Old 04-12-2010, 03:24 PM   #1921
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by ByteStream View Post
Thanks for the info, i used the applicators in the link below .. worked really well .. they are like sponges and soak up the CA and don't drip.
Try these next time -
http://www.totalbeauty.com/reviews/p...up-applicators
I have thought about trying those. Its just so much easier to drip the ca right on the cf (like the CRC way) With a Q tip, or those little things you have to make so many coats to really build up the ca. But thanks for the link, I will have to try those sometime Probably alot easier to do smaller parts with those
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 04-12-2010, 06:57 PM   #1922
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
I use the qtip method, but it takes 5 years to get it done.. lol. About the only thing I do it with anymore is nitro..
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 04-12-2010, 07:11 PM   #1923
cyclone x's Avatar
i came from a race this past weekend and it was bad i clipped a turn going into the sweeper and hit the wall breaking a roll center block and breaking a shock body
Chase Chandler
Sponsors:HOTBODIES Express .The Track. Stevo Racing
Cars: VE8, F104 PRO, B4.1, HPI BLITZ, Losi SCTE
cyclone x is offline   Reply With Quote
Old 04-12-2010, 10:28 PM   #1924
rx7ttlm's Avatar
wow... I have broken a shock body and bent some things at the last two day. Someone punted me (read super punt) and I flew into a hangar door. But with a hit like that anyone's car would break... But sweeper breaking all that.. ouch
Old 04-13-2010, 08:35 AM   #1925
Originally Posted by ballsagna View Post
my feeling is that you have quite a few things working against each other. for example, you have small amounts of camber (so you probably have good forward bite generated by the tires on straights , but less side grip generated by the tires in turns). therefore you are removing screws from the topdeck to add grip in turns. that overcompensates so you add more dual rate or ackerman, etc.
in my opinion, removing screws from the topdeck is probably the worst change to make on this car. it gets lazy, pushes, has too much grip, etc. throw all the screws in the top deck and see what happens. then start trying some of the changes that have been suggested.
anyway... my suggestions were just to try to get you a little closer to the set up other racers are running or more familiar with...might make it easier for all of us internet setup kings (or queens) to help fix your issue, without actually seeing or driving your car.
tried every tging you said and it made the car worse !!
I did lower the outer camber adjusters from 4mm to 2mm and 2 degrees of toe on the rear this msde the car rotate better but it was too nervous , so back to the originsl set up and changed the turbo delay on my tekin and this allows my to get throught the fast corner before the turbo comes in pushing me wide
i also bought an R9R today to try , this is supposed to be a goid body for steering
sidecarphil1 is offline   Reply With Quote
Old 04-13-2010, 10:38 AM   #1926
Johnny Wishbone's Avatar
Phil YGPM.
Old 04-13-2010, 11:00 AM   #1927
wat do people think bout this will it b any better then the kit chassis
http://www.exotekracing.com/EXOTEK_N.../4/12_XR3.html
stcc ssb tires, ko ,gm motors, demon products lipos, hobbywing speedo
mwoods is offline   Reply With Quote
Old 04-13-2010, 01:07 PM   #1928
Why ???
Whats wrong with the original chassis ??
I have only lost one lipo out of my T3 and it was pilot error , big crash !!
I dont even use the lipo bracket things , just good quality battery tape , my car is balanced and weighs 1357g
So again Why ???
Old 04-13-2010, 01:26 PM   #1929
Why ???
So again Why ???
im not going to get one just wanted if it will b better, i no theres nothing wrong with the original chassis .
wats with the why and ??????
Old 04-13-2010, 01:44 PM   #1930
sorry my outlook is , if it aint broken then dont try to fix it
these companys make stuff to be better then the original but i think the original is best
dont mean to be offensave
Old 04-13-2010, 01:57 PM   #1931
none taken lol.. i read somewhere it shud be faster, there isnt nothing wrong with kit just want to that little adge to make it better
Old 04-13-2010, 03:13 PM   #1932
Chris Adams's Avatar
If this lipo chassis is anything like the cyclone one, it will be stiffer than the origional xray chassis. Its a pretty solid tuning option. I know that I already use the chassis standoffs on everything except for a jaco blue setup.
TEXASEOS.net, RcAmerica, Xray, Hudy, Protoform, Orca, Avid, 2mm Designs, Ulti Tires America
Texas EOS 2018!
Chris Adams is offline   Reply With Quote
Old 04-13-2010, 04:24 PM   #1933
cyclone x's Avatar
yeah it was a hard hit and i was just like wow but its all good my local shop carrys so much xray so im fine. great part support
Chase Chandler
Old 04-13-2010, 04:55 PM   #1934
Trader Rating: 18 (100%+)
Send a message via AIM to Roberto Falcon
http://www.rctech.net/forum/r-c-item...-t3-parts.html
T3 forsale eu edition
Roberto Falcon is offline   Reply With Quote
Old 04-13-2010, 09:12 PM   #1935
Pablo Diablo's Avatar
Send a message via Skype™ to Pablo Diablo
I believe the narrower Exotech chassis will not drag on the edges. I also like the way it is symmetrical. I have seen a friends Cyclone running a Exotech chassis and it is a very nice piece.
Paul H
Losi Type R | Xray T3 | CRC Gen XL | CRC Gen X 10 ME(Messiah Edition) | Black Diamond
www.FlyingFoxRC.com | Advanced Electronics | Team CRC | Factory Messiah
Pablo Diablo is offline   Reply With Quote
Xray T2'008 Drew_Cat Electric On-Road 1941 01-25-2016 12:36 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
XRay T3 (spy pics) syndr0me Electric On-Road 33 07-13-2010 04:43 PM
where to get xray?? 2qwik Northwest Racers 20 10-10-2009 03:02 AM
New Xray T3!!! Jammin'Trey Electric On-Road 39 10-09-2009 12:40 PM
