Old 04-03-2010, 04:01 AM   #1831
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Originally Posted by sidecarphil1 View Post
hey fellas
i am after a bit of set up help on a mid grip Asphalt track
this is my current set up , although i am struggling on corner entry , i have MASSIVE amount of rear grip but a lot of front push
2 degree rear camber
1.5 degree front camber
2 degree inboard rear toe 1 degree on the ugrights
1 degree front toe out
all the flex screws on the upper deck removed
inner acceman all the way rearwards then 3 clicks forward
2 hole suspension arms for the shocks
lower shock mount outer hole
300 oil in the shocks
droop 5.5mm front 5mm rear (dropped the front from 6mm to gain some front grip)
ride height of 5mm
HPI gold front springs
HPI silver rear springs
kit the rest
sweep EXP30 tyres
Try going to 400-450 oil and put the rear posts in and silver/2.8 springs all round.
Rest looks fine. This should help with your issues
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 04-03-2010, 06:40 AM   #1832
Skiddins's Avatar
hey fellas
ride height of 5mm
kit the rest
sweep EXP30 tyres
350-400 rear oil, 450-500 front.
If you have plenty of rear grip you could reduce rear toe to 2deg etc that will definietly help with turn in.
1.15mm front shims at wishbone.
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 04-03-2010, 07:30 AM   #1833
thanks for the tips guys
i am changing the oil now as this was sudested buy a few of you and i dont like doing them at the track side if i can avoide it ,
i have various springs from Xray but due to a slight oversight on my part i ordered 2 sets of 2.6 and no 2.8's so if someone wants a swap let me know LOL
i will let you know how i get on (if the rain stops)
sidecarphil1 is offline   Reply With Quote
Old 04-04-2010, 05:32 PM   #1834
dal bains's Avatar
Trader Rating: 35 (100%+)
Will the old prs Pro lite touring spurs fit on the t3?
RCAMERICA-XRAY-HUDY
dal bains is offline   Reply With Quote
Old 04-04-2010, 06:45 PM   #1835
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Well I joined the dark side...
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 04-04-2010, 07:11 PM   #1836
Very Nice
Antoni Caretti
Old 04-04-2010, 07:40 PM   #1837
P.I.M.P's Avatar
Trader Rating: 14 (100%+)
hi guys can any tell me what other parts or work that can make the ball diff last in mod more then two runs the xray diff seem to not last as long between rebuilds.im not a newbie there must be something im missing
Vbc wildfire D06
clinton livingstone
P.I.M.P is offline   Reply With Quote
Old 04-04-2010, 07:55 PM   #1838
hanulec's Avatar
Trader Rating: 27 (100%+)
its hard to make the diffs last with full on modified power. i know that Paul L. rebuilds diffs every four runs. additionally, he replaces the thrust bearings about 7 times more frequently than the rings and balls. i've been mostly running 13.5T indoors - which has some wear on thrusts as compared to 17.5T. i'd just suggest you get a ton of thrust bearings - try different brands - you might have more luck w/ other types. i've been using some from mcmaster with good success.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 04-04-2010, 08:05 PM   #1839
:drool:
punkboy is offline   Reply With Quote
Old 04-04-2010, 08:16 PM   #1840
Cribbin's Avatar
i use ceramic balls and schumacher grease and my diff has had about 20 runs in mod with a 4.5 and it still feels like butter. also make sure its not slipping, as this will make it go bad after one run.
Bro-Kin Racing Group
X-Ray T3
X-Ray T2 '007
Castle Hill Raceway
Futaba LRP Tekin
Cribbin is offline   Reply With Quote
Old 04-04-2010, 08:28 PM   #1841
Chris Adams's Avatar
Looks awesome. Might want to grease up the front cvd's. Looks like your getting some wear on them.
TEXASEOS.net, RcAmerica, Xray, Hudy, Protoform, Orca, Avid, 2mm Designs, Ulti Tires America
Texas EOS 2018!
Chris Adams is offline   Reply With Quote
Old 04-04-2010, 08:32 PM   #1842
Thanks guys
Chris, its just weird in the picture. I was looking at that thinking the same thing, and went and double checked my car and its not there lol. It was dark in my house and I had to bump the brightness up, so I think thats what made it do that
Out of curiosity how many of you guys run the stock plastic out drives? Mine seem fine so far with a 4.5. But I havent ran it a ton so far
Old 04-04-2010, 08:50 PM   #1843
Slotmachine's Avatar
Send a message via MSN to Slotmachine
hey fellas
ride height of 5mm
kit the rest
sweep EXP30 tyres
You have not mentioned roll centers........... These are very important so is the wheelbase! Use low roll center blocks in the front and make the top link as long and as flat as you can get it and as flat as possible.
On the rear try high roll center and angle the upper arm with a 1 or 2 mm. shim under it on the rear hub. Droop also effects steering , more chassis lift in the rear off power will give more steering entering a corner.....
Paul Rush............
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 04-04-2010, 10:35 PM   #1844
The problem with the diff is all in the grease you use. You need to use a thicker grease as anything thin will just "spit" out. If you rebyuild a diff and only in one run it is dry, check the inside of your dust covers and the outside of your pulley. All the grease should be there. Try and use something thick like schumacher or Corally grease.
Thanks guys
The plastic spool outdrives are awesome. They last quite a while. if you get worried, put a tiny bit of black grease on the pins. Most prefer tham over the aluminium ones. Besides there not black The plastic ones are heavier than the aluminium ones with blades.
Antoni Caretti
Old 04-04-2010, 10:39 PM   #1845
Fred Hubbard's Avatar
Actually they both weigh the same. I just weighed them both last week but for the life of me the actual number escapes me at the moment!
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Xray T2'008 Drew_Cat Electric On-Road 1941 01-25-2016 12:36 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
XRay T3 (spy pics) syndr0me Electric On-Road 33 07-13-2010 04:43 PM
where to get xray?? 2qwik Northwest Racers 20 10-10-2009 03:02 AM
New Xray T3!!! Jammin'Trey Electric On-Road 39 10-09-2009 12:40 PM
