Old 12-12-2010, 08:26 AM   #3316
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
You won't get them completely dead because the old bladders allow the piston to bounce off of them. The low profile bladders will help a good deal but I find them a bit more fragile than the old ones.
Second, you should drill a small hole through the plastic shock cap. Essentially you are allowing the air between the bladder and cap to vent.
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
www.toycarracingblog.com
Dane is offline   Reply With Quote
Old 12-12-2010, 10:55 AM   #3317
John_S's Avatar
Yes the tamiya bladders fit. They are pretty much identical to the new xray bladders. If you take your time in shock building making sure that there is zero rebound and the damping feels roughly the same it will make a great deal of difference to the handling of the car. also you need to drill the shock caps for zero rebound. Drew Ellis was meant to release a shock building video for the car but i have never seen it anywhere.
John_S is offline   Reply With Quote
Old 12-12-2010, 11:40 AM   #3318
Potoczak's Avatar
Trader Rating: 112 (100%+)
I think we are all waiting for a shock building video. I hope we have one soon!!!
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 12-12-2010, 12:02 PM   #3319
trerc's Avatar
Trader Rating: 89 (100%+)
+1
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
Old 12-12-2010, 12:35 PM   #3320
ElectriMagician's Avatar
Originally Posted by traxxas.uy View Post
Hi,
I need to add a cooling fan to my T3 motor.
The motor ups 75C, aprox 167 Farenheit.
I see there is little room to install it.
Which do you use ???
Can you tell me which is the best for this chassis.
There is a pic attached of my chassis.
Thanks !!!
Many racers use this fan! I believe Robbie Dodge uses one and he can confirm if he wishes to!
Get them here! http://bossrcmotorsports.com/shop.html
Check it out here!
Nathan Laskey
ElectriMagician is offline   Reply With Quote
Old 12-13-2010, 05:35 AM   #3321
georgec's Avatar
+2
georgec is offline   Reply With Quote
Old 12-13-2010, 06:58 AM   #3322
Trader Rating: 16 (100%+)
hell yeahhh !
ronaldo-1234 is offline   Reply With Quote
Old 12-17-2010, 03:04 PM   #3323
of all of you that converted your t3 with the lipo chassis plate, which one did you use? Are you happy with it? I want to replace the chassis on my T3 and I am hoping to put a lipo chassis on it but I dont know what to use. Smokem or exotec or replace with Xray stock one.
AverageRacer is offline   Reply With Quote
Old 12-17-2010, 03:34 PM   #3324
Johnny Wishbone's Avatar
If your meaning a narrow chassis, if you use the Xray stock piece, you'll have to upgrade to the dual bellcrank steering as well. Pretty sure they didn't make a narrow plate for the '10 stock. So your choices would be the smokem or the exotec only.
Gary Lanzer
Old 12-17-2010, 05:44 PM   #3325
No I meant the 6cell chassis that comes on the EU car as for the other chassis yes I mean the narrow one. What are the differences that people noticed between the three chassis.
Old 12-17-2010, 09:26 PM   #3326
Still Bill's Avatar
For my asphalt track conditions, the original T3 6-cell EU chassis had a lot of drag marks on it. Going to the Exotech chassis reduced that for me and made the car more predictable in turns without experiencing any drag. On carpet, I have yet to make my T3 Exotech handle as well as my Corally RDX Phi did. I have not gone to the T3 2011 because I have concerns about the new dual lever steering setup.
I do have a near perfect T3 6-cell EU chassis plate with all the edges prepped for cheap. Doubt I will go back to it; so, PM me if interested.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 12-18-2010, 09:59 AM   #3327
georgec's Avatar
Are these "NT1 composite wheel hubs" what came on my T3R?
Thanks, GeorgeC
Old 12-18-2010, 01:04 PM   #3328
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Thanks, GeorgeC
nope, different design.
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 12-18-2010, 04:56 PM   #3329
RCknight's Avatar
Bill
Just curious what concerns you have about the dual steering? It's dual steering... Most TCs are using it.
RCknight is offline   Reply With Quote
Old 12-18-2010, 06:27 PM   #3330
R1wurks's Avatar
Hi,
Thanks !!!
this should work fine
http://www.speedtechrc.com/store/ebp...id=689&id=8899
if you have space issues then you can use this.
http://www.speedtechrc.com/store/ebp...id=689&id=9848
both are fully adjustable,you can basically position the fan anywhere around the length of the motor. they both come with high rpm fans (15,000+rpm) that are good for cooling 30degF to 40degF cooler compared to no fans.
It looks like they are both out of stock, you can buy them here too. r1wurks.com
R1wurks is offline   Reply With Quote
Xray T2'008 Drew_Cat Electric On-Road 1941 01-25-2016 12:36 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
XRay T3 (spy pics) syndr0me Electric On-Road 33 07-13-2010 04:43 PM
where to get xray?? 2qwik Northwest Racers 20 10-10-2009 03:02 AM
New Xray T3!!! Jammin'Trey Electric On-Road 39 10-09-2009 12:40 PM
