XRAY T3
#2821
time will tell....
#2825
has anyone here tried the smokem t3lp chassis as yet how does it feels
#2826
Yes no problem, the T2008 was originally fitted with 4 steel drive shafts before the Alu ones came by as an option and standard on the T2009/T3
#2827
What's the best servo to use in a T3 for racing? I have just purchased one second hand and the manual says to use a "narrow light servo" whats a good high speed one.
#2829
Any low profile (or narrow profile) is fine:
- KO PDS 2413 ICS
- Futaba s9550 or S9551 (s9551 got a bit more torque)
- Sanwa SDX 801.
- Team Orion Vortex Servo VDS 1007.
- KO PDS 2413 ICS
- Sanwa SDX 801.
#2831
Savox 1257
#2832
But, considering the left front is the lightest corner of the T3, I switched to a heavier full-sized servo. The fast JR9000 is what I use now. Easy to balance car at all four corners.
Bill
#2833
Initially, I used a Futaba 9551 low profile servo because it served me well with my Corally cars. Great value and durable!
Bill
Bill
#2834
That's what I'm running atm Cristian. Have a look / run of my car in SA if you want to see what it's like. It's no different really. But I should have the litemodz shafts by then.
#2835
Weird thing after 1 run of slapping on new rear Alum shafts the pin where the plastic caps go on came coming loose, as after the run I noticed the pin was nearly all the way out, surprised it lasted like that for a whole run.
