Old 11-26-2009, 08:15 AM   #811
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Originally Posted by Nick Priest View Post
I'm sure he was thinking
"thank god that Nick Priest brought this to my attention more directly than any of these yellow bellied mongtards on rctech who would gladly let rapists live in womens changing rooms "
i see you are still trolling around,
Old 11-26-2009, 08:43 AM   #812
jammincrtjames's Avatar
Default Shock bladder sponge insert
What is the effect of running the sponge insert or not running the sponge insert under the bladder?
NEXUS RACING www.nexusracing.com | FANTOM RACING www.fantomracing.com
ORCA www.orcarc.com | TURTLE TRAX / www.turtletraxraceway.com
"If you're not first...you're last!"
jammincrtjames is offline   Reply With Quote
Old 11-26-2009, 08:58 AM   #813
awth's Avatar
Originally Posted by awth View Post
I have a question on the camber change.
I built my T3EU as the manual suggested.
- Camber link: #3 holes on both the front and rear shocks tower
- Shim: Rear 4mm shim above the upright / Front 1mm above c-hub.
- Camber: rear 2deg / front 1.5deg
When setting camber (Hudy setup system), I push down in the center of the shock towers, I notice no camber change at the rear and only +0.5deg in the front. If I push down on one side, say rear right side of the shock tower, the rear right would become 1deg camber and the left become 3deg.
I think this is wrong? Since I thought the side being push down should have more camber for more traction? I also have a t2 009, also using #3holes, but the camber change in the 009 is normal.
Anyone, please? Thank you in advance.
Anyone please?
Alan
- Xray T3 EU & T2 009 EU
- Assoicated 12R5
awth is offline   Reply With Quote
Old 11-26-2009, 09:09 AM   #814
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
Anyone please?
First I would check to make sure there are no bearings binding, or screwed down to tight, on your setup system. Second I would assure their is no other binding or length difference.
I just put my T3 on the setup and tried to simulate what you were saying. I could only duplicate the variance when I either A. Had my one setup triangle with a binded bearing in the rear or B. loosened the screw to much on the setup triangle causing it to move side to side.
So, I would start there.
ChristopherKee is offline   Reply With Quote
Old 11-26-2009, 09:11 AM   #815
hanulec's Avatar
Trader Rating: 27 (100%+)
using the foam increase shock rebound. i've been running "dead" shocks (zero rebound) by not using foam and drilling a small hole into the shock cap in the top behind the bladder.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 11-26-2009, 09:55 AM   #816
Suspended
It's frightening to think that with modern medicine and all technique available to them, they can’t really help you; I should think in the old days you know you were better auf, because nowadays they’re all specialists, everyone’s becoming better and better at less and less! And eventually someone’s gonna to be superb, AT NOTHING!
Nick Priest is offline   Reply With Quote
Old 11-26-2009, 09:57 AM   #817
Super Moderator
Marcos.J's Avatar
bye nick
Old 11-26-2009, 10:44 AM   #818
poor guy he must be so bored.
Burney is offline   Reply With Quote
Old 11-26-2009, 11:02 AM   #819
Fred Hubbard's Avatar
bye nick
Marcos.J YOU ARE MY HERO!!!
Fred Hubbard is offline   Reply With Quote
Old 11-26-2009, 11:12 AM   #820
Super Moderator
Marcos.J's Avatar
Old 11-26-2009, 11:38 AM   #821
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
How many suspensions does one get before they are banned? That's poor Nicks second time... either way, I do love my Ignore list
Back to topic: does anyone know the rolling chassis weight? (no tires/electronics) I am unsuccessful in my search for this answer...
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 11-26-2009, 04:44 PM   #822
Magnet Top's Avatar
You are going to like it. Last night I raced my T3 for the first time. Wow.
My 009 after an evolution of setup changes has become a great car. The T3 has way more mechanical grip right out of the box so I'm happy I made the jump to it.
btw... I had to tune out a bit of traction due to a traction roll in one of the late qualifiers but the car was very easy to drive and had more corner speed than I was prepared to use
Jake
Originally Posted by lowcel View Post
Only one more day until I get to take my T3 to it's first race!
Magnet Top is offline   Reply With Quote
Old 11-26-2009, 06:23 PM   #823
Sith Lord's Avatar
Trader Rating: 21 (100%+)
US Spec
Dimensions
Class: 1/10 electric touring car
Width: adjustable 189 mm
Length: 372 mm
Wheelbase: adjustable 256 - 261 mm
Weight: 548g Ready-to-run weight: 1504g
EU Spec is 498g
As per the Xray Website under specs of the cars
Tamiya XV-01 Rally :: Tamiya FAV 2011 :: Proline Pro2 SCB
Sith Lord is offline   Reply With Quote
Old 11-26-2009, 06:48 PM   #824
pcar951's Avatar
Trader Rating: 19 (100%+)
My T3 balanced at 1405, with a standard weight speed 6. Had to add a bunch to make weight for our series. It's nice to know you can get light with the T3 if you need to!
BTW, the car is great, very planted compared to my 009!
pcar951 is offline   Reply With Quote
Old 11-26-2009, 08:25 PM   #825
RCRjuanabbe's Avatar
any hop up suggestion to make this car a little sturdier. I had problems with steering knuckles and C-hubs on my T2-007, replaced it with all aluminum problems solved. Alum versus plastic? unfair comparison.
the car handles great. feels like it has too much steering but I'd rather have that problem than no steering. tried it for the first time at debbies yesterday, the car is driveable out of the box.
RCRjuanabbe is offline   Reply With Quote
Xray T2'008 Drew_Cat Electric On-Road 1941 01-25-2016 12:36 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
XRay T3 (spy pics) syndr0me Electric On-Road 33 07-13-2010 04:43 PM
where to get xray?? 2qwik Northwest Racers 20 10-10-2009 03:02 AM
New Xray T3!!! Jammin'Trey Electric On-Road 39 10-09-2009 12:40 PM
