Old 11-05-2010, 05:26 PM   #3256
jake95's Avatar
Trader Rating: 27 (100%+)
my car understers and is taily
XRAY✯NOSRAM✯SANWA
jake95 is offline   Reply With Quote
Old 11-05-2010, 07:21 PM   #3257
Yeah mine too
understeer is offline   Reply With Quote
Old 11-05-2010, 09:06 PM   #3258
blade072's Avatar
Trader Rating: 98 (100%+)
try 2.6 springs front and rear, 3 hole non adjustable pistons and 350 oil all round........works for me....
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 11-06-2010, 06:11 AM   #3259
jake95's Avatar
i ve tried diffrent springs im using 3 hole piston with 350 oil
XRAY✯NOSRAM✯SANWA
Old 11-06-2010, 06:13 AM   #3260
jake95's Avatar
tamiya bladers work great in the xray shocks
XRAY✯NOSRAM✯SANWA
Old 11-06-2010, 07:45 AM   #3261
RCknight's Avatar
deleted post
RCknight is offline   Reply With Quote
Old 11-06-2010, 11:57 AM   #3262
Big Features's Avatar
Narrow the rear and widen the front
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix FDJ Sauce
Big Features is offline   Reply With Quote
Old 11-06-2010, 04:30 PM   #3263
jake95's Avatar
thanks i will try that how much tow in at the rear should i run
XRAY✯NOSRAM✯SANWA
Old 11-06-2010, 05:21 PM   #3264
jake95's Avatar
how many mm shims should i use on the front to widen it
XRAY✯NOSRAM✯SANWA
Old 11-08-2010, 10:53 AM   #3265
Johnny Wishbone's Avatar
You could also try adjusting your wheel base settings.
Old 11-08-2010, 01:23 PM   #3266
jake95's Avatar
yeah i have used the wheel base i have made it shorter
XRAY✯NOSRAM✯SANWA
Old 11-08-2010, 03:09 PM   #3267
I think you should be long wheel base, at least in the rear.
Old 11-08-2010, 10:19 PM   #3268
jake95's Avatar
ill try it
XRAY✯NOSRAM✯SANWA
Old 11-08-2010, 11:45 PM   #3269
I usually run 2mm in front of the rear arms. I use (2) of the gold 1.15 shims to widen the front of the car with the front arms all the way forward. I'm pretty much running Paul's asphalt set-up. The only issue I have with it is that the car steers ALOT. I'm going with lighter oil and more droop in the front.
Mike
Mike Kling
Old 11-09-2010, 01:25 AM   #3270
jake95's Avatar
Mike
ill try it do you run a gear diff
XRAY✯NOSRAM✯SANWA
Xray T2'008 Drew_Cat Electric On-Road 1941 01-25-2016 12:36 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
XRay T3 (spy pics) syndr0me Electric On-Road 33 07-13-2010 04:43 PM
where to get xray?? 2qwik Northwest Racers 20 10-10-2009 03:02 AM
New Xray T3!!! Jammin'Trey Electric On-Road 39 10-09-2009 12:40 PM
