Old 10-06-2013, 10:58 AM   #3436
Bikerbob's Avatar
Send a message via ICQ to Bikerbob Send a message via MSN to Bikerbob Send a message via Yahoo to Bikerbob
Originally Posted by wrenchinmonkey View Post
thanks for the opinion. i think i may have found the problem. the upper brace has a support post right behind the steering linkage, anyway i think it was not spaced up correctly causing pressure on the steering linkage. i will give it a shot tomorrow.
Do you mean the support from the steering pivot to the top brace? most people I know dont even use that brace because it stiffens up the car too much.
Xray T3'11 (17.5t spec)
Xray T3'11 CanVTA
12rr BMI 1/12
Bikerbob is offline   Reply With Quote
Old 10-06-2013, 10:59 AM   #3437
JayBee's Avatar
Trader Rating: 31 (100%+)
Bikerbob, there are none....just go with the body you like the looks of. I like my 71Javelin's. Got a couple of the new Firebirds as well.
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 10-06-2013, 11:01 AM   #3438
Bikerbob's Avatar
I still run the steering up the center of the car .. I have not done the steering mod. What is the general opinion on this?? huge difference?? What does it change?
James
Xray T3'11 CanVTA
12rr BMI 1/12
Old 10-06-2013, 12:03 PM   #3439
Bikerbob's Avatar
The protoform stuff eh?
Hmmm Ok.. look into it.
James
Xray T3'11 CanVTA
12rr BMI 1/12
Old 10-06-2013, 02:48 PM   #3440
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
From what someone mentioned on the VTA thread, usually 1 piece bodies are stronger.
So, what is the hot VTA setup right now for the T3?
< Tekno EB48SL / SCT410.3 | Tekno EB410 x 2 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Cain is online now   Reply With Quote
Old 10-06-2013, 08:35 PM   #3441
Tech Legend
Cain's Avatar
odd question here, do any other brands of body posts work on the T3 2012 edition?
Old 10-06-2013, 08:40 PM   #3442
Trader Rating: 20 (100%+)
Some don't have the hex molded in but still work. I use the Corrally posts on my car with no issue.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 10-06-2013, 08:56 PM   #3443
Tech Legend
Cain's Avatar
got any part numbers for the the posts or even better a link to where to buy some?
Thank you for the info by the way!
Do you think the TC6 posts will work?
Old 10-06-2013, 09:35 PM   #3444
http://www.stormerhobbies.com/cgi-bi...ns&pn=COR75703
They have different sizes if needed. Search stormer for them.
Old 10-06-2013, 09:43 PM   #3445
Tech Legend
Cain's Avatar
big thanks! Speaking with someone who has a car in comparison to a T3 he had, I am going to try these:
http://www.tqrcracing.com/shop/produ....asp?p_id=4605
Old 10-07-2013, 07:39 AM   #3446
Bikerbob's Avatar
I thought you were asking because you needed to by local, if your mail ordering why are you not getting the Xray part?
BTW HPI body post set fits right in the hex on the bottom bumper plate.. and they are cheap..
One thing not to skimp on .. get the HARD foam bumper.. or make one out of very dens foam.. It will make the car last MUCH longer.
James
Xray T3'11 CanVTA
12rr BMI 1/12
Old 10-07-2013, 08:02 AM   #3447
Tech Legend
Cain's Avatar
having to equip 2 vehicles, at $9 per pair of posts works out to $36 for a full set of posts for both vehicles. Figure I could save some cash to put towards setup items like springs, etc.
Old 10-08-2013, 06:22 PM   #3448
Bikerbob's Avatar
ok well my car was used when I got it, and I have been going through it.
to do the steering mod.. do you need any parts? or is it just a matter or re-arranging the arms?
Otherwise, I have the car with solid spool on the front - and at the moment ball diff on the rear.
I have a SpecR gear diff... now this car is going to be my TC car - so do I install the gear diff.. if so do I replace the ball? or what are you guys doing.
Also I have spring steel unis front and rear and they are 52mm .. when do you use the long or shorter arms??
James
Xray T3'11 CanVTA
12rr BMI 1/12
Old 10-13-2013, 12:17 PM   #3449
Tech Legend
Cain's Avatar
anyone use the RC9894 Servo mount? I see it listed as being able to be used on the Xray T3, curious if it does work for sure or not before I buy.
Old 10-13-2013, 04:21 PM   #3450
Odin544's Avatar
Trader Rating: 93 (100%+)
You have a link to the servo mount you are referring to? I don't see it anywhere. No luck with google either.
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Xray T2'008 Drew_Cat Electric On-Road 1941 01-25-2016 12:36 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
XRay T3 (spy pics) syndr0me Electric On-Road 33 07-13-2010 04:43 PM
where to get xray?? 2qwik Northwest Racers 20 10-10-2009 03:02 AM
New Xray T3!!! Jammin'Trey Electric On-Road 39 10-09-2009 12:40 PM
