Old 09-06-2010, 03:19 PM   #2971
Will27's Avatar
^Foxit PDF reader will let you save it as well.
Will27 is offline   Reply With Quote
Old 09-06-2010, 05:39 PM   #2972
Skiddins's Avatar
Originally Posted by Hurrle View Post
Found an easier way with a tips from Skiddins.
Download CutePDF Form Filler which let you save the information you enter in Xray's setup sheet. This does the exact job I wanted.
Thank you Skiddins!
No problem.
My post appears to have been deleted
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 09-07-2010, 04:45 AM   #2973
RCknight's Avatar
Default Any new on the new Xray car?
I know it comes out in Oct. but when late Oct? The TC6 is looking good with those nice new aluminum shocks that are Teflon coated. I hope Xray does something to up the bar.
RCknight is offline   Reply With Quote
Old 09-07-2010, 10:51 AM   #2974
spyder8c's Avatar
Hey guys I just picked up a used 008 EU and in testing it out i just can't find rear traction in corner exit on throttle. I didnt get any spare parts so i have it as is from the dude i bought it from. i've been making changes trying to get it to basic asphalt setup, but this is how it sits
1deg toe out in the front
1.5 camber f+r
ride height 5mm f+r
droop 5mm f+r
diff's both up
quick rolls all up and in
springs 2.8 front, schumacher white rear (14lb). came with 2.8, 3.0
but where i thought the problem is, is the lower arm holders which are
front are both -.75 and rear is in the anti squat(low rc) position.
I didnt want to revive the year old 008 thread, so i figured i would ask on this one. Any help would be appreciated, thanks
spyder8c is offline   Reply With Quote
Old 09-07-2010, 11:08 AM   #2975
JayL's Avatar
post on the 08 thread because the t3 has massive rear grip, we only know how to get rid of it
JayL is offline   Reply With Quote
Old 09-07-2010, 11:18 AM   #2976
spyder8c's Avatar
Ok, will do. thanks
Old 09-07-2010, 11:22 AM   #2977
Slideaway's Avatar
1deg toe out in the front OK
1.5 camber f+r 2F 2.5 R
ride height 5mm f+r OK
droop 5mm f+r 6 F 5 R (under arms)
diff's both up Front spool and good conditions diff
quick rolls all up and in OK
springs 2.8 front, schumacher white rear (14lb). HPI GOLD F SILVER R
WITH 400 CST OIL 3 holes (1.1mm)
lower arm holders USE the 0 one every where
Ludo
Thai Ride Tech Support.
Slideaway is offline   Reply With Quote
Old 09-07-2010, 12:42 PM   #2978
1.5 camber f+r
ride height 5mm f+r
droop 5mm f+r
diff's both up
if you look on the Xray forum there is loads of setups on there for all the Xray cars
sidecarphil1 is offline   Reply With Quote
Old 09-07-2010, 02:09 PM   #2979
spyder8c's Avatar
K cool, i'll give this a try. also what tires/inserts would you recommend for low grip asphalt? i'm currently running sorex 24r's with ofna jl10 inserts. i didnt know if this might be contributing at all to my problem.
Hey thanks, i didn't realise there were that many setups there.
Old 09-07-2010, 02:40 PM   #2980
MikeXray's Avatar
Trader Rating: 73 (100%+)
well before you praise AE, they haven't built a shock that doesn't leak yet, so what makes you think this is any different, lol.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 09-07-2010, 04:00 PM   #2981
Tag
Tag's Avatar
Trader Rating: 31 (100%+)
i am looking to buy turnbuckle wrench for my T3 , i notice it comes in 2 different sizes ( 3mm and 4mm ) just went through the whole manual and not a place mentioned anything about turnbuckle size , does anyone know what size of wrench should i get ? and will this also work with NT1 turnbuckles ?
thanks for help guys
* Serpent 966 TE Novarossi 35+21, Airtronics M12 *
Tag is offline   Reply With Quote
Old 09-07-2010, 04:05 PM   #2982
Impulse_racer's Avatar
You need the 4mm. Nexusracing.com has the Hudy 4mm turnbuckle wrench. I think MuchMore also makes a 4mm wrench.
Xray T3 EU
KO Propo Helios
Tekin RS Pro/LRP X-12/Venom LiPo
Hudy
Litemodz CVS
Impulse_racer is offline   Reply With Quote
Old 09-07-2010, 04:23 PM   #2983
Tag
Tag's Avatar
thanks for the help i will get the 4mm , but just wondering what's 3mm used for ? if this is something that i need i might as well get it the same time.
Old 09-07-2010, 04:37 PM   #2984
RC MARKET's Avatar
later !
RC MARKET is offline   Reply With Quote
Old 09-07-2010, 05:06 PM   #2985
TeamB&B's Avatar
It is good to get both the 3mm and 4mm turnbuckle wrenches. XRAY went from 3mm to 4mm turnbuckles when they went from HUDY spring steel to black aluminum turnbuckles. The small turnbuckle for the steering servo is still 3mm.
It is also good to keep a 3mm wrench in the toolbox in case you have to replace a bent or broken turnbuckle with an easy to find 3mm spring steel one.
We replaced the steering arm aluminum turnbuckles with titanium ones. These are usually the first casualty when running mod.
RCAmerica / Sweep
TeamB&B is offline   Reply With Quote
Xray T2'008 Drew_Cat Electric On-Road 1941 01-25-2016 12:36 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
XRay T3 (spy pics) syndr0me Electric On-Road 33 07-13-2010 04:43 PM
where to get xray?? 2qwik Northwest Racers 20 10-10-2009 03:02 AM
New Xray T3!!! Jammin'Trey Electric On-Road 39 10-09-2009 12:40 PM
