Old 06-11-2010, 07:19 PM   #2371
mikel33's Avatar
Trader Rating: 2 (75%+)
Originally Posted by Owen RaCing View Post
Don't you mean hudy laser etched and optimized shrink tube?
yeah. Optically controlled rate of shrinkage proportional to applied heat source.
Michael Larson.
Village Idiot Racing - Now accepting driver applications.
mikel33 is offline   Reply With Quote
Old 06-11-2010, 09:08 PM   #2372
Still Bill's Avatar
LOL...I've seen em!
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 06-12-2010, 02:03 AM   #2373
nitro rat's Avatar
Trader Rating: 5 (86%+)
Hey guy's,
Im thinking of droping down from 3.0 to 2.6 springs on the front and droping from 2.6 to 2.4 on the rear. The track is pretty slippery and im just trying to get mor traction and turn in. I think by putting the ecs drive shafts in the front will help to. Any thought's?
SMC BATTERIES
ALPHA ENGINES
TEAM DURANGO
nitro rat is offline   Reply With Quote
Old 06-12-2010, 07:35 AM   #2374
hanulec's Avatar
Trader Rating: 27 (100%+)
Originally Posted by nitro rat View Post
Hey guy's,
if your track has low grip you could run 2.6 or 2.4 up front, and 2.4 or 2.2 in the rear. i'd also recommend you try running with and without swaybars.
the ecs shafts help only when you are seeing wheel chatter under full lock conditions. i really like the ecs parts -- but if you cannot keep your car off the boards for the entire race they might not be the best things to buy right away.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 06-12-2010, 09:06 AM   #2375
Hey guy's,
The ECS assembly may reduce your off power steering because of how they free up the front drivetrain. You could try a little bit of antidive or some more rear uptravel to achieve a little more steering on entry. Keep in mind when you add antidive that you're reducing your caster and affecting your front ride height and uptravel. I'd at least reset your ride height and uptravel after adding antidive. (Note that I haven't tested much with antidive, but I've read that it works. Hope you don't mind being sort of a guinea pig for this as I won't get to race again 'til mid-July.)
If you're low on grip I'd also recommend some antisquat in the rear and standing the rear shocks up one hole on the tower. The antisquat will help the car rotate in the middle and on exit, but gives forward bite on exit. Standing the rear shocks up will give you back that side bite middle and out. Don't forget to check and reset your ride height and uptravel after adding antisquat, etc.
What setup did you start with? I tested the antisquat/shock angle last weekend on a low grip track starting with Paul's Reedy setup (minus the chassis). I didn't get to test the antidive, but that was next on my list.
punkboy is offline   Reply With Quote
Old 06-12-2010, 04:56 PM   #2376
nitro rat's Avatar
Hi Guy's,
Thanks for all your replys. I started with Kit set-up and it had no low speed turning on our slippery track so i changed it. I layed the shocks over 1 hole as it had alot of on power steering (at high speed) but no low speed steering, The back would also step out under power so then I went to 1.3 swaybar upfront, and took one shim all round out of the roll center. This helped alot. The car is the fastest out there at the moment but on corner entry it pushes a little bit and on exit under power the back keeps wanting to step out. I was going to try run 2.6 springs up front. 2.4 springs on the rear with 30wt all around. I was also going to put the ecs drive shafts in.
Thanks for your help
SMC BATTERIES
ALPHA ENGINES
TEAM DURANGO
Old 06-12-2010, 08:13 PM   #2377
Way2Evl's Avatar
I had push on corner entry and I set more droop in the rear so I'd get weight transfer. It's current setting is 3. My rear would also step out a little and I found that laying my rear shocks down to 1 helped out quite a bit. Hope that helps.
