Old 08-17-2010, 09:33 AM   #2836
gonzo416's Avatar
Trader Rating: 39 (98%+)
Originally Posted by Still Bill View Post
Initially, I used a Futaba 9551 low profile servo because it served me well with my Corally cars. Great value and durable!
But, considering the left front is the lightest corner of the T3, I switched to a heavier full-sized servo. The fast JR9000 is what I use now. Easy to balance car at all four corners.
Bill
How do you go about balancing the T3? I I had to add a lot of weight just to get it balanced right to left and I have no clue how to balance it front to back. I had to add the weight to the top deck because I'm trying to find a way to add weight to the chassis. Can you post a pic of yours?
gonzo416 is offline   Reply With Quote
Old 08-17-2010, 04:01 PM   #2837
Slideaway's Avatar
How many g do you have to add ?
It mostly depends on your electronics/motor installation but you should not put more than 30g to reach 1400g (depending on the class you race in).
I usually add this extra weight on the inner side wall of the battery.
Don't put anything on the top deck, you don't want to rise up the global CG.
About front/rear balance, it's up to your preferences. The car may be easier to drive if the weight in more forward (a bit push) and a bit (slightly) oversteer in more backward.
Ludo
Thai Ride Tech Support.
Slideaway is offline   Reply With Quote
Old 08-17-2010, 06:57 PM   #2838
Trader Rating: 27 (100%+)
looking into getting the ecs shafts. Are the spec r shafts comparable? They are half the price and im planning on ordering the gear diff this week. Just dont want to spend the 50.00 bucks and then end up getting the ecs shafts later on.
Alex B
Kyosho America/Byron Fuels/J concepts
For all your painting needs!
Elite Paint Workz
[email protected]
mist467 is offline   Reply With Quote
Old 08-17-2010, 07:17 PM   #2839
Pablo Diablo's Avatar
Send a message via Skype™ to Pablo Diablo
I know someone who uses them and have seen them pulled apart into their separate pieces and believe they are very good quality parts.
Paul H
Losi Type R | Xray T3 | CRC Gen XL | CRC Gen X 10 ME(Messiah Edition) | Black Diamond
www.FlyingFoxRC.com | Advanced Electronics | Team CRC | Factory Messiah
Pablo Diablo is offline   Reply With Quote
Old 08-17-2010, 07:32 PM   #2840
Trader Rating: 38 (100%+)
Someone please buy my T3 before I change my mind and keep it!
http://www.rctech.net/forum/r-c-item...are-parts.html
or8ital is offline   Reply With Quote
Old 08-17-2010, 07:37 PM   #2841
JayBee's Avatar
Trader Rating: 31 (100%+)
I want to buddy but I prolly more than likely getting the revised T3 as my second car....
SWEET DEAL though
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 08-17-2010, 07:44 PM   #2842
Still 2 more months until that comes out, I suspect. Make me an offer.
Old 08-17-2010, 08:50 PM   #2843
hanulec's Avatar
the weakest part of the Atomic/Spec-R drive shafts are the pins. if you replace them with XRay ECS pins or make your own using stock from a hobby store you should be good to go. The XRay items are pricey, but if you maintain them they will last for over a year--- at least that is as long as i've had them.
-mike
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 08-17-2010, 10:12 PM   #2844
Slideaway's Avatar
Here, on rubber/asphalt use, people use original Xray ECS if they run mod or wind up to 10.5t. Some of them experienced failures of the SpecR ones with this huge amount of torque.
Motor wind higher than 11.5t should not meet any trouble.
Ludo
Old 08-17-2010, 11:28 PM   #2845
Still Bill's Avatar
gonzo,
My T3 is currently stripped and being rebuilt for the IIC carpet at the new minimum weight of 1400 grams. That's 20 grams less than what I was doing for ROAR rules; so, some weight distribution changes are pending.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 08-18-2010, 02:05 AM   #2846
Has anyone tested the Spec-R 38T geardiff on Xray t2 007?
Zooberg is offline   Reply With Quote
Old 08-18-2010, 02:26 AM   #2847
The 007 has different pulley offsets and I would expect that the belt won't line up with the pulley.
Paul H
Old 08-18-2010, 02:30 AM   #2848
Benzaah's Avatar
Trader Rating: 21 (96%+)
Originally Posted by spike8625 View Post
has anyone here tried the smokem t3lp chassis as yet how does it feels
If your running on medium to high traction I would recommend the smokem chassis as it really makes the car come alive and has s lot more corner speed and ability to change direction quicker. I have found on low grip surfaces there is no difference between the standard chassis so would not be worth the upgrade if that's what you race on
Adelaide RC - XRAY Xb216de & Xb416
Walter Rc Hobby - Serpent 4X
Nosram - R1wurks - Sanwa - Hudy - Muchmore
Benzaah is offline   Reply With Quote
Old 08-19-2010, 06:55 AM   #2849
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
In alot of cases the user has a big part in whether something will work or not. I use the spec r driveshafts, one year old with the 52mm xray ecs shafts which were already second.
I had them come apart once when I tried to use only heatshrink to hold the pins in. The trick to making them bullet proof is assemble them with loctite when they are new and never disassemble them. The clean them use brake/motor cleaner and apply grease with a fine tip paint brush.
And that is with a 4.5 brushless
dontfeelcold is offline   Reply With Quote
Old 08-20-2010, 04:38 AM   #2850
shesha's Avatar
Send a message via MSN to shesha
Finally, managed to get round to some more practice last night, what a session, came to a perfect drivin setup for my likin.
http://forum.teamxray.com/xform/inde...=1715&setup=t3
Plenty of steering onpower and offpower and the rear end is really planted.
What you guys recommended on the QRC being one is spot on, the extra front width in the front helped alot.
R.C.C.C.K - Team Kuwait
shesha is offline   Reply With Quote
Xray T2'008 Drew_Cat Electric On-Road 1941 01-25-2016 12:36 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
XRay T3 (spy pics) syndr0me Electric On-Road 33 07-13-2010 04:43 PM
where to get xray?? 2qwik Northwest Racers 20 10-10-2009 03:02 AM
New Xray T3!!! Jammin'Trey Electric On-Road 39 10-09-2009 12:40 PM
