Old 08-10-2010, 10:59 AM   #2776
Fred Hubbard's Avatar
Just wanted to let you all know of a couple of products that are available. Check them out! If you do decide to give them a try please tell them that I sent you so that they know where the info came from. Thanks!
RC Halt Aluminum T3 Battery holders & T2/T3 Titanium Layshaft
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 08-10-2010, 11:10 AM   #2777
Way2Evl's Avatar
Originally Posted by hanulec View Post
Shesha - im happy I could help. disconnect that front swaybar and try quick roll center position #1 up front. The car will roll less, but disconnecting the bar should remove the push. If not... go to a heavy front spring too.
I don't know much, but shouldn't he try removing his front steering post to get rid of push?
X-Ray T3|Tekin|KO Propo|Spektrum|Thunder Power|Hyperion|Sorex
www.speedworldraceway.com
Way2Evl is offline   Reply With Quote
Old 08-10-2010, 11:38 AM   #2778
One thing that gets me confused is the differing opinions of what helps eliminate understeer/oversteer. I would've thought stiffer front springs would give more push?
maxg123456 is offline   Reply With Quote
Old 08-10-2010, 12:22 PM   #2779
hanulec's Avatar
Trader Rating: 27 (100%+)
Rubber tire is a different animal some times. Forcing the tire into the ground often helps. Overtime you start to pick up on if the car is rolling too much or not enough. And the painful trial and error method sometimes is the best way of figuring things out
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 08-10-2010, 12:50 PM   #2780
JayL's Avatar
we really need to be clear what we are advising
foam
rubber
carpet
ashpalt
as all 4 work differently, something that works on asphalt won't necessarily work on carpet, etc.....
JayL is offline   Reply With Quote
Old 08-10-2010, 01:00 PM   #2781
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
It depends, a stiff spring can cause the front tires to over heat a few mins into the race which will make your car push
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 08-10-2010, 03:29 PM   #2782
DS Motorsport's Avatar
Default Battery wire routing
I want to ask you guys how to route the battery wires on my T3.
It's the first time I'm building and wiring an electric car and I can't figure out how to route it like I've seen on the redrc pictures and such.
Most have the wires running beneath the top deck, but on my car there is absolutely no room for that with the lipo stops in place.
Is this because of the battery, it's a IP 5000.
Here are some pictures:
I don't like routing it across the top deck because of the drive belt, I'm afraid it will start to rub and may cause shorting the electronics.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 08-10-2010, 03:33 PM   #2783
Phil C's Avatar
Route the battery wires above the belt, keep them long enough so they loop over the top and you wont have any issues. Thats how I run mine
| Team XRAY UK | HUDY | RC DisCo| LRP | Sanwa | SMD | Moorespeed | MB Models | Gingapaint | McLaren Racing |
Phil C is offline   Reply With Quote
Old 08-10-2010, 03:52 PM   #2784
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
Like this.
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 08-10-2010, 04:16 PM   #2785
Hahaha Mike to bad thats two different chassis and layouts.
Anyhow unless you have your battery pushed out, on the stock chassis I used the nimh plastic cell plastic pieces and it will make your battery be on the edge of the chassis. I run my battery that way so you dont need weight to balance the car, or not as much. And your wires will fit inbetween the top deck and battery
Hope that helps
Old 08-10-2010, 04:34 PM   #2786
Ok, thanks for the help guys, will try to move the battery more outward to create a bit more space for the wiring.
And then add the weight to the middle of the car to get it up to 1350 gr.
As a last resort I can always route the wires over the top deck.
P1-RC.com
Old 08-10-2010, 04:35 PM   #2787
Default Routing wires
I route the wires over the belt but I made a Lexan right angle (bodyshell offcut) about two inches long and superglued it to the top deck.
regards
Don
donwhit is offline   Reply With Quote
Old 08-10-2010, 06:10 PM   #2788
casino57's Avatar
Xray makes weights that move the battery off the chassis alittle father. This is what you need. You need to move the battery out as far off the right side of the chassis.No need for weights in the middle of the car. Make sure wires are long enough to go over the belts...you'll be glad you did. Also try the gear diff made for it. Will give you more acceleration and more steering too. GL
Mike Garcia - RCAmerica - XRay T3
Trinity - JDR - Hudy - KoPropo America
Laser Products - Tekin
Leisure Hours Raceway & Hobby Shop
casino57 is offline   Reply With Quote
Old 08-10-2010, 06:42 PM   #2789
shesha's Avatar
Send a message via MSN to shesha
Okay figured the push subject out, it was not so much the push it was the steering locking out.
I put the ackerman back to one, then worked my epa on the steering to have a constant arc from off throttle to on throttle so there is little difference.
The final touch came down to some body testing, and traction compound.
add3/4 instead of 1/2 in the front, then switched out from the team titan altis body to a mazda 6 team titan which was better, then finally switched to a mazda 3 also team titan which had a longer body, the perfect body for the track.
Managed 26 laps finally in 5:11 with 3 mistakes in the run, and some over shooting in the sweepers. 11.9
I think 27 is manageable with some more practice time on the track.
Current racers have achieved this so have to catch up on them....
Best Record was 27 laps in 5:02
Best time was 10.9
Here is the updated setup sheet
http://forum.teamxray.com/xform/inde...=1713&setup=t3
R.C.C.C.K - Team Kuwait
shesha is offline   Reply With Quote
Old 08-10-2010, 08:41 PM   #2790
Trying to go the gear diff route and try it out. Whats the best option. Spec R or is there something better out there?? Whats everything i need for the conversion? Been looking around but i am lil confused. Thanks guys
Alex B
Kyosho America/Byron Fuels/J concepts
For all your painting needs!
Elite Paint Workz
[email protected]
mist467 is offline   Reply With Quote
Xray T2'008 Drew_Cat Electric On-Road 1941 01-25-2016 12:36 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
XRay T3 (spy pics) syndr0me Electric On-Road 33 07-13-2010 04:43 PM
where to get xray?? 2qwik Northwest Racers 20 10-10-2009 03:02 AM
New Xray T3!!! Jammin'Trey Electric On-Road 39 10-09-2009 12:40 PM
