Old 06-07-2010, 11:24 AM   #2326
Send a message via AIM to goop
Originally Posted by Way2Evl View Post
I have read this whole thread and I see a lot of people referring to the pro's set up for reference, and if there is one thing I learned this weekend with talking to the guys is that the pro's cars are not like ours. They have many changes they have made to parts and setup that cant be put on a set up sheet. I'd think it be best for one to take notes from setups of people who are fast at your local track that run the T3. Correct me if I'm wrong.
look at paulies setup from the reedy. he was running exactly what he posted in his setup no other special parts he left out. i tried it this weekend and must say its the best my car has been. the only thing is that im running xray 350 shock oil front and rear and no swaybars im running the ltc body as i know paul was running a speed 6
Hurricane Motorsports
Team Trinity
TOP Racing - Gravity Rc - Contact tires - KO Propo - Competition Electronics
goop is offline   Reply With Quote
Old 06-07-2010, 11:28 AM   #2327
JayL's Avatar
I guess you didn't see paul's chassis OR the way he mounted the front roll links.......not listed in the setup
JayL is offline   Reply With Quote
Old 06-07-2010, 11:31 AM   #2328
Trader Rating: 28 (100%+)
ditto.......
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 06-07-2010, 11:51 AM   #2329
drsfly's Avatar
Default Paul's set up.
Actually it is on the sheet he posted. Unfortunatly if you only open the PDF version there are no notes at the bottom. If you open the other version (on the left) it has a notes section at the bottom and the description is there of what he did.
Later,
Darrald
drsfly is offline   Reply With Quote
Old 06-07-2010, 12:16 PM   #2330
Later,
Darrald
you are correct darrold.
the chassis is stock and he mounted the camber link to the shock tower standoff to make the link extra long.
Team Trinity
Old 06-07-2010, 12:47 PM   #2331
JayL's Avatar
his chassis was NOT stock, sorry I don't care what you claim
Paul even says it wasn't stock in his thread.....
MIS-INFO per usual
Old 06-07-2010, 12:50 PM   #2332
Fred Hubbard's Avatar
MIS-INFO per usual
In the interest of clarity for everyone, I was at the event and his chassis was not stock. Not a big deal though as long as you keep it in mind when testing his or any other setup
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 06-07-2010, 01:16 PM   #2333
drsfly's Avatar
Default parts difference/changes
Jay/Fred-- Sorry,
I did not even think about the chassis. i was just pointing out that Paul is good about putting all the info out there. Just as Jay pointed out Paul mentioned in his thread--- the chassis he was running may at some point be available---- in some form.
The info on the camber link mod is available.
I think all the pro's keep some information to themselves-- at least for a while. However It is at some point in their interest to pass it on so our cars make us happy.
That is all.
thx,
Darrald
Old 06-07-2010, 01:28 PM   #2334
my appologies on the chassis confusion.
Team Trinity
Old 06-07-2010, 01:34 PM   #2335
Way2Evl's Avatar
A few questions....
1) Any difference between ecs shafts and the knock off ones?
2) When should 50mm shafts be used instead of 52mm? Or how will the car change when using 50mm in front and back?
3) What will "Hard" C-Hubs & Steering Blocks do for performance?
X-Ray T3|Tekin|KO Propo|Spektrum|Thunder Power|Hyperion|Sorex
www.speedworldraceway.com
Way2Evl is offline   Reply With Quote
Old 06-07-2010, 07:18 PM   #2336
hanulec's Avatar
Trader Rating: 27 (100%+)
it is very hard to look at a setup sheet on the internet and have that apply to your local track. that said - i do look at the setups of others online to see what they 'say' they are doing. the euro setups always look interesting to me but i know their cars are much lighter than in the US.
by far the best help is that help you have locally. also - the help doesn't need to only be from XRay drivers . i've been encouraging my local RCAmerica teammates to post their setups whenever possible on the forum.teamxray.com. all of mine are under the username 'racerlog'.
A few questions....
non-XRay ECS are OK - but they are not as strong. any brand of ECS will require more maintenance than the CVDs as the pins are much more brittle. shrink wrapping your ECS pins is by far one of the best things you can do
i've been preferring 50mm shafts as they let the car roll more.
some people like the Hard c-hubs, knuckles and toe blocks. i always run hard rear toe blocks, but will run either medium or hard front end parts.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 06-08-2010, 11:47 AM   #2337
JayL's Avatar
the 50mm generally give more steering
stick with real xray ecs
the harder arms/knuckles are for carpet
If you are not hitting every turn-in point perfect, at this point I would stick with stock parts and practice practice practice
Old 06-08-2010, 02:06 PM   #2338
Way2Evl's Avatar
Thanks Hanulec
Thanks J, I just like the knowledge base. I wouldn't use any upgrades until I stop hitting stuff anyway. I'd hate to throw away $50.
Old 06-08-2010, 04:03 PM   #2339
JayL's Avatar
Thanks Hanulec
exactly
Old 06-08-2010, 11:03 PM   #2340
Clint161's Avatar
Can you give us an idea of what was different on his chassis?
What do you think these differences changed?
I'm sure I'm not the only one who is interested, Thanks!
Clint161 is offline   Reply With Quote
Xray T2'008 Drew_Cat Electric On-Road 1941 01-25-2016 12:36 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
XRay T3 (spy pics) syndr0me Electric On-Road 33 07-13-2010 04:43 PM
where to get xray?? 2qwik Northwest Racers 20 10-10-2009 03:02 AM
New Xray T3!!! Jammin'Trey Electric On-Road 39 10-09-2009 12:40 PM
