Old 07-11-2010, 11:29 AM   #2596
i have 2 types
2 Bionic 5000 40c
1 Acepow 5000 40c
sidecarphil1 is offline   Reply With Quote
Old 07-12-2010, 02:08 AM   #2597
KWT-NITRO's Avatar
just a small question about the rear ball diff, not sure till when to tighten it?? what's the method to know if its tight enough or not?? will run on low traction carpet (new carpet)
cheers
Ali
Team Kuwait, Team Terribles, www.rccck.org
Kuwait National Champion
FEMCA Truggy Finalist & FEMCA Buggy Semi-Finalist
Thanks to all my sponsors: Modelix/Ultimate Racing, AKA Racing, AVID Racing, Stick-it1 Racing and HES
KWT-NITRO is offline   Reply With Quote
Old 07-12-2010, 05:52 AM   #2598
hanulec's Avatar
Trader Rating: 27 (100%+)
cheers
Ali
Two ways -
#1 on the bench with the body off, use your left hand to hold the left wheel, diff housing and spur gear. With your right hand spin the right tire. If there is some slip that is ok. If there is no slip, then it is too tight. If the right wheel spins with nearly Hi resistance than it needs to be tighter.
#2 when on the track from a standstill punch the throttle and listen. If it sounds like it is slipping then tighter the diff slightly (1/8 of a wheel turn) and test again. Again, a little slip is ok, but too much will just cause u to rebuild the diff a lot. If when you punch it the car is pulling in way (and your tweak and trim are hood) then the diff is too tight.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 07-12-2010, 06:02 AM   #2599
KWT-NITRO's Avatar
Originally Posted by hanulec View Post
Two ways -
thanks alot for the info, exacrly what i was looking for, ill guess ill start with bench method and thenmove on to the track.
how will you adjust to track surface?? high grip = tighter diff/ low grip = softer diff??
cheers
Ali
Old 07-12-2010, 06:32 AM   #2600
hanulec's Avatar
cheers
Ali
Yes.
If your are running at your new carpet track you might want to get a pro10/235mm Or wgt /200mm car with those wide 1/10 foams to help build a groove.
Old 07-12-2010, 05:08 PM   #2601
shesha's Avatar
Send a message via MSN to shesha
Two ways -
Man you can hold alot with your left hand, I would not want to imagine what you can hold with your right hand...
R.C.C.C.K - Team Kuwait
shesha is offline   Reply With Quote
Old 07-12-2010, 10:07 PM   #2602
hanulec's Avatar
Originally Posted by Way2Evl View Post
Finally here is a pick of my modified Corally/Specialized RC bumper for the T3. As you can see it is much wider than the XRay Hard Foam bumper I have mounted on this main plate.
I have more pics here: http://picasaweb.google.com/racerlog/T3KydexBumper
Would anyone be interested in buy a product like this? But instead of it being 'hacked' together, for it to be properly made for XRay's??
Old 07-12-2010, 10:16 PM   #2603
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Has anyone tried the smokem chassis? Im stuck between that and the exotek chassis. Will probably end up with the exotek but just curious..
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 07-12-2010, 10:44 PM   #2604
B4james's Avatar
I have tried the Smokem and Exotek chassis and found they are both a good tuning option to have in the box.
I prefer the Exotek on very low grip surfaces due to the 2.00mm thickness and the Smokem on medium to high grip surfaces.
Follow me on Facebook - James Ainslie Designs or on Instagram - JA_Designs
*HEI International for Protoform/Proline/Spaz Stix
*Bitty Design Australia for Bodies and Liquid Mask
* Airbrushmegastore.com for all paint and airbrush supplies
B4james is offline   Reply With Quote
Old 07-12-2010, 10:52 PM   #2605
I prefer the Exotek on low grip surfaces due to the 2.00mm thickness and the Smokem on high grip surfaces. I do hear though that there is another Smokem version in the pipeline which will have more flex than the current one.
Hmm good to know. by high grip do you mean mainly carpet? And also is the smokem and exotek both the same width, or is one more narrow? Thanks!
Old 07-12-2010, 11:35 PM   #2606
Smokem, perfect quality on the cutting, all the holes etc, a mirror finish on the chassis and cheap.
Car feels much more stable, and more consistent to drive.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 07-12-2010, 11:45 PM   #2607
Pablo Diablo's Avatar
Send a message via Skype™ to Pablo Diablo
Unfortunately we don't often get the pleasure of carpet racing on this side of the planet. I spoke to a fast guy who uses a Smokem and his opinion is that at a bigger event than normal club days, that as the grip comes up from all the cars cleaning the track, the Smokem chassis starts working a little better than the Xray chassis.
Paul H
Losi Type R | Xray T3 | CRC Gen XL | CRC Gen X 10 ME(Messiah Edition) | Black Diamond
www.FlyingFoxRC.com | Advanced Electronics | Team CRC | Factory Messiah
Pablo Diablo is offline   Reply With Quote
Old 07-13-2010, 12:51 AM   #2608
B4james's Avatar
As Pablo Diablo mentioned below carpet racing is a rarity over here in Australia. In relation to the width they are both the same width which is quite narrow. The finish and quality of the CF on the Smokem chassis is second to none and as Brad mentions you can see yourself in it.
Agreed with comments above, the reverse of this is that I feel the Exotek tends to over grip the car when the grip comes up due to only being 2.0mm thick.
Old 07-13-2010, 04:17 AM   #2609
blade072's Avatar
Trader Rating: 98 (100%+)
i will have both chassis soon.....
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 07-13-2010, 04:44 AM   #2610
Make your own like I did .....
Easy and cheaper and more satisfying when you win
Xray T2'008 Drew_Cat Electric On-Road 1941 01-25-2016 12:36 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
XRay T3 (spy pics) syndr0me Electric On-Road 33 07-13-2010 04:43 PM
where to get xray?? 2qwik Northwest Racers 20 10-10-2009 03:02 AM
New Xray T3!!! Jammin'Trey Electric On-Road 39 10-09-2009 12:40 PM
