Old 06-08-2010, 11:14 PM   #2341
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Clint161 View Post
Can you give us an idea of what was different on his chassis?
What do you think these differences changed?
I'm sure I'm not the only one who is interested, Thanks!
Paul's chassis was a custom machined piece, that I kind of have the impression that he made himself for testing purposes. It was made for lipo (No cell cut outs) and had some center cut outs. This is all vague, as I was racing and doing my own thing to much to remember.
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 06-09-2010, 02:14 AM   #2342
Way2Evl's Avatar
I believe it was mentioned that the top deck was hollowed all the way through also.
X-Ray T3|Tekin|KO Propo|Spektrum|Thunder Power|Hyperion|Sorex
www.speedworldraceway.com
Way2Evl is offline   Reply With Quote
Old 06-09-2010, 02:16 AM   #2343
Way2Evl's Avatar
Like an exotek?
Old 06-09-2010, 11:07 AM   #2344
Trader Rating: 16 (100%+)
When getting a new T3, besides the usual spares like arms, c-hub, uprights, knuckles, what are the other option parts that is good to have?
How does the option F/R arms, upright compare to the standard ones?
How does the option ESC drive shaft compare to the standard ones?
ronaldo-1234 is offline   Reply With Quote
Old 06-09-2010, 04:36 PM   #2345
hanulec's Avatar
Trader Rating: 27 (100%+)
you should pick up a hard foam bumper, some replacement 'blades' for drive shafts, and maybe the aluminum spool cups. you'll wanna pick up a bunch of spurs too. the 50mm dog bones can cause the car to steer more up front, or have more roll in the rear.
Martin Hudy talks about some of the optional parts here: http://forum.teamxray.com/viewtopic....9739&start=180
For the ECS - they are really useful on rubber tire carpet racing. they aren't really necessary -- and are not worth it if you're slamming into things. they can get expensive to replace/fix.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 06-09-2010, 04:44 PM   #2346
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by Way2Evl View Post
Like an exotek?
No, it had big open cut outs in the center of the chassis, there was 4 I believe, and they went the length of the chassis. It was very cool
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 06-09-2010, 05:12 PM   #2347
JayL's Avatar
optimized multi-flex lol
JayL is offline   Reply With Quote
Old 06-09-2010, 07:14 PM   #2348
ark
Was it one of these maybe
http://www.smokem-racing.com/T3LP1.html
ark is offline   Reply With Quote
Old 06-09-2010, 07:41 PM   #2349
Hahaha! It was optimized for sure
Noooope. Was custom made by himself. Im amazed no one took pics of his car from reedy. I would of but it was the last thing on my mind lol
Old 06-09-2010, 11:30 PM   #2350
If he is at the world i will snap some pictures of the chassis
sidecarphil1 is offline   Reply With Quote
Old 06-10-2010, 10:59 AM   #2351
Way2Evl's Avatar
What are most using to balance their car and how do you go about doing it? Can four scale technique work, or does tweak play a factor?
Old 06-10-2010, 05:10 PM   #2352
JayL's Avatar
the hudy balance pins
you can place them in the middle for front to back as well
if you use scales you need fixed link, to replace all four shocks, that is the exact same length as your shocks
Old 06-10-2010, 05:21 PM   #2353
Still Bill's Avatar
The IRS balance buttons work far better than the Hudy balance pins and cost less.
One of the few non-Hudy tools in my pit box.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 06-10-2010, 05:36 PM   #2354
PrimeAKF11's Avatar
Just curious, how durable are the stock xray belts? I never broke any belts on my cyclone so I'm wondering if it is still necessary to stock up on them.
Best rubber tires>> www.SweepRacingUSA.com
For your Team Magic G4 parts needs>> www.bluesunhobbies.com
HD Videos of Blue Diamond Onroad Raceway!!! 200ft+ straight of fury!! >> http://www.rctech.net/forum/racing-forum/406318-2nd-annual-pete-johnson-have-nice-day-memorial-race-5.html
PrimeAKF11 is offline   Reply With Quote
Old 06-10-2010, 06:13 PM   #2355
hanulec's Avatar
like people said, pins work great. you can also get away with two scales and two equal pieces of 1" sq x 12" aluminum stock. you set your ride height equal (i.e. do not apply a tweak) and then using the two scales and the aluminum stock balance the car left / right and front / rear.
in the US to make 1420/1425 w/ rubber tire i'm using xray 10g weights at the front of the car, on the left and right, in front of the battery and servo. i run a 15g weight behind my battery at the rear. finally, i put 3x7g sticky lead slightly off center close to my ESC and servo -- away from the belts.
unless your running modified, your belts will more than last any race reason. i swap belts (mostly the front belt) out before important races or when swapping from indoor to outdoor season/etc.
Xray T2'008 Drew_Cat Electric On-Road 1941 01-25-2016 12:36 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
XRay T3 (spy pics) syndr0me Electric On-Road 33 07-13-2010 04:43 PM
where to get xray?? 2qwik Northwest Racers 20 10-10-2009 03:02 AM
New Xray T3!!! Jammin'Trey Electric On-Road 39 10-09-2009 12:40 PM
