Old 08-24-2010, 11:25 AM   #2911
Trader Rating: 27 (100%+)
Got some money to spend. In between the spec r shafts or the gear diff. What would be a better first upgrade? Planning on getting them both at one point.
Alex B
Kyosho America/Byron Fuels/J concepts
For all your painting needs!
Elite Paint Workz
[email protected]
mist467 is offline   Reply With Quote
Old 08-24-2010, 02:48 PM   #2912
whityboy's Avatar
For the gear diff you need short drive shafts (50mm). Or you could put 2mm shims between the suspension holders and the bulkheads. if you have these I would go for a gear diff. Or even better get some ECS drive shafts. In my opinion one of the best upgrade parts
whityboy is offline   Reply With Quote
Old 08-24-2010, 03:24 PM   #2913
So the spec r gear diff does not work in the rear unless you buy different shafts? I had understood it was complete drop in.
Alex B
Elite Paint Workz
[email protected]
Old 08-24-2010, 04:33 PM   #2914
LOL. Don't worry about 50mm driveshafts. In fact, forget the Spec-r diff altogether. In my humble opinion, I think its overrated. On low grip tracks, I think its harder to drive. Whenever I put the ball diff back in the car, (with a free, non slip well maintained one of course) the car performs better. I've tried different oils 150 - 2000 and i've ended up removing it.
maxg123456 is offline   Reply With Quote
Old 08-24-2010, 06:08 PM   #2915
This is probably a dumb question. Do you guys adjust wheel base in the front and rear of the car or just the rear? And if you are adjusting in the front for a shorter wheel base, do you shim in the front or rear of the front A-arm?
Thanks.
bdortch is offline   Reply With Quote
Old 08-24-2010, 06:14 PM   #2916
Skiddins's Avatar
Thanks.
I've only ever changed the rear.
On the 009 I used to be able to run 1mm in front of the rear wishbones quite often, but on the T3 it almost always makes it more unstable so I stick with the kit 2mm.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 08-24-2010, 06:59 PM   #2917
Still Bill's Avatar
Default 92T spur gear?
Has anyone run the Xray 92T offset spur gear in their T3? Can you get to the rear screw to tighten the motor in place? Or do you have to do something special? Thanks. Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 08-25-2010, 10:06 AM   #2918
JayL's Avatar
lol Bill, I have been running the lunsford motor screws that use a 2.5mm and a ballend wrench reminds me of nitro
JayL is offline   Reply With Quote
Old 08-25-2010, 12:24 PM   #2919
Hey all. What is everyone running for pistons? Are you guys using the adjustable or standard. I am using the adjustable pistons but feel like they are a lil inconsistent sometimes.
Alex B
Elite Paint Workz
[email protected]
Old 08-25-2010, 01:45 PM   #2920
Send a message via AIM to goop
fixed pistons always
Hurricane Motorsports
Team Trinity
TOP Racing - Gravity Rc - Contact tires - KO Propo - Competition Electronics
goop is offline   Reply With Quote
Old 08-25-2010, 05:23 PM   #2921
PinoyCali's Avatar
Default Shock oil???
Hello..
What is the good shock oil set up F/R and springs.
Thanks..
PinoyCali is offline   Reply With Quote
Old 08-25-2010, 05:47 PM   #2922
Skiddins's Avatar
Originally Posted by PinoyCali View Post
Hello..
Thanks..
The kit 350cSt is a good starting point, but it will all depend on the track etc.
Skiddins
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 08-25-2010, 05:50 PM   #2923
PDX-Spike's Avatar
Hello..
Thanks..
Need MUCH much information.
Roger Christal - Team Timezone (Hooligans), Rose City Scale Racing, ROAR Member until 9/16/2012
Support the locals: Timezone Raceway, Timezone II, R/C Plus, Portland RC Raceway
McKune Design, Slapmaster Tools, Houston's Engine Service
PDX-Spike is offline   Reply With Quote
Old 08-25-2010, 07:40 PM   #2924
Still Bill's Avatar
Ah ha! Got both. Thanks.
Old 08-25-2010, 11:30 PM   #2925
PinoyCali's Avatar
Sorry im new to onroad
Xray T2'008 Drew_Cat Electric On-Road 1941 01-25-2016 12:36 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
XRay T3 (spy pics) syndr0me Electric On-Road 33 07-13-2010 04:43 PM
where to get xray?? 2qwik Northwest Racers 20 10-10-2009 03:02 AM
New Xray T3!!! Jammin'Trey Electric On-Road 39 10-09-2009 12:40 PM
