Old 10-09-2010, 08:57 PM   #3136
shikakae123's Avatar
Can tamiya parts be used with T3?
shikakae123 is offline   Reply With Quote
Old 10-09-2010, 09:29 PM   #3137
Still Bill's Avatar
Originally Posted by georgec View Post
What is the advantage to running outboard toe on the rear instead of all inboard?
Potentially allows the rear arms to move more freely on the inner hinge pins. Less binding.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 10-09-2010, 09:34 PM   #3138
Still Bill's Avatar
Some people use Tamiya shocks on their Xrays. Otherwise, the standard parts on the Xray T3are very, very good...Not a lot of options needed for carpet or asphalt.
With the new Xray T3 2011 coming out soon, you should be able to buy a slightly used T3 with some spares for $300-350. A steal.
Bill
Old 10-09-2010, 09:36 PM   #3139
georgec's Avatar
Stands to reason.
georgec is offline   Reply With Quote
Old 10-09-2010, 09:55 PM   #3140
Ok.Thank you all so much for all your help.I decided to get the Xray T3.Thanks
Old 10-09-2010, 10:42 PM   #3141
blade072's Avatar
Trader Rating: 98 (100%+)
best decision i ever made...went from corally to xray....welcome to the team.... you wont be disappointed...
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 10-10-2010, 06:21 AM   #3142
RCknight's Avatar
Default shock o-rings?
Hey guys, I have often used HPI o-rings when I build shocks for super smooth and seem a good balance for wear. Anyone have a o-ring preference? Will HPI 0-rings work in the plastic Xray shocks? Thanks.
RCknight is offline   Reply With Quote
Old 10-10-2010, 09:21 AM   #3143
RC MARKET's Avatar
Originally Posted by blade072 View Post
preordered...
OK arrived first time send to you !
Thanks !
RC MARKET is offline   Reply With Quote
Old 10-10-2010, 09:21 AM   #3144
hanulec's Avatar
Trader Rating: 27 (100%+)
i don't know of anyone who runs other o-rings than the xray 'stock' ones. they do a good job already.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 10-10-2010, 02:20 PM   #3145
The ones in the kit... They are the best shocks Ive ever used/built..
slashman4x4 is offline   Reply With Quote
Old 10-11-2010, 08:40 PM   #3146
Magnet Top's Avatar
Outboard toe makes the car square up on power. Good for open / mod , maybe not so good for stock classes where the driving lines are more rounded to carry speed. This past weekend I used 1 degree outboard toe in Mod, but 0 degree in stock.
Magnet Top is offline   Reply With Quote
Old 10-11-2010, 08:45 PM   #3147
oldrcr's Avatar
Trader Rating: 44 (100%+)
Default Thanks
Hey thanks, someone tried to explain it to me last night, made no sense, this clears it up. Funny that someone else was looking for this same info.
oldrcr is offline   Reply With Quote
Old 10-11-2010, 08:47 PM   #3148
Regional Moderator
CarbonJoe's Avatar
Also, outboard toe (hinge pin hole machined into the upright) reduces the chance for binding. Excessive toe using shims can make the hinge pins bind since the shims are flat. This was more of an issue with the T2 series that didn't have toe machined into the bulkheads.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 10-11-2010, 09:48 PM   #3149
Da4head's Avatar
I just finish building the T3 and now I am trying to get it to ROAR rules weight of 1420 grams. The car is light as it is and now I need to stick on a ton of weight. Anyone have some pics on where to stick all three strips equalling to 84 grams or can they be stuck on the side of the lexan body?.
Da4head is offline   Reply With Quote
Old 10-11-2010, 09:58 PM   #3150
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Definitely don't stick them to the lexan. Flat on the chassis, and arranged to achieve balance is the preferred method.
Xray T2'008 Drew_Cat Electric On-Road 1941 01-25-2016 12:36 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
XRay T3 (spy pics) syndr0me Electric On-Road 33 07-13-2010 04:43 PM
where to get xray?? 2qwik Northwest Racers 20 10-10-2009 03:02 AM
New Xray T3!!! Jammin'Trey Electric On-Road 39 10-09-2009 12:40 PM
