Old 02-07-2011, 03:36 AM   #3376
fantapants22's Avatar
Originally Posted by nerdling View Post
Very much an FK05. Check out the XRAY website (or a google image search) to see what a T3 looks like.
sorry guys now the guy whos listed it has finally sorted out everything im glad he has aswel because i just about bid on it before i seen the pics of it! lucky i didnt! thanks for that mate
Savage X with LRP.30, Team Associated RC8.2 With LRP.21, Kyosho MP9 CNC upgraded with JS Racing 521R, Kyosho Spada 09, Kyosho Mini Inferno 09 (nitro), Traxxas Mini Revo massively hopped up, Parkzone Radian Pro DX6i. Eflite Blade MCPx
fantapants22 is offline   Reply With Quote
Old 02-12-2011, 12:24 AM   #3377
blade072's Avatar
Trader Rating: 98 (100%+)
Default t3 LIPO MULTI DIFF
http://www.redrc.net/2011/02/xray-mu...po/#more-39820
thought they would of concentrated on a gear diff instead....
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 08-02-2011, 05:01 PM   #3378
MeBeMikey's Avatar
Originally Posted by Dusttt View Post
Does anyone know if schumacher or hpi springs will work on the t3s?
HPI pink front and silver rear. Works like a dream and don't ever change it, no matter what indoor track I go to. Pinks were hard to find a while ago. Dunno how it is now.
Xray T4'18, HW XR10 pro, R1Wurks 13.5 V16 - Indoor Carpet
Xray T4'17, HW XR10 pro, Fleta ZX V2 13.5- Outdoor Tarmac
Xray T4'16, HW Extreme Stock, Actinium V2 13.5 -Wet Racing
RcDisCo.com
MeBeMikey is offline   Reply With Quote
Old 08-02-2011, 05:07 PM   #3379
MeBeMikey's Avatar
It is a gear diff.
Testing at my track with lots of team drivers building them all together said after they ran it that it handles no different than a ball diff. I bought one just a few minutes ago and will post up here my thoughts. I'm sure I will come to the same conclusion but can't tell til i run it. Probably won't use it, but who knows. RC racing is all about testing new stuff that comes out.
RcDisCo.com
Old 08-11-2011, 09:57 AM   #3380
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Anyone happen to have a t3 foam car or a t3 they want to sell?
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 08-11-2011, 11:22 AM   #3381
HarryLeach's Avatar
Send a message via AIM to HarryLeach
Originally Posted by MeBeMikey View Post
It is a gear diff.
No, the link you quoted is for the multi-diff, which is a front one way that can be run as a one way, locked one way, or spool. The link was also posted back in February.
The XRay gear diff has been since introduced [within the last month], with very good reviews.
Privateer racing lots of stuff.
Remember kids, racing isn't fair!
HarryLeach is offline   Reply With Quote
Old 08-11-2011, 12:00 PM   #3382
rx7ttlm's Avatar
If you happen to find yourself breaking the t3 diff gears you can use the NT1 steel gears
Old 08-12-2011, 12:09 AM   #3383
nerdling's Avatar
No Foam spec for the T3. Best thing you can do is get a T3 then buy the XH suspension parts and front Diff. I think they did a thick upper and lower deck as well.
--XRAY--NOSRAM--PROTOFORM--MUCHMORE--
www.teamxray.com -- www.hudy.net -- www.hobbyexpress.com.au
nerdling is offline   Reply With Quote
Old 08-12-2011, 12:13 AM   #3384
defcone's Avatar
Trader Rating: 15 (100%+)
http://www.teamxray.com/teamxray/pro...p?prod_id=3290
defcone is offline   Reply With Quote
Old 08-12-2011, 12:39 AM   #3385
rx7ttlm's Avatar
I don't know where you got that idea, xray made a t3 us spec car. They don't make a 2011 foam car. But the T3 foam car didn't need much in the way of help.
Old 11-16-2011, 08:46 AM   #3386
Meradin's Avatar
Trader Rating: 19 (100%+)
I am using a T3'10 for a vta class and I am pretty happy with it. I need a little help with the setup. I am loosing traction in the high speed corners. As I come off the straight I can spin out of the turn about half way through the turn if I am not careful and I am loosing a lot of ground there.
I have started with the basic rubber tire setup and moved to a lighter spring in the rear to help, I thought, bring the rear of the car around and give it more traction.
What can do to lock the rear (and front) in during these high speed turns but not sacricfice agility in the sharp corners?
Meradin is offline   Reply With Quote
Old 11-16-2011, 03:08 PM   #3387
nerdling's Avatar
Oops... sorry
My memory is not what it used to be
Old 12-14-2011, 09:35 PM   #3388
Meradin's Avatar
What causes slop in the front arms? For example, I have 1mm spacers in front and the rear of the arms but I can move them back and forth on the shaft about 1mm.
Better than Randy, Adam said so!
Second thought...I don't trust Adams, they make up everything!
"Leave it to Steever", custom paint masks, decals, and paint.
Old 12-15-2011, 03:29 AM   #3389
Skiddins's Avatar
Loosen the screws on the roll centre holders and squeeze them towards eachother while doing them back up.
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 12-15-2011, 05:44 AM   #3390
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
Default Xray question
Hello can one of the Xray enthusiast please answer my question?
I purchased some custom painted bodies and was intending on running them on a x ray t2 008 that i never ended up getting. I want to sell the custom painted bodies but I want to make sure that what I put in my description is correct. Can someone tell me if all of the xray bodies hole patters line up all of the T-2 and T-3 also will this hole pattern fit on any other chassis from another brand like the TRF 416 or 417?
Many thanks in advance...!
RED-LINE M03 is offline   Reply With Quote
Xray T2'008 Drew_Cat Electric On-Road 1941 01-25-2016 12:36 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
XRay T3 (spy pics) syndr0me Electric On-Road 33 07-13-2010 04:43 PM
where to get xray?? 2qwik Northwest Racers 20 10-10-2009 03:02 AM
New Xray T3!!! Jammin'Trey Electric On-Road 39 10-09-2009 12:40 PM
