Old 07-06-2010, 05:40 PM   #2581
BBSpence's Avatar
Trader Rating: 45 (100%+)
Originally Posted by JayL View Post
that's not my point
my point is you will always be running a different viscocity oil than everyone else if you go with the 'american' measurements, unless ASSoc makes a 43.79 viscocity oil
My response wasn't meant to challenge your reply; it was to answer Way2Evl's question. But, 43.79 wt oil doesn't really mean anything as there is no standard for weight. AE 30 wt, Losi 30 wt, and Trinity 30 wt are all different. Yes, cSt (CentiStoke) is an actual viscosity value. So, assuming AE's cSt value is somewhat accurate, and you don't use their wt/cSt value for another brand like Losi or Trinity, you should be fine comparing.
BBSpence is offline   Reply With Quote
Old 07-06-2010, 10:53 PM   #2582
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Originally Posted by hanulec View Post
Andrew - I know my painted bodies from my T2'008/009 did not fit the same on the T3. You could make it work but the front posts were more forward.
I had heard that from someone as well, but I never encountered it with my 009 and T3; no flexing the body posts to get it to fit either and this was with a new body with normal sized holes. The 009 was previously owned so maybe there's something non-standard about it. I wonder why the discrepancy? Glad you mentioned it for the OP.
Old 07-06-2010, 11:28 PM   #2583
Johnny Wishbone's Avatar
Originally Posted by sidecarphil1 View Post
I have got the H roll centres on my T3 and was wondering if people add 1mm spacers to the outer links too ???
cheeRS Phil
Yes, definately locks in the end that you use them in. ie if you put them in the back you will get more rear traction
Old 07-06-2010, 11:46 PM   #2584
adrian_pg's Avatar
Send a message via AIM to adrian_pg
Originally Posted by KWT-NITRO View Post
Hey guys,
just a small question, i have a T2R pro and buying a T3, can i swch bodies without modifing the wholes?? do both chassis share the same body mounting wholes??
cheers
Ali
Yes! T3 body post position are the same as T2...
''Gosh... My wife going to divorce me, if I kept spending time in RC"...
///MEMBER OF PPRCC///
adrian_pg is offline   Reply With Quote
Old 07-07-2010, 01:12 AM   #2585
KWT-NITRO's Avatar
thanks for the info
Team Kuwait, Team Terribles, www.rccck.org
Kuwait National Champion
FEMCA Truggy Finalist & FEMCA Buggy Semi-Finalist
Thanks to all my sponsors: Modelix/Ultimate Racing, AKA Racing, AVID Racing, Stick-it1 Racing and HES
KWT-NITRO is offline   Reply With Quote
Old 07-07-2010, 06:00 AM   #2586
yokemad's Avatar
Not really !
Front posts located more forward position..
yokemad is offline   Reply With Quote
Old 07-10-2010, 02:09 PM   #2587
this is my home made new chassis plate
I made 1 small mistake with the countersinking and destroyed one bumper mount screw hole , but it isn't too bad really
the car is quicker through the corners and has a faster reaction through fast direction changes
sidecarphil1 is offline   Reply With Quote
Old 07-10-2010, 09:22 PM   #2588
Potoczak's Avatar
Trader Rating: 112 (100%+)
Wow looks really good, did you make all the cut out's yourself? Also where can you get sheets of Carbon fiber like that??
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 07-11-2010, 12:48 AM   #2589
I bought the carbon from a local suppyer here in Holland it was expensave though
and i cut it with a Dremmel with a diamond bit and then drilled the holes with a piller drill
Old 07-11-2010, 01:43 AM   #2590
blade072's Avatar
Trader Rating: 98 (100%+)
VERY NICE......ahh memories.....i used to make modded chassis for both my EV10 and TAMIYA F1 back in the day....
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 07-11-2010, 04:09 AM   #2591
Pablo Diablo's Avatar
Send a message via Skype™ to Pablo Diablo
You must not have heard of Smokem Racing then? Yours looks much the same. Hope you had a mask on, those pieces of carbon are not so good for the lungs!
Paul H
Losi Type R | Xray T3 | CRC Gen XL | CRC Gen X 10 ME(Messiah Edition) | Black Diamond
www.FlyingFoxRC.com | Advanced Electronics | Team CRC | Factory Messiah
Pablo Diablo is offline   Reply With Quote
Old 07-11-2010, 10:04 AM   #2592
I didn't like the designs of the other brands of chassis'
i wanted it to be equal width left and right sides
And i wanted a 2.0mm chassis plate every one elses are 2.3
I tested it today and can report it is very quick and my corner speed is great
I TQ'ed this morning but due to cooking a motor and loosing a tyre in the other 2 quali's i ended up starting last and worked my way to 3rd and 4th in the finals
Old 07-11-2010, 10:31 AM   #2593
Andy63's Avatar
how did you get the lipo to get so low and flat on the chassies? and what was holding the lipo?
www.andrefossto.wordpress.com|HOBBYWING |YOKOMO |HBracing |MIBOSPORT.COM |Reservdelsrc.com |Jockeli-Painting |
Andy63 is offline   Reply With Quote
Old 07-11-2010, 10:38 AM   #2594
My lipos are flat bottomed and so they sit on the chassis plate nicely and i use the Xenon racing battery tape
Old 07-11-2010, 11:05 AM   #2595
Andy63's Avatar
What type of lipo are you using? what brand?
Xray T2'008 Drew_Cat Electric On-Road 1941 01-25-2016 12:36 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
XRay T3 (spy pics) syndr0me Electric On-Road 33 07-13-2010 04:43 PM
where to get xray?? 2qwik Northwest Racers 20 10-10-2009 03:02 AM
New Xray T3!!! Jammin'Trey Electric On-Road 39 10-09-2009 12:40 PM
