Old 03-31-2010, 06:48 PM   #1816
lowcel's Avatar
Trader Rating: 80 (100%+)
Originally Posted by Fred Hubbard View Post
Unfortunately there aren't any alternatives.
Originally Posted by Johnny Wishbone View Post
I haven't found anything yet, Assoc, Tamiya and Losi aren't exact replacements, all are either too tall, too sloppy, or too small.
Thank you both very much. It probably sounds petty but over charging for items like this are what could possibly keep me from purchasing another xray. So far the only touring cars I have owned have been xrays (2-t2's, 1-t2'008, 1-t3) but I might have to consider another brand next time.
Team Whopperjawed Racing
This hobby is going to $5 me to death.
lowcel is offline   Reply With Quote
Old 03-31-2010, 07:43 PM   #1817
Johnny Wishbone's Avatar
Thats why I walk the track looking for the remains of the crash everytime I take a front corner off.
Old 03-31-2010, 07:46 PM   #1818
Originally Posted by Korgae View Post
We still need to weigh it as well...
Stock diff = 20 grams
Gear diff = 38 grams (regular weight out drives, fluid filled)
Old 03-31-2010, 07:47 PM   #1819
lowcel's Avatar
I did but I had no luck.
Old 03-31-2010, 08:19 PM   #1820
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Default Asphalt setups
Here are some good asphalt setups from some Australian drivers. I have personally found the car to work well with all 3 stiffner posts in. All of these setups are pretty different so take your pick
http://forum.teamxray.com/xform/inde...=1368&setup=t3
http://forum.teamxray.com/xform/inde...=1226&setup=t3
http://forum.teamxray.com/xform/inde...=1259&setup=t3
http://forum.teamxray.com/xform/inde...=1227&setup=t3
Those are all Mod setups BTW
Antoni
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 03-31-2010, 08:28 PM   #1821
Antoni
Just curious if any of those drivers tried 2* c-hubs. Also wondering what if anything is being used to prep the track? Thanks
Old 03-31-2010, 08:34 PM   #1822
I dont think they tried the C-hubs, I could be wrong though. Those setups were at 3 different tracks. I know that the tracks were cleaned. The one setup by Darrell Khemlani, the track they raced out was prep'd, but there was a dust storm and that didnt quite go so well for the track....The drivers were all wearing goggles Im not 100% sure, but i think the tracks were all painted with Boral paint Or at least 2
Antoni
Antoni Caretti
Old 03-31-2010, 10:26 PM   #1823
Suspended
Trader Rating: 14 (100%+)
Originally Posted by Skiddins View Post
Because 'Wt' is not a standard and cSt is (or supposed to be) maths will be useless.
The numbers you have as 'weight' are too low as the cst gets higher.
The problem is weight is a BS term that has no standard where cSt is.
Weight actually ramps up as the numbers get higher compared with cSt.
300 should be around 25wt where 600 is around 40-45wt
you are correct about weight not being standard. we throw that term around with motor oil for you car too. the W actually stands for "winter" and has to do with performance at a standard cold temperature condition.
Just to clarify, the weight numbers in bold were provided by xray. the non-bold were predicted. what you called ramping was taken into account because i didnt generate a linear model....its actually an exponential fit.
you can be confident my numbers for xray silicone oils are correct..... and how they relate to another brand is surely debateable. i was definitely not trying to compare 'weights' between brands, but only provide a meaningful point of reference for xray owners who use xray silicone oil.
I never apologize... I'm sorry, but that's just the way I am
ballsagna is offline   Reply With Quote
Old 04-01-2010, 04:16 AM   #1824
Have you guys tried the Capricorn spider gears? I hear their gears are a direct fit for the NT1 diffs, and they are plastic. I've also heard their pins are aluminum and will work as well. Might be something worth looking into.
punkboy is offline   Reply With Quote
Old 04-01-2010, 10:33 AM   #1825
JayL's Avatar
but then you would have non-xray parts on your car and if you read pages 20-40 you will find out that's bad, lol
Asphalt 120x60 sprayed, 4.5t lipo, rubber tires, EU edition all top deck screws except front post stock kit setup
need alittle more on and off power steering, rear is planted
little less rear toe?
fronts seem alittle overworked maybe more rear weight or droop?
JayL is offline   Reply With Quote
Old 04-01-2010, 02:47 PM   #1826
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Yup, that's one of the key parts for me. I am waiting on them to come in for my NT1 first. Durability test with nitro car first, then overall test for T3 . The cool think about the diff gears etc is they should be stocked by a couple USDM hobby shops
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 04-01-2010, 03:26 PM   #1827
RC MARKET's Avatar
HK before 1 year many peoples tested ,
short life !
RC MARKET is offline   Reply With Quote
Old 04-01-2010, 04:54 PM   #1828
short life !
How short? A day, month, half a season?
Old 04-03-2010, 01:49 AM   #1829
hey fellas
i am after a bit of set up help on a mid grip Asphalt track
this is my current set up , although i am struggling on corner entry , i have MASSIVE amount of rear grip but a lot of front push
2 degree rear camber
1.5 degree front camber
2 degree inboard rear toe 1 degree on the ugrights
1 degree front toe out
all the flex screws on the upper deck removed
inner acceman all the way rearwards then 3 clicks forward
2 hole suspension arms for the shocks
lower shock mount outer hole
300 oil in the shocks
droop 5.5mm front 5mm rear (dropped the front from 6mm to gain some front grip)
ride height of 5mm
HPI gold front springs
HPI silver rear springs
kit the rest
sweep EXP30 tyres
sidecarphil1 is offline   Reply With Quote
Old 04-03-2010, 03:59 AM   #1830
Mr. MR4's Avatar
Try one step softer front spring or 2 deg front camber - it should help.
Xray T4'16 HobbyWing Xerun 120A V3.1
Xray X1'16 HobbyWing Justock
Yokomo R12C3 HobbyWing Xerun V3.1
Mr. MR4 is offline   Reply With Quote
Xray T2'008 Drew_Cat Electric On-Road 1941 01-25-2016 12:36 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
XRay T3 (spy pics) syndr0me Electric On-Road 33 07-13-2010 04:43 PM
where to get xray?? 2qwik Northwest Racers 20 10-10-2009 03:02 AM
New Xray T3!!! Jammin'Trey Electric On-Road 39 10-09-2009 12:40 PM
