Old 05-21-2010, 09:15 PM   #2146
yodace's Avatar
R/C Tech Charter Subscriber
Thts pretty cool... are you using it if so how do u like it?
yodace is offline   Reply With Quote
Old 05-21-2010, 09:18 PM   #2147
Potoczak's Avatar
Trader Rating: 112 (100%+)
No not yet, about to place an order for one.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 05-21-2010, 09:51 PM   #2148
Professor's Avatar
Originally Posted by Potoczak View Post
at 150grams will u not have to add a lot of weight to the opposite side to counter balance this ????????
VBC RACING AUS--HOBBYWING--RC MAKER--
MAD GRAPHICS--BITTY DESIGN
Professor is offline   Reply With Quote
Old 05-21-2010, 11:11 PM   #2149
hanulec's Avatar
Trader Rating: 27 (100%+)
i'd recommend this alternate part instead..
http://www.egrracing.com/shop/xray-t...te-p-2652.html
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 05-22-2010, 12:28 PM   #2150
Potoczak's Avatar
Has anybody tried these yet? How is the fit and finish? http://www.egrracing.com/shop/alu-70...t3-p-3694.html
Pete Potoczak
Old 05-23-2010, 06:52 AM   #2151
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
ha ha, ATM...
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 05-23-2010, 08:29 AM   #2152
hanulec's Avatar
I haven't tried them. Atomic makes some very nice swaybar mounts.
For rubber tire racing I don't think this is necessary. Hitting stuff will always cause cars to break... or worse yet, have parts bend that will then cause handling issues.
Running a hard bumper - xray or parma - should be good enough. With all metal steering blocks I've seen issues with either screws backing out or people destroying the smaller bearings that you use in them. If you want to make a front end a little more crash resistant I'd recommend installing either a kydex bumper (it will crack and require replacing every so often) under the foam bumper or metal c-hubs (thsese will bend but probably not break)
Old 05-23-2010, 08:30 AM   #2153
hanulec's Avatar
Originally Posted by rx7ttlm View Post
ha ha, ATM...
That ain't right...
Old 05-23-2010, 11:44 AM   #2154
Potoczak's Avatar
What is the link for the swaybar mounts, i would be interested in a set. Thanks
Pete Potoczak
Old 05-23-2010, 01:28 PM   #2155
hanulec's Avatar
Atomic p/n EPO-007
http://www.rcatomic.com/atomic/index...mart&Itemid=92
Old 05-24-2010, 02:28 PM   #2156
What servos are everyone running? I've got an XP 1015 from an offroad car installed but it's not great. The widest mounting holes seem a bit too wide and the narrow mounting holes are too narrow. Especially when trying to use the ser-boy washers. Thanks.
g26er is offline   Reply With Quote
Old 05-24-2010, 02:36 PM   #2157
I know it's a bit of work, but when I run into this problem I normally just use a small jeweler's file to remove the material between the 2 rear-most holes and then blend the countersinking from hole to hole making a nice countersunk slot. Then you can put the screw/mount wherever you need it.
Right now I am running a Futaba S9551 w/serboys and using the widest holes. Fits perfect.
punkboy is offline   Reply With Quote
Old 05-24-2010, 02:36 PM   #2158
nice!
Old 05-24-2010, 02:37 PM   #2159
ha ha, ATM...
smh...
Old 05-24-2010, 03:35 PM   #2160
PrimeAKF11's Avatar
Guys,
I have a T3 on the way for a big local race next weekend and am trying to stock up on parts.
I'll be buying the usual suspension arms, c-hubs etc, but is there any specific part on the car that breaks a lot?
Best rubber tires>> www.SweepRacingUSA.com
For your Team Magic G4 parts needs>> www.bluesunhobbies.com
HD Videos of Blue Diamond Onroad Raceway!!! 200ft+ straight of fury!! >> http://www.rctech.net/forum/racing-forum/406318-2nd-annual-pete-johnson-have-nice-day-memorial-race-5.html
PrimeAKF11 is offline   Reply With Quote
Xray T2'008 Drew_Cat Electric On-Road 1941 01-25-2016 12:36 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
XRay T3 (spy pics) syndr0me Electric On-Road 33 07-13-2010 04:43 PM
where to get xray?? 2qwik Northwest Racers 20 10-10-2009 03:02 AM
New Xray T3!!! Jammin'Trey Electric On-Road 39 10-09-2009 12:40 PM
