Old 07-27-2010, 04:15 PM   #2686
shesha's Avatar
Send a message via MSN to shesha
Originally Posted by jammincrtjames View Post
1.9
thx
R.C.C.C.K - Team Kuwait
shesha is offline   Reply With Quote
Old 07-27-2010, 04:59 PM   #2687
Way2Evl's Avatar
Originally Posted by BlackedOutREVO View Post
Honestly I dont know I mixed some oils around, and because I used only two spider gears instead of four I had to use thicker oil. This weekend I am going to try with 1500 or 2000 to see what its like. I think 1500 will be like 1000 with four gears. And the chassis didnt seem much different really, just corner speed because nothing rubs the ground now, same with the gear diff too lol I can hammer the throttle and rip out of a corner but theres no point because id have to slam the brakes for the next, just no more rebuilds
Why did you decide to use 2 spider gears instead of four? I'm going to have to try that with the shimming the motor mount because I put the two rear chassis post back in and I'm still scrubbing my motor. Did you put anything under the motor to help prop it up after shimming it up?
X-Ray T3|Tekin|KO Propo|Spektrum|Thunder Power|Hyperion|Sorex
www.speedworldraceway.com
Way2Evl is offline   Reply With Quote
Old 07-27-2010, 05:25 PM   #2688
JayL's Avatar
we are going to rub on the left no matter what, it's the sweeper. Raising everything so it doesn't rub is not going to help laptimes..... Marc did it because he was scrubbing almost EVERY corner. It's not something you do for a one corner sweeper
I also think it will be easier to tweak the topdeck with those shims
1000cst is perfect in the diff for our amount of traction with 4 gears. 2 gears is more for spec trying to save weight, it is less consistent
JayL is offline   Reply With Quote
Old 07-27-2010, 05:38 PM   #2689
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Its just lighter because I used the metal gears is all. And nope just put a 1mm shim under the motor mount and layshaft bulk, and that little piece that connects the motor mount to the chassis
I dont know about you man, but my motor and chassis were really rubbing the ground, my motor is wayyy beveled LOL. After running last weekend the motor doesnt rub at all (did your marker on the motor trick) And the chassis does very little. We will compare more this weekend with your car un messed with but either way it cant hurt anything having the motor up. I had some nice hits and it didnt tweak, but I did go back to the 4 screws up front in the top deck. But any more corner speed is worth it, we carry alot of speed onto the straight and at the end, maybe you just need to carry some more speed everywhere to make the motor rub
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 07-27-2010, 06:19 PM   #2690
JayL's Avatar
haha "carry more speed everywhere" nice
you had no nice hits, the other "mod" guys werent there to hit you
Old 07-27-2010, 06:48 PM   #2691
Really though with the narrow and thinner chassis it cant hurt to mess with raising the motor because thats what really rubs the ground on everyones car ive looked at. And yeah true, but I havent had a tweaked car from being hacked (NO im not asking to try it lmao Scotty. We see you lurking in our thread )
Old 07-27-2010, 06:59 PM   #2692
Way2Evl's Avatar
LOL
Old 07-27-2010, 07:03 PM   #2693
Way2Evl's Avatar
Too far out front most of the time to get hacked. And coming around people just move out the way.
Old 07-28-2010, 12:00 AM   #2694
Still Bill's Avatar
To subscribe.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 07-28-2010, 03:27 AM   #2695
Cribbin's Avatar
those that have raised the motor mount bulkhead, what have you done about the ackerman post?
Bro-Kin Racing Group
X-Ray T3
X-Ray T2 '007
Castle Hill Raceway
Futaba LRP Tekin
Cribbin is offline   Reply With Quote
Old 07-28-2010, 08:23 AM   #2696
hana166's Avatar
Just a heads up about the exotek chassis if anyone is considering it
Nice and flat, which is good, but countersinking is messy with C/F thread loose like they used a worn out countersink. I recut them with a solid carbide countersink
Excellent value considering the lipo locators are included, and the design of these is really good
Front hinge pin mount holes are further forward so use 2mm spacer in front, 1mm behind to maintain default front wheelbase setting. Gives just about zero play which is cool
All fits together very accurately, no tweak
The chassis has considerably greater torsional stiffness when compared to stock, it is not similar at all
I run on high traction carpet and the car is always decking out in so hopefully this will improve things
I love the way this car handles and hope the chassis doesn't ruin it !
hana166 is offline   Reply With Quote
Old 07-28-2010, 09:03 AM   #2697
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
You raise the motor mount. NOT the bulkheads. Look at blackedoutrevo's photos. You see the shims under the topdeck to the bulkheads and none under the topdeck to the motor mount.
EDIT: I read your post wrong. I'm pretty sure that he just shimmed the steering post up too.
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 07-28-2010, 11:00 AM   #2698
JayL's Avatar
lower your motor till it rubs then go up alittle.
I would mount the motor stock and mark it, then drive the track hard every turn EXCEPT the sweeper, just roll it slow, do this for 5-6min and then check the motor for marks
Old 07-28-2010, 02:32 PM   #2699
Haha the starts of races are always the worst, and I usually start in the middle or back. Just gotta let off and drive a different line then wait for the pile up to happen then drop the hammer. Usually works lol
Just put a shim under the bearing in the plastic holder's till the slop is gone
Yeah I was a bit disappointed with the way the cuts and countersunk holes looked out of the package but ohh well. The chassis will be all scratched up with a few weeks of running anyhow I guess. Although my buddy has a cyclone exotek and the holes and cuts look great but its a few months old
I think theres alot of different things that would come into play here though also. You run thicker oil and less droop so your car would roll less then mine does. Obviously you dont like the idea of lifting the motor mount but im going to mess with it. Everyones car in 17.5 (I think were the first in mod to have them?) that has a exotek chassis go look at there motors, especially Brian's car, his motor looked worse then mine in mod lol. That cant help corner speed
Old 07-28-2010, 02:38 PM   #2700
musti72's Avatar
Hey guys I just got an Xray T3 EU...
Direct to the topic;
Will this motor bulkhead raising modification be required when using standart chassis? I will run my car on big nitro tracks with faast sweepers. Actually you can see it from my avatar.
Mustafa Alp
http://www.aytemizhobi.com
Turkish shop for: Serpent, Xceed, Sweep Racing, MyLaps
musti72 is offline   Reply With Quote
Xray T2'008 Drew_Cat Electric On-Road 1941 01-25-2016 12:36 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
XRay T3 (spy pics) syndr0me Electric On-Road 33 07-13-2010 04:43 PM
where to get xray?? 2qwik Northwest Racers 20 10-10-2009 03:02 AM
New Xray T3!!! Jammin'Trey Electric On-Road 39 10-09-2009 12:40 PM
