Old 03-29-2010, 08:01 PM   #1771
Johnny Wishbone's Avatar
Originally Posted by witz_dan View Post
ok so I posted up on xray so please take a look.
Aric, i understand the traction issues at underground. Im asking more of a general setup question that I am having problems with. A car that both pushes slightly at high speed but then gets loose at low speeds. I wont be at the track this weekend its easter sunday. I will be heading to LH on saturday though.
Dan
You need to adjust your droop settings so your getting less weight transfer under braking. Try 2.5mm orh in the front and 1.5mm orh in the rear.
Old 03-29-2010, 08:02 PM   #1772
witz_dan's Avatar
Trader Rating: 25 (100%+)
Originally Posted by hanulec View Post
dan - are you sure your setup sheet is live/public? what login name did you post it under?
i didnt enter an entire sheet though i will if it really helps heres my post right now.
http://forum.teamxray.com/viewtopic.php?t=10347
witz_dan is offline   Reply With Quote
Old 03-29-2010, 08:03 PM   #1773
The NT1 gear diff conversion in the rear works very well, no problem all weekend long and very consistant performance.
Old 03-29-2010, 08:09 PM   #1774
hey guys
so I ran my T3 for the second time today and was having a comfusing issue for me.
car started out with a really bad push at corner entry to early mid corner.. so as i slowed it would push push push then the front would grab and the rear would break loose. I pust 6* caster up front and the car handled much better but pretty much only when I drove it very aggressive. if I got off my line and slowed to much the car would hook in hard and get loose. still with a slight push.
running pretty much the stock setup with the 6* casters in 17.5
check for tweek and all other settings were good. so what can i do to keep the rear from kicking out if i get off the throttle to fast. this was touch on a little about 20 pages back but faded off.
thanks
I had the same problem with my T3. The 52 mm shafts were binding when the rear suspension was compresed. You can get the 50mm shafts or move the rear arm out 1 mm. This cured my problem.
Lugnutz1 is offline   Reply With Quote
Old 03-29-2010, 08:12 PM   #1775
witz_dan's Avatar
lugnutz how did you figure out that one? ill take a look at that interesting
ok johnny that makes alot of sense as well..
though I thought that dropping the rear arms to the lower hole would raise my roll center giving me less rear traction? am i wrong about that
Old 03-29-2010, 08:13 PM   #1776
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Originally Posted by Johnny Wishbone View Post
The NT1 gear diff conversion in the rear works very well, no problem all weekend long and very consistent performance.
send me one , I am at 19 credits this term (F-ing school of engineering... ).
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 03-29-2010, 08:13 PM   #1777
rx7ttlm's Avatar
ygpm, ditch 6 degree blocks, go back to 4. 550 cst front shock oil with three holes, check your steering throw left degrees, and right degrees. If your struggling, turn the dual rate down if your a lock to lock driver (big changes first to see if that's whats happening..try -20% first and then add or subtract as needed) sounds like the car might actually be pushing, but you think its loose cause when the tires finally grab its hooking, and spinning out. The ppl that I have seen struggle with the t3 that's usually whats going on or a couple of the components. The car has a HUGE sweet spot so if the car is way off, look for something in the car that's way off.. also look for my previous post about drive shaft plunge vs lots of rear camber, and low rear toe values
4 degree blocks are a great place for 90% of the carpet racing, and 550 front oil will help the car feel a little bit more mellow.
Old 03-29-2010, 08:14 PM   #1778
TRXRACER99's Avatar
Trader Rating: 10 (92%+)
thing that would help a lot is saucing the whole front tire. I hope your not running 100% dual rate i run about 60% on mine
TRXRACER99 is offline   Reply With Quote
Old 03-29-2010, 08:18 PM   #1779
witz dan, just looked at your set up, same one I had on the car. Check the black drive shaft cups they might have marks on them from binding when they bottom out.
Old 03-29-2010, 08:29 PM   #1780
hanulec's Avatar
Trader Rating: 27 (100%+)
dan - increasing your dampening should help too. i suspect you have a ton of chassis rub marks w/ the 350wt - your car is probably on the ground in the high speed sweeper. i'd also recommend bumping up the spring rate on carpet. i just tried 3.4 front / 3.0 rear - it was pretty good .. but would probably only work if grip comes up. standing up your shocks in the rear should also improve the 'cut' of the car at high speed.
i've been running a wide rear end setup most of the season with my t3 - added an extra 1.5mm everywhere in the rear. the wide rear will help improve overall stability too.
how much dual rate do you have in your car? you might just have too much throw in hopes of getting through the sweeper and it is causing the car to be loose in the infield. i'd also recommend equaling your front & rear camber to 1.5mm and then removing some dual rate.
mike
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 03-29-2010, 08:29 PM   #1781
rx7ttlm's Avatar
It also depends on how you drive.. Some people are lock to lock drivers.. I started out that way.. but now I run more dual rate and just use the steering that I need. Sauce isn't a huge change btw.. lol
Old 03-29-2010, 08:32 PM   #1782
TRXRACER99's Avatar
trust me running on a track with about 0 traction you need about as much as you can get
Old 03-29-2010, 08:32 PM   #1783
rx7ttlm's Avatar
mike
hey, are you going to fuel onroad nats?
Old 03-29-2010, 08:34 PM   #1784
pcar951's Avatar
Trader Rating: 19 (100%+)
Gary, you gotta hack up a pulley to do this though right?? Korgae mentioned it at the last WCICS. What other mods are required, do you have to run 50mm shafts?
pcar951 is online now   Reply With Quote
Old 03-29-2010, 08:35 PM   #1785
rx7ttlm's Avatar
true, but it depends on whats available for overall traction. The biggest component to making a car fast for me, is balance.... the grip can lick balls but just as long as your not drifting or plowing with the front. Lap times can be decent. Then you just mess with stuff for corner speed . That's how I do it anyhow.
Xray T2'008 Drew_Cat Electric On-Road 1941 01-25-2016 12:36 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
XRay T3 (spy pics) syndr0me Electric On-Road 33 07-13-2010 04:43 PM
where to get xray?? 2qwik Northwest Racers 20 10-10-2009 03:02 AM
New Xray T3!!! Jammin'Trey Electric On-Road 39 10-09-2009 12:40 PM
