Old 11-03-2010, 01:42 AM   #3241
jake95's Avatar
Trader Rating: 27 (100%+)
Originally Posted by blade072 View Post
1000wt losi fluid that comes in a tube works very well.......
thanks
XRAY✯NOSRAM✯SANWA
jake95 is offline   Reply With Quote
Old 11-03-2010, 04:10 AM   #3242
ronsand's Avatar
Default Xray T3 US Foam set-up (2010)
Hello all.
I am running on a relatively technical indoor carpet track with on one 20m straight ending in a long sweeping curve. The total length of the track is apx. 100m.
I have problem finding any set-up sheets for the US Foam edition. As of now I am running the basic setup and it is quite OK, but I feel there is room for improvement. It is quite good in the slower technical parts of the track but I feel that it under steers (pushes) when I go off the power in the some of the high speed corners
I have been using the Gecko Low Profile 1/10 Electric Sedan tires (28mm) 35-37 shore in the rear and 37-40 in the front (turned down to 59mm). Traction compound full with rear and inner half of front tires. Power is from a Tekin RS Pro and Tekin Redline S 10.5T on 2 cell lipo (45C). Roll-out is about 23mm as of now (FDR 7.98).
I hope someone can point me to alternative setup sheets and/or give me some thought about what you have found to be working best.
Regards Ronny
Mugen MBX7 - Tekno V4 MBX6 - DEX410v3 - DEX210 - DESC410 - Serpent S411 - Futaba 4PKs - Tekin RX8 + RS Pro - Werks B6
ronsand is offline   Reply With Quote
Old 11-03-2010, 09:22 AM   #3243
darrenoakley's Avatar
Just building the alloy shocks and wondered the Pro's/Con's of installing the foam inserts.
I have put them in as the manual says to do so but have heard of guys not running with them, but dont know if it affects the rebound or something.
Xray x11
Xray T3 011
darrenoakley is offline   Reply With Quote
Old 11-03-2010, 10:33 AM   #3244
Big Features's Avatar
They act as volume compensators. They also affect rebound. I only ran them on Asphalt or low-traction conditions.
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix FDJ Sauce
Big Features is offline   Reply With Quote
Old 11-03-2010, 05:29 PM   #3245
jake95's Avatar
are ecs drive shafts worth buying
XRAY✯NOSRAM✯SANWA
Old 11-03-2010, 11:53 PM   #3246
Yes! Use shrink wrap around the coupling to help secure the drive pins.
Mike Kling
Old 11-04-2010, 12:47 AM   #3247
jake95's Avatar
thanks
XRAY✯NOSRAM✯SANWA
Old 11-04-2010, 05:22 AM   #3248
Trader Rating: 16 (100%+)
Many commented T3 runs well with TRF Shocks. How do you get it to run on TRF Shocks? Any pics?
ronaldo-1234 is offline   Reply With Quote
Old 11-04-2010, 07:54 AM   #3249
303slowdown's Avatar
Trader Rating: 24 (100%+)
Originally Posted by ronsand View Post
Hello all.
Regards Ronny
I would recomend picking up a xxx main set up book its a little out dated but still very informative and more detailed than the xray book. I can never find others set ups that work for me so i keep changing things till the car does what i want. Good luck.
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 11-04-2010, 11:01 AM   #3250
JayL's Avatar
you use the xray shock end screwed onto the tamiya shocks and some guys drill out the cap and use the plastic top mount as well
I would try the new t3 2011 bladders in your current shocks before you switch, they pretty much make the xray shocks the same a tamiya especially the xray aluminum ones
JayL is offline   Reply With Quote
Old 11-04-2010, 03:08 PM   #3251
Send a message via AIM to goop
Hello all.
Regards Ronny
try using 30-35 shore tires front and rear. you should try and get the bigger rim tires if possible they produce more traction and corner speed. hope this helps
Hurricane Motorsports
Team Trinity
TOP Racing - Gravity Rc - Contact tires - KO Propo - Competition Electronics
goop is offline   Reply With Quote
Old 11-04-2010, 04:53 PM   #3252
ronsand's Avatar
Thanks for the advice.
I suspect I will have to dig even deeper into the theory of setting up the cars. So far I have only done two full seasons of racing (1/10 touring in the winter and 1/8 buggy in the summer) and still have lots to learn.
I usually run the larger dia. rims already, but I might try with some softer tires.
Old 11-04-2010, 09:21 PM   #3253
what body are u running
Team Trinity
Old 11-04-2010, 11:25 PM   #3254
gonzo416's Avatar
Trader Rating: 39 (98%+)
Hello all.
Regards Ronny
Try using Andrew Ellis iic T2 009 setup. It should work.
gonzo416 is offline   Reply With Quote
Old 11-05-2010, 11:59 AM   #3255
Ran the 11 car today for the first time. Got tracking roll problem decide to stiffen up the spring to front Xray blue and rear Dark blue Now could not get the desired ride hide. What do i check or do? Stock spring ride height is 5 spring change ride height cant be lowered more than 5.5 adjusted the caps to the fullest..
Romeo 7 (Chief Entertainment Officer)
Romeo is offline   Reply With Quote
Xray T2'008 Drew_Cat Electric On-Road 1941 01-25-2016 12:36 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
XRay T3 (spy pics) syndr0me Electric On-Road 33 07-13-2010 04:43 PM
where to get xray?? 2qwik Northwest Racers 20 10-10-2009 03:02 AM
New Xray T3!!! Jammin'Trey Electric On-Road 39 10-09-2009 12:40 PM
