Old 10-18-2010, 05:59 PM   #3196
Slideaway's Avatar
Originally Posted by Photocycler View Post
Thanks, what would my limitations be racing the T3R without those parts? I am a beginner road guy so do not know much more aside from gearing, camber and caster settings
Not much limitation. Like Bonadona and others said, try to get a set of turnbuckle and sway bars and that's it. If you want more option, then I suggest you to get a second hand T3 in good condition to limit the cost.
But to begin TC class with, the T3R will be great.
Don't worry to much about the settings. You can follow the intruction manual to start with (it will work well), but focus first on these 4 crutial points:
- Correct assembly of the car, suspensions travel free from any issue, and symetric L/R.
- Differential tight enough but ALWAYS smooth.
- Bodyshell/wing correctly cut and posted.
- and the most important of all, choose the right tires for your application and take the greatest care of them.
Everything else will come on time !
Happy begining !
Ludo
Thai Ride Tech Support.
Slideaway is offline   Reply With Quote
Old 10-18-2010, 06:10 PM   #3197
Photocycler's Avatar
Trader Rating: 34 (100%+)
Ate the Cvds and diffs the same in the T3 and t3r
Photocycler is offline   Reply With Quote
Old 10-18-2010, 06:18 PM   #3198
Slideaway's Avatar
Nope, T3R comes with 4 natural Aluminium CVD. T3 comes with hudy spring steel ones for the front and black aluminium for the rear.
Differential is also different. Plastic outdrives, disk shapes etc are different.
Ludo
Old 10-18-2010, 06:20 PM   #3199
cwoods34's Avatar
Also, if you plan to buy the ECS shafts for a T3R, you will need to either Dremel the stock caster blocks, or buy the new style to fit the joint.
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 10-18-2010, 06:58 PM   #3200
Would a 09 or 08 t2 be better then a t3r
I plan to run a tekin rs esc and 17.5 brushless with lipos
Old 10-19-2010, 05:25 AM   #3201
georgec's Avatar
Originally Posted by Slideaway View Post
On T3R : No carbon fiber parts, only FRP (glass fiber)
No sway bar, no orange coated parts, no adjutable turnbuckle, no S.Steel drive shaft. check the Xray web site for the exact list.
But honestly, if you really want to upgrade a T3R to T3 (which is of course possible), it's gonna be pricey. More than buying the T3 directly. No point...
Not so pricey if your a cheap skate like myself on a tight budget. T3R Kit new=$250.00, T3 chassis and upper deck=45.00, set of turn buckles with ball ends and balls=15.00, full set of sway bars and hdwre=19.00 and so on, all the upgrade parts were purchased second hand in exc. condition from the pull apart guys and with the release or the new T3-11 there will be many more used parts and cars available! From what I have seen most Xray owners take very good care of their cars so to me buying a used Xray product isn't much of a gamble IMHO.
georgec is offline   Reply With Quote
Old 10-19-2010, 10:59 AM   #3202
academygaz's Avatar
Has anyone tried modding a T3 to make it more 2011 spec? I mean, Smokem or Exotek chassis plate, and dual bellcrank steering from a TRF416 or TCX?
I should have a used T3 coming this week, and if the lower deck needs replacing then I'll probably get a Smokem one, and I have the steering parts from TRF416 available to me....
Quote, Leodis, 2007: ''I've been shopping online for 9 years and the only charge I've ever had to dispute with my credit card company was from TiR. Congratulations TiR. Even porn sites are more ethical than your company!''
RC cars - I haz sum.
academygaz is offline   Reply With Quote
Old 10-19-2010, 11:28 AM   #3203
keep us imformed it is a cheaper option than a new T3'11
sidecarphil1 is offline   Reply With Quote
Old 10-19-2010, 12:37 PM   #3204
DS Motorsport's Avatar
This is something I'm planning to design this winter.
Also like to have the servo in the same position as Tamiya has it.
Furthermore I'm planning on making a version which uses the Tamiya suspension blocks, the way the T3 has it is an improvement, but I still think the Tamiya/TCX/Yokomo style of suspension blocks is superior.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 10-19-2010, 01:30 PM   #3205
Johnny Wishbone's Avatar
Please explain why?
Old 10-19-2010, 01:34 PM   #3206
Ok , i will have contact with you
I am planning on making another chassis plate with TRF416 steering and the servo turned by 90 dergees
i think this will give the car the best of both worlds , i like the Xray suspension mounting points though so i will leave those alone
Old 10-19-2010, 02:47 PM   #3207
Originally Posted by Johnny Wishbone View Post
Please explain why?
I don't think there would be much difference performance wise, maybe the car will feel a bit more direct because of the elimination of the composite rollcentre inserts.
However I really dislike working with the system, fiddly to mount with the shims, takes more time to change rollcentre, high change of mis aligning the parts and so binding the suspension.
In the short time I owned a Serpent S400 I really started to like the suspension block system this car and the other cars mentioned are using.
It's just a personal preference, I also think it looks a lot better.
Ok sure, no problem.
Yes, I think this as well, I like the design of the 416/417 a lot better as the T3, but the quality and availability made me decide to run a T3.
I will start next week with converting the original T3 chassis to a cad-file.
Then I will try to acquire a 416 steering system and chassis to put those into cad as well.
I'm also planning on doing a lot of calculations regarding the car's flex.
First with the original chassis and how far it's off regarding symmetrical flex.
I'm guessing the methods used by most factories are pretty crude simply because the software packages to do these kind of calculations are hugely expensive.
At first I will work on a chassis with the 416 steering setup and original suspension mounting points.
If I'm pleased with the results and there is enough interest I will look into a limited production of the chassis.
P1-RC.com
Old 10-19-2010, 03:16 PM   #3208
what mah and c rating battery's are best to run in a T3 in stock 17.5 BL class
Old 10-19-2010, 05:44 PM   #3209
cwoods34's Avatar
I like a Thunderpower 5000 mAh 40C 2S for all of my 17.5 needs......
Also, with the 2 corner battery mounts (small black plastic pieces) a TP 5000 fits perfectly.
Old 10-19-2010, 09:52 PM   #3210
Trader Rating: 24 (100%+)
The SMC 5200mah 50c CMAX is a great battery and fits nicely.
Bonadona is offline   Reply With Quote
Xray T2'008 Drew_Cat Electric On-Road 1941 01-25-2016 12:36 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
XRay T3 (spy pics) syndr0me Electric On-Road 33 07-13-2010 04:43 PM
where to get xray?? 2qwik Northwest Racers 20 10-10-2009 03:02 AM
New Xray T3!!! Jammin'Trey Electric On-Road 39 10-09-2009 12:40 PM
