Old 06-03-2010, 10:17 PM   #2296
Still Bill's Avatar
XRAY 303364
http://www.nexusracing.com/product_i...oducts_id=3027
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 06-03-2010, 10:41 PM   #2297
Way2Evl's Avatar
How does one accurately measure rebound on a shock with anything besides 25, 50, 75 & 100% rebound. Is there a gauge or technique?
X-Ray T3|Tekin|KO Propo|Spektrum|Thunder Power|Hyperion|Sorex
www.speedworldraceway.com
Way2Evl is offline   Reply With Quote
Old 06-04-2010, 07:34 AM   #2298
KWT-NITRO's Avatar
this is my method that i use for both onroad and offroad shocks,
i measure the shaft length from bottom cap to top of ball ends, lets say its
10mm, i bring a fuel line or an antenna tube and start cutting them to specifis lengths using a cliper.
10mm= 100% rebound
7.5mm= 75% rebound
5mm = 50% rebound
2.5mm = 25% rebound
same thing goes for other values
8mm is 80%
4mm is 40% ... etc etc etc
then i build the shock and when the time comes to set the rebound, i put the plastic/fuel line between the bottom cap and the ball end and push the shaft untill the "rebound" piece stops the movement at the percentage you choose. you check the rebound and do it again if you dont have it right the first time, if you end up with less rebound than needed, refill shocks and start over.
does it make any sense to you?? it may sound complicated but its been working great with me.
cheers
Ali
Team Kuwait, Team Terribles, www.rccck.org
Kuwait National Champion
FEMCA Truggy Finalist & FEMCA Buggy Semi-Finalist
Thanks to all my sponsors: Modelix/Ultimate Racing, AKA Racing, AVID Racing, Stick-it1 Racing and HES
KWT-NITRO is offline   Reply With Quote
Old 06-04-2010, 07:47 AM   #2299
Way2Evl's Avatar
Makes perfect sense. I just hope when I measure I can get a nice round number like 10 . I'm good with math. I'll figure it out. Thank you!
Old 06-04-2010, 10:18 AM   #2300
please correct me if i am wrong:for the istallation of the STANDARD front one way multi-diff you must use XRAY Alternative Driveline Configuration for NIMH batteries.
My car is the T3.
cr0c0dil3 is offline   Reply With Quote
Old 06-04-2010, 10:33 AM   #2301
My car is the T3.
Yep, the front belt will need to be on the left if you wish to use the one-way.
punkboy is offline   Reply With Quote
Old 06-04-2010, 11:44 AM   #2302
T3R just released
Also Spec-R arms. 1mm Shorter. Hmmm
g26er is offline   Reply With Quote
Old 06-04-2010, 12:08 PM   #2303
ttso's Avatar
Xray's pass history of releasing "R" spec car... tell you something.........
ttso is offline   Reply With Quote
Old 06-05-2010, 09:46 AM   #2304
Just recieved my t3 yesterday put my tekin 13.5 system together but I now have a problem. My HiTec servo doesn't line up with the servo post holes. It's a standard size servo. Also I notice that xray doesn't include hitec servo horns. Anyway to fix my problem?
immrwright7 is offline   Reply With Quote
Old 06-05-2010, 09:56 AM   #2305
I had the same problem w/ both Futaba and Ace servos. Narrow holes were too narrow and the wide ones too wide. I end up using big washers on the servo screws and the wide holes in the chassis.
Old 06-05-2010, 11:57 AM   #2306
I'll try that do you have pictures to show how it's done?
Old 06-05-2010, 01:31 PM   #2307
Still Bill's Avatar
Default T3 Servo Post
Would be interesting to hear what actual servo does fit the T3 posts without modification (or spacers).
Bill
Old 06-05-2010, 01:40 PM   #2308
No, sorry. I just sandwiched the ears with 3 mm washers on each side and the screws are just out towards the outside edges of the ears. Just use washers and the outside hole on the chassis and you should be fine.
Bill
Me too! Wonder if the Exotec chassis has the servo holes right. I've been looking at this chassis. I'm disappointed in the Xray chassis. The uneven rear suspension mount holes make no sense to me. 3deg left rear toe and 2~2.5 right rear toe. Have to use an extra .4 shim on the right to get the rear toe even. Wonder if the 1pc rear (forward) suspension mount fixes this?
Old 06-05-2010, 04:17 PM   #2309
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Bill
My ko servos only need spacers from the radio tray (steering spacers d or something) also same with airtronics. airtronics use the narrow position ko use the wide position.
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 06-05-2010, 04:28 PM   #2310
gonzo416's Avatar
Trader Rating: 39 (98%+)
anyone have the 1pc rear (forward) suspension mount in stock? need 3
gonzo416 is offline   Reply With Quote
Xray T2'008 Drew_Cat Electric On-Road 1941 01-25-2016 12:36 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
XRay T3 (spy pics) syndr0me Electric On-Road 33 07-13-2010 04:43 PM
where to get xray?? 2qwik Northwest Racers 20 10-10-2009 03:02 AM
New Xray T3!!! Jammin'Trey Electric On-Road 39 10-09-2009 12:40 PM
