Old 06-02-2010, 11:52 PM   #2281
Sam-E's Avatar
Originally Posted by nitro rat View Post
Hey guys,
Just after some help with my T3. The car is very fast but lacks rear traction when exiting a corner or entering a corner. Im racing on an asphalt tight track with low traction. Coming out of a corner the rear of the car just wants to let go. Im running Kit setup with 30wt shock oil all around (%100 Rebound) i have moved the front and rear shocks in 1 hole from kit set up. I have gone to 1mm shims all around on the hubs. Front sway bar is now a 1.3 Everything else is as per kit set up. As i said the car is fast and i dont wanna compromise its performance by changing alot just to gain rear end traction. is there anything i can do to get somemore rear end traction?
Thanks heaps Guys
Your answer is simple............ Tamiya 416!!!!! lol!!!!!!!!
TMORC - Official Club for the 1/10th Offroad Electric Worlds, 2012!!
Sam-E is offline   Reply With Quote
Old 06-03-2010, 12:59 AM   #2282
Sith Lord's Avatar
Trader Rating: 21 (100%+)
Thanks for everyones replies on the previous page regarding loctite, cvd's, etc. I will strip the car down on the weekend and start again using some of your tips.
Top - $3.00 for 8. The Xray ones seem to be a bargain at $3.60 for 2!
Tamiya XV-01 Rally :: Tamiya FAV 2011 :: Proline Pro2 SCB
Sith Lord is offline   Reply With Quote
Old 06-03-2010, 01:01 AM   #2283
nitro rat's Avatar
Trader Rating: 5 (86%+)
No im gonna stick out the remainder of the year with the T3 and see if i can get it to go better. it is fast, its just the rear end which is annoying. if i cant sort it out im gonna go with a different car next season
SMC BATTERIES
ALPHA ENGINES
TEAM DURANGO
nitro rat is offline   Reply With Quote
Old 06-03-2010, 01:01 AM   #2284
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Hey guys,
Thanks heaps Guys
Try a harder rear sping
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 06-03-2010, 01:04 AM   #2285
nitro rat's Avatar
ok thanks, i will give it a go. i would have thought a softer rear spring? But anyway i will try that and see how it goes.
Thanks, much appreciated
SMC BATTERIES
ALPHA ENGINES
TEAM DURANGO
Old 06-03-2010, 01:09 AM   #2286
A harder spring will help with on power, may not with entering a corner but give a go. Most people on asphalt run the same spring fr anf rr or 1 rate difference, so give it a shot.
Antoni
Antoni Caretti
Old 06-03-2010, 01:19 AM   #2287
dont buy a TRF , i swapped from Tamiya to Xray andit was the best decicien i ever did
try this set up our track is dusty and low grip
http://forum.teamxray.com/xform/inde...=1358&setup=t3
sidecarphil1 is offline   Reply With Quote
Old 06-03-2010, 02:16 AM   #2288
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
Originally Posted by punkboy View Post
Aluminum knuckles will make the car push. Are you using the "M" knuckle or the "H"? You want the H (Hard) for all conditions with rubber tires.
Why you want the H over M on asphalt? Can you please explain?
Thank you
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
Don't practice until you get it right. Practice until you can't get it wrong
Team Xray T4'17, Team Xray X10'18, TOP Racing Rebel
nnick is offline   Reply With Quote
Old 06-03-2010, 02:21 AM   #2289
GTRtuned's Avatar
Hey guys,
Thanks heaps Guys
My local racetrack is pretty high grip but when I go out to race on low traction asphalt there are a few things I do to gain rear traction. For the T3 you can try running 2.5 mil spacers on the rear hubs and lowering the inner rear camber links. You can also bring in your rear shocks all the way in. Also for low traction you can go with more droop in the rear. 5 droop up front and 4 in the rear. Last thing I do is lighten the rear springs. Try 2.4 in the rear and 2.8 in the front. Hope this helps...
Walter Cosico
RC America/ X-ray/ SRG www.superradgraphics.com/ Hudy/ R1wurks/ TeamBocaBearings
GTRtuned is offline   Reply With Quote
Old 06-03-2010, 03:01 AM   #2290
ark
When I changed to the Exotec chassis, the car was loose on power exiting turns with my usual 2.4 rear springs so I then went to 2.6 on the rear and problem solved. So I would suggest in some instances, firm up the rear if you are having trouble putting power down IF you already have softish springs on. If you need more grip in the middle of the corner then its a good idea to lay the shocks down. My 2c
ark is offline   Reply With Quote
Old 06-03-2010, 06:28 AM   #2291
jonny123's Avatar
Try the 1 hole rear uprights if you're not running them
already. They make the rear end alot more stable at both highspeed and lowspeed corners. I won't be switching back to the standard rear upright anytime soon.
Jonny
Xray-Hudy-Ko Propo-RC DisCo Uk-Ardent Racing-Boultspeed
jonny123 is offline   Reply With Quote
Old 06-03-2010, 06:32 AM   #2292
jonny123's Avatar
Also try standing the rear shock up one hole upto no.4. If you're struggling putting power down this helps alot. Make sure you have a perfect rear diff aswell as this may be your problem if you're struggling on and off power with rear traction.
Jonny
Old 06-03-2010, 06:19 PM   #2293
Thank you
The H parts are more durable and flex less which makes them more consistent IMO. It's all personal preference and someone else might like the feel of the M parts and their flex characteristics. A lot of guys in my area ditched the M parts quickly for the H.
punkboy is offline   Reply With Quote
Old 06-03-2010, 08:02 PM   #2294
nitro rat's Avatar
Thanks guys for all your help, i will make a few changes and let you know how it goes. Thanks again
SMC BATTERIES
ALPHA ENGINES
TEAM DURANGO
Old 06-03-2010, 08:04 PM   #2295
nitro rat's Avatar
Jonny
Thanks Jonny,
Have you got a part number?
SMC BATTERIES
ALPHA ENGINES
TEAM DURANGO
Xray T2'008 Drew_Cat Electric On-Road 1941 01-25-2016 12:36 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
XRay T3 (spy pics) syndr0me Electric On-Road 33 07-13-2010 04:43 PM
where to get xray?? 2qwik Northwest Racers 20 10-10-2009 03:02 AM
New Xray T3!!! Jammin'Trey Electric On-Road 39 10-09-2009 12:40 PM
