Old 05-26-2010, 12:02 PM   #2191
bigdadracing's Avatar
thanks ark for the info.I just ordered one
also I just ordered a spec r gear diff whats the genral thought on what oil to run in it. thanks for any thoughts on my question
rcamerica/xray/ team powers/bsr tires/ slapmaster tools/ bigdads garage/cheep beer/ mykeart paint works / team pop a top
suport your local hobby shop because ebays track is hard to find !!!!!!!!
Russ Jacobson
bigdadracing is offline   Reply With Quote
Old 05-26-2010, 12:33 PM   #2192
jammincrtjames's Avatar
Anybody running the HPI springs? If so, which ones for asphalt. Anybody have a part number?
NEXUS RACING www.nexusracing.com | FANTOM RACING www.fantomracing.com
ORCA www.orcarc.com | TURTLE TRAX / www.turtletraxraceway.com
"If you're not first...you're last!"
jammincrtjames is offline   Reply With Quote
Old 05-26-2010, 01:47 PM   #2193
Originally Posted by F1fletch View Post
Question guys. I know the front spools are widely used now but I am wondering how the car handles with a front diff. Does it make the car more forgiving? Since you can adjust it for track conditions I am just wondering if it is better (unless the track is just stuck).
Opinions??
With a Diff the car will steer in a lot better, but because of the potential of slipping, the Diff doesn't always help the car pull out of the corner, where a spool puts down all the power you apply.
I'd be interested to see how well it works if someone puts one of these gear diffs in the front of their T3 with some 200K or 300K oil...
punkboy is offline   Reply With Quote
Old 05-26-2010, 01:50 PM   #2194
HPI6548 is the Pink spring, which some guys use for the front. I've never used any other HPI spring, so not sure about others.
Old 05-26-2010, 02:02 PM   #2195
F1fletch's Avatar
I keep hearing about these gear diffs, what is the news on them are they superior? Where can you buy them?
Yokomo BD8/YR-10F
F1fletch is offline   Reply With Quote
Old 05-26-2010, 03:04 PM   #2196
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Ball diffs will slip as they rely purely on the friction between the balls and rings for power transfer. A gear diff wouldn't allow for loss of power put down unless you got the inside wheel light enough to where it would spin up. Open gear differentials will bias torque to the wheel with least traction. You wouldn't need 200k+ oil to prevent that, perhaps only 50-100k tops. A light-weight torsen differential would be fun to have though, as it biases torque to the wheel with most traction.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 05-26-2010, 06:07 PM   #2197
i think if you are running it in the rear somewhere between 1k-5k oil would be the answer. I agree on trying it in the front with heavier oil, i hope the seals are good, i always hated leaking front diff o-rings in 1:8 offroad. The inside front can really unload on power around sweepers.
I should have a couple to try in 2 weeks.
gameover is offline   Reply With Quote
Old 05-26-2010, 07:51 PM   #2198
Need some input here fellas.
I'm currently in the running a Cyclone TC that I bought sealed and put together myself. I planned on using this car to compete at my local track. Upgraded to DCJ dogbones and the car runs great! However after running a friends T1 EVO2 i've decided that the T3 is a better comp car. Can you give me some pro's and con's with this car and what should be purchased as spare parts?
immrwright7 is offline   Reply With Quote
Old 05-26-2010, 08:26 PM   #2199
cyclone x's Avatar
the hpi blue springs are really nice also
Chase Chandler
Sponsors:HOTBODIES Express .The Track. Stevo Racing
Cars: VE8, F104 PRO, B4.1, HPI BLITZ, Losi SCTE
cyclone x is offline   Reply With Quote
Old 05-26-2010, 08:35 PM   #2200
No doubt a gear diff up front would require some setup adjustments to make it work. 200K was just a shot in the dark based on what guys are doing with the NT1 and I wouldn't doubt we could get away with a lighter oil. Just throwing the thought out there as it could be something to seriously look into. Unfortunately I don't have the time or ability to test these things like I'd want to.
I'm definitely interested to hear any feedback anyone has from testing something like this.
Old 05-26-2010, 08:41 PM   #2201
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I have one coming. I may try it. Lets hope it doesn't leak ...
Old 05-26-2010, 11:25 PM   #2202
i use Gold front and silver rear , sometimes silver/silver
sidecarphil1 is offline   Reply With Quote
Old 05-26-2010, 11:49 PM   #2203
J.Dy's Avatar
Since we're on the topic of hpi springs, are the all gold spring the same rate as the black with gold paint? It's the same part number but just want to make sure nothing changed when they switched to black. Thanks.
http://www.amainhobbies.com/product_...15mm-6-Coils-2
R1wurks Competition Products
ABC Hobby USA
J.Dy is offline   Reply With Quote
Old 05-27-2010, 12:32 AM   #2204
RC MARKET's Avatar
Yes buy it now !
Japan HPI was all sold out !
Best shock spring
RC MARKET is offline   Reply With Quote
Old 05-27-2010, 01:34 AM   #2205
Way2Evl's Avatar
What about the Tamiya 84008. A lot of people are running these and seem to like them. Does anyone have them and can you report on what you like about them?
X-Ray T3|Tekin|KO Propo|Spektrum|Thunder Power|Hyperion|Sorex
www.speedworldraceway.com
Way2Evl is offline   Reply With Quote
Xray T2'008 Drew_Cat Electric On-Road 1941 01-25-2016 12:36 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
XRay T3 (spy pics) syndr0me Electric On-Road 33 07-13-2010 04:43 PM
where to get xray?? 2qwik Northwest Racers 20 10-10-2009 03:02 AM
New Xray T3!!! Jammin'Trey Electric On-Road 39 10-09-2009 12:40 PM
