Old 12-19-2010, 04:47 AM   #3331
Skiddins's Avatar
Originally Posted by traxxas.uy View Post
Hi,
I need to add a cooling fan to my T3 motor.
The motor ups 75C, aprox 167 Farenheit.
I see there is little room to install it.
Which do you use ???
Can you tell me which is the best for this chassis.
There is a pic attached of my chassis.
Thanks !!!
Don't bother, most motors will take up to 100degC now, if your regularly getting a lot higher than that you have set something incorrectly on your ESC or your motor is poo.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 12-19-2010, 07:16 AM   #3332
georgec's Avatar
Originally Posted by R1wurks View Post
this should work fine
http://www.speedtechrc.com/store/ebp...id=689&id=8899
if you have space issues then you can use this.
http://www.speedtechrc.com/store/ebp...id=689&id=9848
both are fully adjustable,you can basically position the fan anywhere around the length of the motor. they both come with high rpm fans (15,000+rpm) that are good for cooling 30degF to 40degF cooler compared to no fans.
It looks like they are both out of stock, you can buy them here too. r1wurks.com
These look very nice, altough they are pricey and out of stock!
georgec is offline   Reply With Quote
Old 12-21-2010, 09:36 AM   #3333
I have a T-3 with a 48p 84t spur .What pinion should I use on a 10.5 and a 13.5.I just want a safe ratio.I don't want to overheat them.Don't worry asking about what size track we run on.It is so small and goofy I don't think it matters..
thanks. merry xmas!
tc3jp is offline   Reply With Quote
Old 12-22-2010, 04:23 AM   #3334
georgec's Avatar
When in doubt start low say around 6.0 FDR. 84/27x1.9=5.91
Run it for about 2 min. check the temp and go from there.
MerryXmas
Old 12-22-2010, 08:15 AM   #3335
gacjr0's Avatar
Trader Rating: 15 (100%+)
I was very happy with 84/26 with a 13t on a goofy track.
Rubber tires right?
In the A-main starting at 5:35 in the video.
Blue car, yellow wing, yellow flames.
+ YouTube Video
-Dangerous with power tools-
gacjr0 is offline   Reply With Quote
Old 12-23-2010, 11:26 PM   #3336
jsr555's Avatar
Trader Rating: 17 (100%+)
Default Titainium Pivot Pins
Anybody know where I can get Titainium Pivot / Hinge Pins for the T3. Been looking but can't seem to find any after-market ones for the T3.
thanks
Xray T4 & HPI/HB Pro 5 - Powered by Hobbywing
SQ: HPI RS Pro -HPI RS Pro 2 - HPI Pro 3 - HPI Pro ?? - HPI Pro 5
jsr555 is offline   Reply With Quote
Old 12-24-2010, 04:46 PM   #3337
SavageCanadian's Avatar
Trader Rating: 58 (100%+)
Send a message via MSN to SavageCanadian
For anyone running the Spec R diff, what would be a decent oil to try as a starting point running in the 17.5 class. Also what are the noticable differences over the ball diff?
CR Performance Custom RC Parts (PM for details)
Colin Roussel
2013/2014 WCICS CTA Champ
Awesomatix | CRP F1 | Trinity/Revtech | SANWA | ORCA
SavageCanadian is offline   Reply With Quote
Old 12-24-2010, 05:20 PM   #3338
Default Steering
Stillbill I wouldn't be worried about the steering it works great. I would update the car to a 2011 specs if your buying a chassis the new car is dialed.
AARON YOUNG is offline   Reply With Quote
Old 12-25-2010, 05:12 AM   #3339
georgec's Avatar
It depends on the level of traction, I run on a low traction carpet track and find 3000wt to work quite well. If you are running on a high bite track start with 1000wt and go up or down from there. The only difference I can fell with the gear diff is that seems to remain some what more consistent over the race day. The only down side is the Spec R tends to leak a bit with thinner than 1000wt lube. I'm hoping Xray will come out with a gear diff soon for the T3...hint...hint
Old 01-05-2011, 09:52 PM   #3340
Default bearings
Are the bearings in the T3 the same as the T3R?
mdhyams is offline   Reply With Quote
Old 01-05-2011, 09:55 PM   #3341
blade072's Avatar
Trader Rating: 98 (100%+)
yes they are mate.....
309000 bearing set T2/T3
but look around as you can get cheaper sets from other manufacturers
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 01-05-2011, 10:18 PM   #3342
blade072's Avatar
thanks. merry xmas!
my ratio is 7.98 (84/20) and i am amongst the fastest at our track in 10.5.....also just started using the rw spurs currently using (83/20)which is now 7.88 so see how you go.. oh here is our track btw...
http://www.aerccc.org.au/
David Randall
Old 01-06-2011, 04:10 AM   #3343
georgec's Avatar
Very nice track!
Old 01-06-2011, 06:52 AM   #3344
Skiddins's Avatar
I would start at 1000cSt and try it.
We have found that coming off power it can sometimes make the back end kick a little. This is particularly bad on a track with a lot of sharp corners that are approached at high speed.
This all depends on the size or track and grip levels etc.
If you find the back end a bit loose, try the ball diff with no other changes and see how it feels.
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 01-06-2011, 04:20 PM   #3345
blade072's Avatar
+1 at the moment have been happy with the ball diff which suits our track conditions .....but now that i have the new gaskets, shims and o-rings am going back to trying the geardiff using 1000....which is what i was using oh and prepping the track helps....thats when the geardiff comes into its own...
David Randall
Xray T2'008 Drew_Cat Electric On-Road 1941 01-25-2016 12:36 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
XRay T3 (spy pics) syndr0me Electric On-Road 33 07-13-2010 04:43 PM
where to get xray?? 2qwik Northwest Racers 20 10-10-2009 03:02 AM
New Xray T3!!! Jammin'Trey Electric On-Road 39 10-09-2009 12:40 PM
