Old 01-17-2011, 07:16 AM   #3346
san.'s Avatar
Trader Rating: 60 (100%+)
Mint condition T3 2010 roller for sale:
http://www.rctech.net/forum/r-c-item...9-shipped.html
Awesomatix USA||Roche RC USA||Mon-Tech Racing USA||Sanwa
san. is offline   Reply With Quote
Old 01-18-2011, 08:32 PM   #3347
rfleck's Avatar
Trader Rating: 58 (100%+)
Guys,
I picked up an xray T3 EU in which I plan to run in a 17.5 rubber sedan class. Local track is medium size, semi high traction carpet.
Are there any areas of concern with the durability of the car? Also, assuming the car is completely stock, what is a safe gearing recommendaton to at least get me in the ballpark with tekin RS?
Thanks,
Ron Fleck Jr.
Nemoracing USA!
Agama-Beta-Bullitt!
rfleck is offline   Reply With Quote
Old 01-18-2011, 08:44 PM   #3348
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
Originally Posted by rfleck View Post
Guys,
Thanks,
Car is solid but like anything will break if you hit it hard enough.
Boosted around 6.4
Non boosted (stock spec) around 4.2
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
www.toycarracingblog.com
Dane is offline   Reply With Quote
Old 01-18-2011, 08:47 PM   #3349
PinoyCali's Avatar
Default Hard bumper
Hello All,
Any body using the hard bumper ?
What is advantage/disadvantage ?
Thanks.
PinoyCali is offline   Reply With Quote
Old 01-18-2011, 08:52 PM   #3350
trerc's Avatar
Trader Rating: 89 (100%+)
Originally Posted by PinoyCali View Post
Hello All,
Thanks.
Yes, many
Advantage, We break less parts! Disadvantage some say weight, I'll take the extra weight over added protection.
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
Old 01-18-2011, 08:54 PM   #3351
ByteStream's Avatar
Guys,
Thanks,
I'd say you have one of the most durable kits out there .. but nothing is perfect.
I would put 3mm setscrews in the rear uprights (the unused holes) to add a little strength for the outer camber link if you have not done so already.
Also, be gentle with the outer camber link screws all around the car, if you change shims enough times you might strip them, so don't over tighten.
ByteStream is offline   Reply With Quote
Old 01-18-2011, 08:56 PM   #3352
Still Bill's Avatar
Hello All,
Thanks.
Keeps the front arms intact in a big hit.
No downside that I can think of. Weighs similar to stock bumper.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 01-18-2011, 08:56 PM   #3353
ByteStream's Avatar
Originally Posted by trerc View Post
Yes, many
+1
I use the Xray Impact Absorbing Front Bumper and the Parma T2 Ultimate Bumper. Highly recommended.
Old 01-18-2011, 11:42 PM   #3354
PinoyCali's Avatar
Thanks guys
Old 01-19-2011, 12:06 AM   #3355
Magnet Top's Avatar
Originally Posted by ByteStream View Post
+1
I use the impact absorbing front bumper as well. The only real negative is that it can get deformed and start dragging fairly easily so you'll have to watch for that and bend it up. Someone suggested I use a heat gun to pre bend it up a bit, something I still haven't done but intend to.
Magnet Top is offline   Reply With Quote
Old 01-19-2011, 02:50 AM   #3356
blade072's Avatar
Trader Rating: 98 (100%+)
the HARD bumper weighs 20g heavier than the stock bumper....
the upside....better front grip and does not bend...it does break other cars that come in contact with it though....
i also got some top racing pin sleeves in the standard cvd's which work a treat and there is no need to use of a grub screw (thanks ant)
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 01-19-2011, 08:36 AM   #3357
rfleck's Avatar
Default Good carpet base setup?
Hey guys,
I looked through the forum and cannot find a good rubber base setup for a T3 EU for carpet.
Any suggestions?
Ron Fleck Jr.
Nemoracing USA!
Agama-Beta-Bullitt!
Old 01-19-2011, 09:25 AM   #3358
Dane's Avatar
Hey guys,
Any suggestions?
Put the stock setup on it. It works well.
blade072 - more weight in front does not mean more front end grip. Actually means more rear end grip.
Old 01-19-2011, 11:49 AM   #3359
05forfun's Avatar
Trader Rating: 81 (100%+)
more weight in front does not mean more front end grip. Actually means more rear end grip.[/QUOTE]
Interesting.. Would you mind explaining how that works theoretically?
05forfun is offline   Reply With Quote
Old 01-19-2011, 02:05 PM   #3360
303slowdown's Avatar
more weight on either end means more weight to transfer to the other end ex.more weight on front means on acceleration more wight is transferd to the rear=more rear grip, more weight on the rear means on braking or deceleration more weight is tranferd to the front=more stearing
hope that helps
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Xray T2'008 Drew_Cat Electric On-Road 1941 01-25-2016 12:36 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
XRay T3 (spy pics) syndr0me Electric On-Road 33 07-13-2010 04:43 PM
where to get xray?? 2qwik Northwest Racers 20 10-10-2009 03:02 AM
New Xray T3!!! Jammin'Trey Electric On-Road 39 10-09-2009 12:40 PM