X-Ray T3|Tekin|KO Propo|Spektrum|Thunder Power|Hyperion|Sorex
www.speedworldraceway.com
Way2Evl is offline   Reply With Quote
Old 06-12-2010, 09:12 PM   #2378
Benzaah's Avatar
Trader Rating: 21 (96%+)
I have done a fair bit of testing with Anti dive and I run it in my set up all the time although i am testing without it and the 6 degree hubs next practice as we are between seasons and I saw a similar set up on the Xray site and want to try it out. Not everything works for everyone and i have tested a lot of set ups to see what works for me. Try the 1st set up for starters and the 2nd if you want something more aggressive. These set ups do suffer a little when the grip comes up and are good for low to medium traction only. It's such a fiddly change to make going back changing c hubs and roll center adjusters on a race day so i just reduce my camber and toe and lay in the shocks and hope no one has tuned their car better to the track that day
http://forum.teamxray.com/xform/inde...=1589&setup=t3
http://forum.teamxray.com/xform/inde...=1590&setup=t3
Adelaide RC - XRAY Xb216de & Xb416
Walter Rc Hobby - Serpent 4X
Nosram - R1wurks - Sanwa - Hudy - Muchmore
Benzaah is offline   Reply With Quote
Old 06-14-2010, 04:13 AM   #2379
lill question.
X-ray T3 vs X-ray T3R
is this meaning the end of the t3 series ?
Lockyie is offline   Reply With Quote
Old 06-14-2010, 04:27 AM   #2380
hanulec's Avatar
Originally Posted by Lockyie View Post
lill question.
Nope. The T3R replaces the T2R as the beginner/value focused TC offering from XRay.
Old 06-14-2010, 01:30 PM   #2381
pinoy69racer's Avatar
Trader Rating: 180 (99%+)
Default help!!!!!!!
hey guys, what is the best set up (pinion and spur gear) for novak 21.5 spec class for xray t3....
thanks you!!!!!!
HENRY C
DESOTO RACING/SERPENT/VEYTREX DESIGN LAB/RC TARGET
pinoy69racer is offline   Reply With Quote
Old 06-14-2010, 04:01 PM   #2382
JayL's Avatar
be careful using droop for entry, I like to save it for exit, as there are more things you can do for entry, like tap the brakes .
usually when someone asks me how to help push on entry I wonder if they aren't overdriving the front tires, so I usually suggest Dual rate and/or slower corner entry as a start.
how is the tire wear? are you getting way more front wear than rear?
JayL is offline   Reply With Quote
Old 06-14-2010, 06:16 PM   #2383
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
This weekend I found that shortening the front links gave the car a lot more corner speed. In my mind, it should have reduced the front traction because the car is rolling less.
Could someone please explain why I picked up so much more corner speed? The car is in the upper outer position with 1 mm of shim on the hub.
Thanks,
Dane
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
www.toycarracingblog.com
Dane is offline   Reply With Quote
Old 06-14-2010, 08:17 PM   #2384
tb214's Avatar
Thanks,
Dane
Well, You might have lost some roll traction (outside tires, by rolling less), but you also have gained some traction on inside tires (your inside tires are now pressed onto the surface more). 2 wheels turning on the front is better than lets say 1.5 wheels turning. You can roll less if you have traction.
"Inspired by the late Phillip Toshio Sudo."
tb214 is offline   Reply With Quote
Old 06-15-2010, 12:35 AM   #2385
KWT-NITRO's Avatar
hello,
just a small question, when lookin at spur gears and pinion, what does 48P and 64P mean?? i know its pitch but dont understand what is it!
whats different between them and when to use what ??
cheers
Ali
Team Kuwait, Team Terribles, www.rccck.org
Kuwait National Champion
FEMCA Truggy Finalist & FEMCA Buggy Semi-Finalist
Thanks to all my sponsors: Modelix/Ultimate Racing, AKA Racing, AVID Racing, Stick-it1 Racing and HES
KWT-NITRO is offline   Reply With Quote
Xray T2'008 Drew_Cat Electric On-Road 1941 01-25-2016 12:36 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
XRay T3 (spy pics) syndr0me Electric On-Road 33 07-13-2010 04:43 PM
where to get xray?? 2qwik Northwest Racers 20 10-10-2009 03:02 AM
New Xray T3!!! Jammin'Trey Electric On-Road 39 10-09-2009 12:40 PM
