XRAY T3
Old 06-02-2010, 03:37 AM
  #2266
Benzaah's Avatar
Trader Rating: 24 (96%+)
I had screws come a touch loose after a few runs and just checked them after each run for about the first 10 or so. I ended up adding a small touch of ca glue to the screw holes on the chassis and doing that has made some of then very hard to crack when releasing all scres to remove tweak. As for the CVD issue, IMO build them dry without any lube and a tiny bit of purple thread lock with flat spot pins. I let them dry overnight and check for binding which can happen when building dry. Then add much more joint lube or associated green slime and go. I would like to try a spray on joint lube like Inox Mx8 http://www.inoxed.com/mx8.htm
Anyone use this stuff?
Benzaah is offline
Old 06-02-2010, 10:14 AM
  #2267
gonzo416's Avatar
Trader Rating: 39 (98%+)
are there any cvd pins that come with a flat spot on them out there?
gonzo416 is offline
Old 06-02-2010, 11:24 AM
  #2268
Jonny Aird's Avatar
http://www.teamxray.com/teamxray/pro...at%20Spot%20(2)
Jonny Aird is offline
Old 06-02-2010, 12:12 PM
  #2269
Way2Evl's Avatar
http://www.amainhobbies.com/product_...-w-Flat-Spot-2
This should fix your problem if the pins came out. You could also use some shrink wrap in addition to this.
http://www.amainhobbies.com/product_...at-Shrink-Wrap
Way2Evl is offline
Old 06-02-2010, 12:25 PM
  #2270
Thinking of buying the spec r gear diff. How are you guys liking it so far?
immrwright7 is offline
Old 06-02-2010, 12:31 PM
  #2271
RC MARKET's Avatar
XRAY
http://rcmarket.com.hk/advanced_sear...nrntm5llvilel6
or
TOP $3 8pcs
http://rcmarket.com.hk/product_info....oducts_id=3729
RC MARKET is offline
Old 06-02-2010, 02:57 PM
  #2272
For the ECS I also build them dry, blue locktite on the threads. Let dry for a few hours and then lube with Hudy graphite grease. 10mm heatshrink around the uni only over hang heatshrink 1-2mm each side. Heatshrink has saved me a few times from loose or broken pins ending a race.
To re-lube, wash in Shellite, then compressed air to dry, re-lube with Hudy graphite grease. I NEVER undo the set screws after the first time Locktite unless the pin breaks (which does happen oscasionally in 10.5 & mod) or replacing bent shaft etc.
I have tried spray on lube (some German bearing lube, $100 a can), and it's pretty good if you don't want to remove the heatshrink all the time.
gameover is offline
Old 06-02-2010, 05:32 PM
  #2273
Alum steering block for T3.
Anyone uses the alum steering block on their T3, will it has noticeable less steering than the plastic Ver 2 steering block that come with T3?
I am no sure why I have major problem breaking the T3 plastic steering block just like cheap toy car plastic. No issue with my T2009 before for playing in the same track, in fact, never break 1 at all in T2009.
MIKA is offline
Old 06-02-2010, 06:15 PM
  #2274
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Are you buying the foam car knuckles or the med flex ones? Ive seen some crazy t3 crashes with no broken parts. Ive never used the alu knuckles so I cant comment on those
BlackedOutREVO is offline
Old 06-02-2010, 06:24 PM
  #2275
Aluminum knuckles will make the car push. Are you using the "M" knuckle or the "H"? You want the H (Hard) for all conditions with rubber tires.
punkboy is offline
Old 06-02-2010, 06:49 PM
  #2276
Dear Sir,
I am using the rubber spec "M" knuckle, as my LHS never stock the "H" type.
I have broken 3 knuckles in just 2 days of play which I didnt think I was abusing the car at all. Worst of all, no stock for the "M" knuckle from my LHS at the moment, they only have the alum one in stock.
Like I said earlier, never have any problem with the older T2009, never break a single part before.
Thanks. I guess I will wait for the re-stock for the plastic knuckles.
MIKA is offline
Old 06-02-2010, 08:45 PM
  #2277
Dear Sir,
Where is it breaking?
The only time i have seen issues is when the screws used on the top and bottom are not long enough, they should thread 98% the way through to where the axle sits. If its only holding on by a few threads you will pull out the top screw especially very easy.
Besercoe is offline
Old 06-02-2010, 10:11 PM
  #2278
Trader Rating: 39 (100%+)
Hey guys, just a quick question with regards to Xray shock oil... the little bottle hat I have says 350 cSt... is this the same as 35wt?
any help appreciated.
$$$... is offline
Old 06-02-2010, 10:31 PM
  #2279
Dear Sir,
It only break at the bottom side. Do you have any experience running the alum steering block?
MIKA is offline
Old 06-02-2010, 10:34 PM
  #2280
nitro rat's Avatar
Trader Rating: 5 (86%+)
Hey guys,
Just after some help with my T3. The car is very fast but lacks rear traction when exiting a corner or entering a corner. Im racing on an asphalt tight track with low traction. Coming out of a corner the rear of the car just wants to let go. Im running Kit setup with 30wt shock oil all around (%100 Rebound) i have moved the front and rear shocks in 1 hole from kit set up. I have gone to 1mm shims all around on the hubs. Front sway bar is now a 1.3 Everything else is as per kit set up. As i said the car is fast and i dont wanna compromise its performance by changing alot just to gain rear end traction. is there anything i can do to get somemore rear end traction?
Thanks heaps Guys
nitro rat is offline
