Old 06-10-2010, 09:12 PM   #2356
Trader Rating: 16 (100%+)
Hi
Has any got the editable and save-able setup sheet? Thanks!
ronaldo-1234 is offline   Reply With Quote
Old 06-10-2010, 11:07 PM   #2357
nitro rat's Avatar
Trader Rating: 5 (86%+)
Hey guys,
Just wondering if any of you's can shed any light on the ECS drive shafts. Would just like to know what the performance difference is compared to the standard cv's
SMC BATTERIES
ALPHA ENGINES
TEAM DURANGO
nitro rat is offline   Reply With Quote
Old 06-11-2010, 12:25 AM   #2358
Way2Evl's Avatar
Originally Posted by JayL View Post
the hudy balance pins
you can place them in the middle for front to back as well
if you use scales you need fixed link, to replace all four shocks, that is the exact same length as your shocks
Fixed link to replace shocks, I don't get it?? Also, where do you put the balance pins for front to back. I see the holes for left to right but not for front to back? Or do you just find chassis center point and place balancing pin there?
X-Ray T3|Tekin|KO Propo|Spektrum|Thunder Power|Hyperion|Sorex
www.speedworldraceway.com
Way2Evl is offline   Reply With Quote
Old 06-11-2010, 06:56 AM   #2359
Trader Rating: 38 (100%+)
fixed linked would be like a set of turnbuckles replacing the shocks that are all the same length
or8ital is offline   Reply With Quote
Old 06-11-2010, 09:44 AM   #2360
Way2Evl's Avatar
Originally Posted by ronaldo-1234 View Post
Hi
Go here http://forum.teamxray.com/xsheets.php create a username and password. Go to create set-up sheet and do so.
Old 06-11-2010, 09:46 AM   #2361
Way2Evl's Avatar
Sorry to ask so many questions, but why do you need a fixed link. What kind of inconsistency occurs if you try and do it with you shocks on? Just wondering, thanks.
Old 06-11-2010, 09:54 AM   #2362
The likely-hood that your shocks are the perfect length from left to right is minimal. Using the links gives u the exact measurement for each corner. You can do it either way to be honest with you. If you are confident your shocks are exactly the same length, rebound, etc don't use the links. Onroad is all about precision the more precise everything is the better the car will handle...in a nutshell.
Schuurspeed / Aero-model / Gear One / LG1
www.OHRCR.com
Gitsum is offline   Reply With Quote
Old 06-11-2010, 11:57 AM   #2363
Way2Evl's Avatar
And that would effect placing your car on four scales to corner balance it and get the weight even? Or are we talking about two different things?
Old 06-11-2010, 12:08 PM   #2364
JayL's Avatar
yes the front to rear balance has no holes but the pins still sit under the chassis fine..I usually end up doing front to back weight by looking at tire wear....
if you corner balance your car with the shock on using scales you will go crazy due to slight differences in each shock length and dampening and the fact that they can move
if you want to do it this is the way:
step one: make 4 turnbuckles the same length as the shocks,
step 2: balance using lead or xray weights
step 3: put the shocks on and tweak the car using the scales and the shock collars to adjust
you may not even want the car balanced front to rear, it may handle better heavier on one end depending on the track layout etc.....
JayL is offline   Reply With Quote
Old 06-11-2010, 01:16 PM   #2365
Way2Evl's Avatar
Thanks J!!
Old 06-11-2010, 01:25 PM   #2366
PinoyCali's Avatar
Default Gear
Hello...newbie here..
What is good starting gear set up spur/pinion
for novak 21.5 and havoc esc?
Thanks,
Mike
PinoyCali is offline   Reply With Quote
Old 06-11-2010, 03:04 PM   #2367
this is what i do to my ECS axles to stop them coming apart and it keeps the dirt out
sidecarphil1 is offline   Reply With Quote
Old 06-11-2010, 05:07 PM   #2368
JayL's Avatar
yep!
I can't wait for xray to come out with some killer shrinktubing
Old 06-11-2010, 06:21 PM   #2369
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
Don't you mean hudy laser etched and optimized shrink tube?
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 06-11-2010, 07:04 PM   #2370
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
lol
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Xray T2'008 Drew_Cat Electric On-Road 1941 01-25-2016 12:36 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
XRay T3 (spy pics) syndr0me Electric On-Road 33 07-13-2010 04:43 PM
where to get xray?? 2qwik Northwest Racers 20 10-10-2009 03:02 AM
New Xray T3!!! Jammin'Trey Electric On-Road 39 10-09-2009 12:40 PM
