XRAY T3
Old 08-21-2010, 10:58 AM
  #2866
Anyone got an idea whether is Xray coming out with a new car soon? Maybe with a gear diff???
Racer18 is offline
Old 08-21-2010, 12:47 PM
  #2867
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
Originally Posted by Still Bill
Any suggestions for a good TC 17.5 setup to use for the no timing stock class at the IIC? We will be on Jaco Blues.
Thanks.
Originally Posted by EAMotorsports
Hey Bill,
I would try Mike Hanulec's setup from there last year. His car was awesome though it was a 009. He has some setups for the T3 on xray's site as well from this year's birds that are very good as well!
EA
Thanks EA! My T2'008 was really good last year... and that setup is posted online. That setup leveraged a high amount of rear toe and near zero rear camber change. My XRay Forum user is 'racerlog'. I have two setups that I'll be trying this year... an old one from January 2010 Snowbirds (http://forum.teamxray.com/xform/inde...=1263&setup=t3) and my latest thoughts from what I learned this summer outdoors (http://forum.teamxray.com/xform/inde...=1727&setup=t3)
hanulec is offline
Old 08-21-2010, 01:46 PM
  #2868
yodace's Avatar
what do the different degree of rear hubs do for the T3?
yodace is offline
Old 08-21-2010, 05:02 PM
  #2869
shesha's Avatar
increases your toe in range more
shesha is offline
Old 08-21-2010, 10:54 PM
  #2870
Trader Rating: 16 (100%+)
Hey Bill,
EA
Thank you Mr. A. See you in a couple...
And thanks to Mike for the additional info...I found em.
Bill
Still Bill is offline
Old 08-22-2010, 05:34 PM
  #2871
shesha's Avatar
Hanulec and Ark thanks for all the help, tips and recommendations on the T3, the car is perfect now with the caster 6 and back on the kickup, just need to try the steering post recommendation and see what that does but cant ask for anymore from the car.
Hell some of the other drivers tested out the final setup and managed to improve their laps and time overall.
As for me, today was not a good day, just could not concentrate, to many minds as they say in my head today way to many mistakes and crashes that just never happened previously.
Guess everyone has their day mine was today
Hopefully tomorrow I will be in the zone
shesha is offline
Old 08-22-2010, 05:48 PM
  #2872
hanulec's Avatar
Shesha - good work. Sometimes I can only put together a hot lap or two... you have to save up the no blow out skillz for when it matters.
hanulec is offline
Old 08-22-2010, 05:56 PM
  #2873
shesha's Avatar
hanulec, yeah bro... +1 on that statement.
Have the WC 1/8 offroad coming in thailand, hope this jinx today does not set on me there.....
Heres the final setup sheet for anyone interested to run on medium to high traction carpet and technical track.
http://forum.teamxray.com/xform/inde...=1715&setup=t3
shesha is offline
Old 08-22-2010, 06:38 PM
  #2874
hanulec's Avatar
Good luck at the WC.
As for bad racing days... I race weekly with Jason Schreffler and the week prior to Snowbirds 2010 he ran really poorly -- I beat him . Thankfully he bounced back winning 13.5 rubber and having an excellent 2nd in 10.5 1/12th. Dreams can come true....
hanulec is offline
Old 08-22-2010, 08:02 PM
  #2875
KWT-NITRO's Avatar
OKAY
i will admit it, your final set-up is great
thank you guys helping Shesha with his set-up that was originally my set-up that was originally Paul lemieux's set-up
drove my T3 eater today and set the fastest lap on the track and also my personal best by 5 seconds and best lap time by 0.2s.
thank you all for making me beat all those T3s around me with my cheap T2R Pro
cheers
Ali
KWT-NITRO is offline
Old 08-23-2010, 10:23 AM
  #2876
Iīve broken my two days old T3 chassis it break in nimh - hole completely.. Is it possible to repair it some way, or is it better to get a new one? It is pretty expensive as iīve already spend too much for T3, but it is my fault..
Or what do you guyz say on aftermarket Exotek XR3 chassis? It is little cheaper then OEM and it should improve handling of Xray?
http://www.exotekracing.com/EXOTEK_N.../4/12_XR3.html
Martyn666 is offline
Old 08-23-2010, 10:28 AM
  #2877
i personally didn't like the Exotech chassis
I didn't like the way the battery was held
So i made my own
It was really easy and cheap , the 2mm carbon sheet cost me 40 euros and about 3 hrs work ,
not the best finish on the edge but works well
sidecarphil1 is offline
Old 08-23-2010, 10:39 AM
  #2878
Wow thatīs interesting, looks good, how does that perform? And do you have some whiteprints plans for OEM chassis? Or would you mind make some step by step how-to manual? I think that more users will be interested.. Thanks a lot for information..
Old 08-23-2010, 10:59 AM
  #2879
it drives good
The problem with the stock chassis is the battery side is 10mm wider then the motor side and the stock chassis is 2.5mm thick
I wanted a 2.0mm chassis and after speaking with Paul Lemieux i decided to build my own
Start of with the balance pin holes , drill them out with a 2mm drill hole then put an M2 bolt and nut through them then scribe the motor side of the chassis , turn the original chassis over and trace the motor side again so you have an equal left right chassis
Then cut it out with a Dremmel , cuttin out only the holes you need , diff,spool, and battery tape holes
Then drill out the holes for ONLY the hole you need this will give better control of flex , use a 3mm drill for this
Then countersink , this is where i made a silly mistake and drilled a hole too big when the countersink drill snatched the chassis from my hands
i used a piller drill for the holes , to make sure the holes were straight through the chassis , drilling through the original chassis
then for the motor resess i set the piller drill platform at 1mm below the side drill bit then mark the chassis where you want the motor resess then carefully cut away
chassis made
Old 08-23-2010, 12:09 PM
  #2880
Team EAM
Trader Rating: 79 (100%+)
I just got to run my Exotek chassis for the first time this weekend. It ran very well for me on our low bite track. It balanced very good and did not have to add any weights with a 17.5 motor to get it balanced....just the stock ones it comes with. The battery tape part of it takes a little getting used to but it works awesome once you learn how to run the tape and use it. 1 piece will probably last all week at the IIC!! LOL
EA
EAMotorsports is offline
