Old 08-20-2010, 07:00 AM   #2851
hanulec's Avatar
Trader Rating: 27 (100%+)
Originally Posted by shesha View Post
Finally, managed to get round to some more practice last night, what a session, came to a perfect drivin setup for my likin.
http://forum.teamxray.com/xform/inde...=1715&setup=t3
Plenty of steering onpower and offpower and the rear end is really planted.
What you guys recommended on the QRC being one is spot on, the extra front width in the front helped alot.
Shesha - i'm happy you've made progress with your setup. i think there is two more things you should try when you can..
#1 moving the inner ackerman post forward on the chassis. in this setting you will have less overall ackerman, but your ackerman settings will be more fine grained
#2 experiment with lowering the front arm mounts. you don't have to move both arm mounts at once, you could say lower the front arm mount and that would generate anti-dive --- something that could be very helpful when running such a high horsepower motor as you are.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 08-20-2010, 10:53 AM   #2852
KWT-NITRO's Avatar
do you call 20 hours on the track A SESSION?? more like a Le Mans 24H Race
Team Kuwait, Team Terribles, www.rccck.org
Kuwait National Champion
FEMCA Truggy Finalist & FEMCA Buggy Semi-Finalist
Thanks to all my sponsors: Modelix/Ultimate Racing, AKA Racing, AVID Racing, Stick-it1 Racing and HES
KWT-NITRO is offline   Reply With Quote
Old 08-20-2010, 11:55 AM   #2853
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
I agree with hanulec anti dive works really well in mod. And the forward post as well, two things I always run!
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 08-20-2010, 11:57 AM   #2854
KWT-NITRO's Avatar
i already have the forword post on my T2 but how will the anti dive help when running MOD?? when you say anti dive, front arm angeled toward the rear or front?? which side is lower?? i guess rear is lower??
Old 08-20-2010, 02:04 PM   #2855
hanulec's Avatar
T2 forward post != T3 forward post. I think T3 forward post == T2 rear post. I always ran my T2 w/ the rear post.
Anyway -- anti-dive will help the car from compressing the front suspension so quickly when you get on the brakes. I found it to be necessary when going from 13.5T to basically anything quicker. Also, w/ the T3 you don't have to just use the default +/- 0.75mm options, you can use shims to get less than 0.75mm pin height differences.
Old 08-20-2010, 07:14 PM   #2856
shesha's Avatar
Send a message via MSN to shesha
Hanulec, am not sure about what you are referring to the ackerman post forward, you mean the plastic piece that slides back and forth from setting 1 to 5 or are you referring to the plastic which the bearings seat in?
I did not touch the post since I was not sure, but played with the antidive, my car initiall before setting up antidive was lacking a bit of on power steering, so when I put in antidive on the front being front plastic piece at 0 degree and rear +0.75 it felt really nice on the corner entry and very comfortable you can see the change on the first lap and corners.
however having lost the steering on mid corner and exit, i switched out the plastic to reverse the process and went with pro-kickup, it was perfect, but then you lost the previous effect but still it was good with the on-power steering which gave me just the right amount.
I could go back to the anti-dive and work on the onpower steering with some other feature on the car to compensate.
R.C.C.C.K - Team Kuwait
shesha is offline   Reply With Quote
Old 08-20-2010, 07:17 PM   #2857
shesha's Avatar
Antdive means the front arms are leaning downwards , rear is higher.
Example front at 0 and rear at +0.75 or -0.75 front and rear 0
Like hanulec said it really keeps the car balanced when you hit the brakes, front end does not squat down.
Old 08-20-2010, 07:20 PM   #2858
shesha's Avatar
I needed to sort out my sleep it's $ucked up, so might as well stay awake on something i can concentrate on.
FYI try the 36LS tires they are better than the 36PP
Old 08-20-2010, 07:33 PM   #2859
I may have missed this mentioned else where but if you're currently @ 4deg caster, go back to anti-dive then change to 6deg caster blocks to get your mid and exit steering back.
g26er is offline   Reply With Quote
Old 08-20-2010, 07:37 PM   #2860
shesha's Avatar
Yup u are right, but i dont have the 6 degree caster blocks, the other guys finished them off from the shop and we are out of stock, till they are back in stock.
I know particular guy went through 4 of them in one session...
Old 08-20-2010, 07:57 PM   #2861
hanulec's Avatar
yes - im talking about the plastic that holds the bearing in the chassis and top deck.
i'd give anti-dive another try, but this time w/ 6 degree c-hubs. i think that will be the hot modified setup. you might be able to not do the 6 degree c-hubs if your running a lot of camber gain in the front or really stiff springs (have you tried past a 3.0 in the front yet... if not, please do).
Old 08-20-2010, 08:07 PM   #2862
shesha's Avatar
Think I will beg tomorrow on the track for 6 degs of caster, am sure it will be the cherry topping on the setup.
It feels so nice as it is, will play with the plastic bearings seats and see how that goes once i get my hands on the 6 deg caster blocks.
Old 08-20-2010, 08:45 PM   #2863
ark
Shesha try change your front droop value from 5 to 6
ark is offline   Reply With Quote
Old 08-21-2010, 12:06 AM   #2864
Still Bill's Avatar
Any suggestions for a good TC 17.5 setup to use for the no timing stock class at the IIC? We will be on Jaco Blues.
Thanks.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 08-21-2010, 05:52 AM   #2865
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Thanks.
Hey Bill,
I would try Mike Hanulec's setup from there last year. His car was awesome though it was a 009. He has some setups for the T3 on xray's site as well from this year's birds that are very good as well!
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Xray T2'008 Drew_Cat Electric On-Road 1941 01-25-2016 12:36 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
XRay T3 (spy pics) syndr0me Electric On-Road 33 07-13-2010 04:43 PM
where to get xray?? 2qwik Northwest Racers 20 10-10-2009 03:02 AM
New Xray T3!!! Jammin'Trey Electric On-Road 39 10-09-2009 12:40 PM
