Old 09-30-2013, 07:18 AM   #3421
Bikerbob's Avatar
Send a message via ICQ to Bikerbob Send a message via MSN to Bikerbob Send a message via Yahoo to Bikerbob
seemed odd to me that there is 5mm of adjustment in the rear, but in the front it tells you to put 1mm in front and 1 in behind the arm.. I think the pins are the same length so that gives you 3mm of slop?
James
Xray T3'11 (17.5t spec)
Xray T3'11 CanVTA
12rr BMI 1/12
Bikerbob is offline   Reply With Quote
Old 09-30-2013, 10:21 AM   #3422
Chaz955i's Avatar
James
Sure front and rear use the same length hingepin? Perhaps shorter up front?
Chaz955i is offline   Reply With Quote
Old 09-30-2013, 02:06 PM   #3423
Bikerbob's Avatar
Im saying I have 3mm of slop in the front.. so what am I doing wrong?
James
Xray T3'11 CanVTA
12rr BMI 1/12
Old 09-30-2013, 02:16 PM   #3424
James
Wow, 3mm of slop is A LOT.
Posting a picture of the front of your car could help identify the problem.
Regards,
David
niemand is offline   Reply With Quote
Old 09-30-2013, 03:54 PM   #3425
Chaz955i's Avatar
James
Yeah I saw what you wrote the first time and am trying to figure out where you are getting 5 mm of rear wheelbase adjustability. The set up sheet shows 3 rear and 2 up front. Perhaps post pictures as suggested because no idea where you could get that much front slop using 2 mm of shims unless the pin holders are way out of position.
Old 09-30-2013, 05:22 PM   #3426
Regional Moderator
CarbonJoe's Avatar
The front pins are shorter than the rear pins. I assume you double checked the thickness of the shims you used on the hinge pins? Two 1mm on the front hinge pins, and 1 2mm and 1 1mm on the rear hinge pins? Also, are the hinge pin blocks square to the hinge pin?
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 09-30-2013, 05:48 PM   #3427
Chaz955i's Avatar
Yes, considering the rear hinge pins are 3mm longer than the fronts I can see 3mm of slop using 2mm of shims and the incorrect pin. I already tried suggesting OP check the pins but he says that is not the issue.
Long time no see man, hope things are going well.
Old 10-02-2013, 06:08 AM   #3428
Bikerbob's Avatar
weird I am getting a lot of double posts somehow. sorry about that.
I know most of you reading have moved to a T4 and I am sure most of the parts are compatible with the 2011, but if you have spare bits and in particular those that break.. aka arms knuckles and hubs I would love some help - self employed lol
James
Xray T3'11 CanVTA
12rr BMI 1/12
Old 10-02-2013, 06:08 AM   #3429
Bikerbob's Avatar
thanks guys for the suggestions.. I think the front rear mount was messed and not flush with the chassis.. maybe from a hit.. I loosened the entire front end and retightened.. then switched over to the neutral pin holders and tada! no slop..
Its funny how playing with the car again after 6 months can get you excited to run. LOL even the anodized orange makes you go cool..
James
Xray T3'11 CanVTA
12rr BMI 1/12
Old 10-03-2013, 10:59 AM   #3430
so i just traded for an x ray t3. i ran it for the first time last night in trans am. Went well for the most part other than the steering. It seems that after i come out of a left turn to the long straight my car wants to steer to the left. if i go right quickly it will return to straight. I put the car on a setup kit last night found that when i turn to the left and return to center the toe will remain about 2-3 degrees to the left. if i go to the right and return to center it will return to 0 toe. i removed servo and steering is free without any binding. and i am running a savox 1251 servo. thanks
wrenchinmonkey is offline   Reply With Quote
Old 10-03-2013, 12:57 PM   #3431
Sounds like a broken Servo or Servosaver to me...
Or the steering wheel on your radio gets stuck somehow.
Regards,
David
Old 10-03-2013, 02:17 PM   #3432
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
picked up some of the 2012 edition T3's as well as a T3R with some upgrades on it.
Does anyone have a current VTA setup for carpet that they are liking?
Are the shock towers different on the T3R versus the other T3 versions as far as layout goes?
In general, am I right in assuming you don't need the specific xray servo saver? What ones other than that one do people recommend?
< Tekno EB48SL / SCT410.3 | Tekno EB410 x 2 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Cain is online now   Reply With Quote
Old 10-03-2013, 10:31 PM   #3433
Regards,
David
thanks for the opinion. i think i may have found the problem. the upper brace has a support post right behind the steering linkage, anyway i think it was not spaced up correctly causing pressure on the steering linkage. i will give it a shot tomorrow.
Old 10-04-2013, 08:23 AM   #3434
Tech Legend
Cain's Avatar
did some more searching and it appears the T3 2012 had some changes that the T3R didn't have.
have to say though, even though the T3R is the cheapy car, it feels excellent.
Old 10-06-2013, 10:53 AM   #3435
Bikerbob's Avatar
Well I am now setup for T3'11 in both spec tc and VTA and lots of spares. I am a happy fellow.
Its nice to concentrate on one car.. especially when there are so many adjustments you can make on this car.
Indoor carpet season is coming up.. I assume most people use the offset wheel hexes for VTA???
What is the best performing VTA body people have found??
James
Xray T3'11 CanVTA
12rr BMI 1/12
Xray T2'008 Drew_Cat Electric On-Road 1941 01-25-2016 12:36 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
XRay T3 (spy pics) syndr0me Electric On-Road 33 07-13-2010 04:43 PM
where to get xray?? 2qwik Northwest Racers 20 10-10-2009 03:02 AM
New Xray T3!!! Jammin'Trey Electric On-Road 39 10-09-2009 12:40 PM
