Old 03-21-2010, 06:42 PM   #1741
RAL
RAL's Avatar
Trader Rating: 60 (100%+)
Originally Posted by Slotmachine View Post
If anyone here is looking for inexpensive screws go here http://www.fastener-express.com/
Great hardware and prices.
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 03-21-2010, 07:31 PM   #1742
hanulec's Avatar
Trader Rating: 27 (100%+)
Originally Posted by Pablo Diablo View Post
I just measured the thickness of my T3 EU chassis where it is milled under the motor. It's only 0.5mm thick which seems way too thin to me. Pleavious Xrays I've had are 1.5 mm in this area. Can anyone tell me how thick theirs is so I can be sure I have a faulty chassis.
nope - that sounds right. less meat is needed to get the motor (and the CG) as low as possible..
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 03-21-2010, 07:34 PM   #1743
hanulec's Avatar
Originally Posted by alecladanga View Post
hi guys
Apologies in advance if this question has been asked so many times, I've checked the cross reference for parts file in the xray website but couldn't get a definitive answer.
I have an 009 and I'm planning to move to 1.9 drive ratio and the shop here carries mostly t3 parts. My question is will the rear and front drive belts of the t3 fit in the 009 given that the 009 kit has already changed to a 38T pulley?
thanks in advance
the T2'009 runs at 1.9 when you install the motor forward conversion. i don't have an 009 to verify what could happen w/o the motor forward conversion. you might wanna check out the T2'009 thread too...
Old 03-21-2010, 11:55 PM   #1744
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
hi guys
thanks in advance
well, I don't happen to know the part numbers of the belts on your conversion. But usually the xray PN is printed on the belt. Download the T3 manual off the www.TeamXray.com web site and then you can figure out if the parts cross over
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 03-22-2010, 12:34 AM   #1745
alecladanga's Avatar
thanks hanulec and rx7ttlm, much appreciated
alecladanga is offline   Reply With Quote
Old 03-22-2010, 01:05 AM   #1746
Dana McKee's Avatar
PATRIC DID YOU PRACTICE AT TIMEZONE TODAY OR STILL WORKING ON T-3
Dana McKee is offline   Reply With Quote
Old 03-22-2010, 02:34 AM   #1747
rx7ttlm's Avatar
Car is still in pieces, I just got back from a much needed weekend of decompression camping..
Old 03-22-2010, 05:28 AM   #1748
Pablo Diablo's Avatar
Send a message via Skype™ to Pablo Diablo
Thankyou, Much appreciated.
Paul H
Losi Type R | Xray T3 | CRC Gen XL | CRC Gen X 10 ME(Messiah Edition) | Black Diamond
www.FlyingFoxRC.com | Advanced Electronics | Team CRC | Factory Messiah
Pablo Diablo is offline   Reply With Quote
Old 03-22-2010, 02:12 PM   #1749
Potoczak's Avatar
Trader Rating: 112 (100%+)
Does anybody use the foam inserts behind the bladder when they build there shocks? What does that piece exactly do??
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 03-22-2010, 10:49 PM   #1750
Johnny Wishbone's Avatar
On carpet most don't use the foam, it effects the rebound of the shock, so on carpet most want a 0 -25% rebound shock. You might use it on asphalt though. Since it sits on top of the bladder it makes it harder to compress the bladder on the up shock travel.
Old 03-23-2010, 08:44 PM   #1751
Potoczak's Avatar
Thanks Wishbone for the info that makes sense now!!!
Pete Potoczak
Old 03-25-2010, 08:57 PM   #1752
Potoczak's Avatar
Hey do any of you guys put shims between the shock tower and the shock to move them forward? Does this affect handling at all???
Pete Potoczak
Old 03-25-2010, 09:36 PM   #1753
hanulec's Avatar
Adding shims to the front will make the car less responsibe/lazy but easy to drive. I couldn't use this trick unless your on a high speed track without tight chicanes.
Old 03-28-2010, 08:22 PM   #1754
witz_dan's Avatar
Trader Rating: 25 (100%+)
hey guys
so I ran my T3 for the second time today and was having a comfusing issue for me.
car started out with a really bad push at corner entry to early mid corner.. so as i slowed it would push push push then the front would grab and the rear would break loose. I pust 6* caster up front and the car handled much better but pretty much only when I drove it very aggressive. if I got off my line and slowed to much the car would hook in hard and get loose. still with a slight push.
running pretty much the stock setup with the 6* casters in 17.5
check for tweek and all other settings were good. so what can i do to keep the rear from kicking out if i get off the throttle to fast. this was touch on a little about 20 pages back but faded off.
thanks
witz_dan is offline   Reply With Quote
Old 03-28-2010, 08:32 PM   #1755
lowcel's Avatar
Trader Rating: 80 (100%+)
Does anyone know of any steering bushings (xray part 302291) that will work in the c hubs besides the xray brand? I don't consider myself cheap but paying $17 for four little bushings just doesn't set well with me when other companies sell them for $3 or $4 a package.
Team Whopperjawed Racing
This hobby is going to $5 me to death.
lowcel is offline   Reply With Quote
Xray T2'008 Drew_Cat Electric On-Road 1941 01-25-2016 12:36 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
XRay T3 (spy pics) syndr0me Electric On-Road 33 07-13-2010 04:43 PM
where to get xray?? 2qwik Northwest Racers 20 10-10-2009 03:02 AM
New Xray T3!!! Jammin'Trey Electric On-Road 39 10-09-2009 12:40 PM
