Old 09-20-2010, 11:44 PM   #3091
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Originally Posted by kuruption View Post
Just jumped into this conversation about gear diffs for the T3.
Are you guys running gear diffs in front and rear (carpet racing)?
What diff fluids do you guys recommend starting with?
I race asphalt, but i would recommend 1000-2000 wt oil in the rear, and anything from 150,000 to 500,000 in the front depending on the grip levels and class you run
Antoni
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 09-20-2010, 11:46 PM   #3092
kuruption's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to kuruption
Antoni
150-500k in the front would almost turn the gear diff into a spool (okay, not quite but pretty close) especially compared to the rear of 1000 or 2000. I wonder if it's even worth going to a front gear diff?
Should I also consider ECS driveshafts with a front gear diff, especially given that weight of oil?
Ray Sundland
Eat. Sleep. Race. Repeat.
"Feel not as though it is a sphere we live on, rather an infinite plane which has the illusion of leading yourself back to a point of origin."
kuruption is offline   Reply With Quote
Old 09-20-2010, 11:52 PM   #3093
The gear diff acts like a spool, but will give when under heavy load. I dont use ECS in the front with or without a spool.
Antoni Caretti
Old 09-27-2010, 06:32 AM   #3094
nerdling's Avatar
Does anyone know if there is a difference between the Spec-R diff for the T2009 and the T3? I tried to install a Spec-R Gear Diff in a T3 and it bound on the drive shafts
--XRAY--NOSRAM--PROTOFORM--MUCHMORE--
www.teamxray.com -- www.hudy.net -- www.hobbyexpress.com.au
nerdling is offline   Reply With Quote
Old 09-27-2010, 06:33 AM   #3095
A Ilievski's Avatar
Trader Rating: 39 (100%+)
I think you need to use the shorter shafts on the rear with the spec-r
Alex Ilievski
*INFINITY * R1 WURKS * PLAIG BEARINGS* SPEEDY RC
A Ilievski is offline   Reply With Quote
Old 09-27-2010, 06:35 AM   #3096
kuruption's Avatar
Yeah, I was thinking that he may need to use the 50mm shafts instead of the 52mm. Interesting thing to find out before I buy the diffs myself.
Ray Sundland
Old 09-27-2010, 06:36 AM   #3097
B4james's Avatar
yeah, you need to run the 50mm drive shafts, the only difference between the T3 and 2009 diffs are the pulley teeth size
Hope that helps
Follow me on Facebook - James Ainslie Designs or on Instagram - JA_Designs
*HEI International for Protoform/Proline/Spaz Stix
*Bitty Design Australia for Bodies and Liquid Mask
* Airbrushmegastore.com for all paint and airbrush supplies
B4james is offline   Reply With Quote
Old 09-27-2010, 06:42 AM   #3098
Potoczak's Avatar
Trader Rating: 112 (100%+)
like everybody said you need to use the shorter shafts
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 09-27-2010, 06:47 AM   #3099
Pablo Diablo's Avatar
Send a message via Skype™ to Pablo Diablo
I believe you can use the 52mm shafts if you put 0.75mm shims between the toe blocks.
Paul H
Losi Type R | Xray T3 | CRC Gen XL | CRC Gen X 10 ME(Messiah Edition) | Black Diamond
www.FlyingFoxRC.com | Advanced Electronics | Team CRC | Factory Messiah
Pablo Diablo is offline   Reply With Quote
Old 09-27-2010, 06:57 AM   #3100
nerdling's Avatar
thanks guys.
I did not see where it was said that you had to use the 50mm shafts with the T3 (shrug)
James, I'm pretty sure there is no difference between the factory T2009 and T3 diffs (I swap them all the time) maybe your thinking T2008 US spec?
Pablo, I had shimed the toe blocks by 1mm, I could get it to work but with 0deg camber which would..... not work
cheers
Old 09-27-2010, 07:06 AM   #3101
B4james's Avatar
Unless it has been updated, the kit versions of the two cars were different pulley sizes
the T2009 in kit form was 34 teeth and the T3 is a 38 tooth pulley
Old 09-27-2010, 07:08 AM   #3102
Hey,
Just picked up the t3 EU edition for indoor carpet rubber tire.
Any hop ups I should look into, or is all well from the box?
Losi 8T 2.0 - Novarossi P5 Modded - JR 9100HVS' - Odonnell Fuel -
Mugen MBX6 - Novarossi +4 Modded - Hitec 7940TH's - Hudy Tools
Andy Z is offline   Reply With Quote
Old 09-27-2010, 02:36 PM   #3103
Originally Posted by Andy Z View Post
Hey,
Below are the list of things I run on my XRAY T3: Not all of these things are absolutely neccasary, but good things to have. You will not need any parts from any other car, or any third party brands. Not in any particular order. The XRAY T3 is probably the most complete car from the kit of any sedan I can think of.
1. ECS Driveshafts
2. Springs-The car comes with 3.0 and 2.6. I would recommened purchasing 2.4, 2.8 and 3.2. These will all come in handy for both asphalt and carpet.
3. Optional 1 degree rear hubs-I use these most all the time on my car and are a good option to have.
4. Spur Gears- This is somewhat obvious. For both stock and MOD I usually have: 108,110, 112, and 116 (64 pitch Xray or RW)
5. Anti-Roll Bars-I almost always run the kit bars, but its good to keep some extras. 1.3 for the front is good one to have.
6. Hard front bumper-I run the Xray hard front bumper and have been for close to a year. I know others who use other bumpers, like parma, or cut their own. That's up to you.
7. Spares-You may want some extra front knuckles, C-hubs, and/or arms, but I rarely find myself braking any parts.
Some of these are just good things to have, while not completely needed. Everyone who has an XRAY T3 that I know who have all these parts/options on hand.
Sam
samstheman2 is offline   Reply With Quote
Old 09-28-2010, 01:31 AM   #3104
blade072's Avatar
Trader Rating: 98 (100%+)
ive just started using a ball diff after running a gear diff.....long story short.....still using 50mm shafts....for both ball and gear diff......
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 10-01-2010, 10:11 AM   #3105
mok
mok's Avatar
Send a message via MSN to mok Send a message via Skype™ to mok
http://www.redrc.net/2010/10/xray-t3...ar/#more-35853
w00t!
XRAY T3'2011 / TEKIN RS PRO / LRP X12 / HYPERION SWIFT G3 RACE PACKS / FUTABA S9551 / SPEKTRUM DX3R
www.epracer.com - www.precc.org.au - www.westcoastmodelrallyclub.asn.au - www.onroadrccarclubbunbury.org.au
mok is offline   Reply With Quote
Xray T2'008 Drew_Cat Electric On-Road 1941 01-25-2016 12:36 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
XRay T3 (spy pics) syndr0me Electric On-Road 33 07-13-2010 04:43 PM
where to get xray?? 2qwik Northwest Racers 20 10-10-2009 03:02 AM
New Xray T3!!! Jammin'Trey Electric On-Road 39 10-09-2009 12:40 PM
