Old 03-15-2010, 04:39 PM   #1696
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
Hey RX7,
heard from a birdie that your a modified guy. I'm hoping to get my T3 finished for the 27th and come up to TZII. Wanna try to get a mod class going? I'm down to pile drive my car into the wall at a high rate of speed
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 03-15-2010, 04:48 PM   #1697
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Originally Posted by Owen RaCing View Post
Hey RX7,
sure, I should have my new orion's by then . The hard part will be to get dave to run lol. If we go back to the old larger layout I am totally down. Not sure about this current layout, its pretty small.
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 03-15-2010, 05:25 PM   #1698
Sounds good.
Old 03-15-2010, 06:25 PM   #1699
ark
Default My T3
I love my T3 Its the best car Ive ever raced to date. Im running Novak Ballistic 4.5, Spektrum, TW RB50, KO servo. Just thought Id share some low quality photos
ark is offline   Reply With Quote
Old 03-15-2010, 06:36 PM   #1700
rx7ttlm's Avatar
Sounds good.
we will see, I just got back from a two day that closes out about a month of straight racing.
Old 03-15-2010, 06:38 PM   #1701
Johnny Wishbone's Avatar
I've found that when I get a notchy feeling diff its usually associated with the thrust bearing and washers. Upon invetigating the thrust washers there always seems to be a small pit right in the grove which the captured balls run in, sometimes so minute that the only way to see/feel it is running a needle point in the grove. So my question is do you prep the thrust washers as well as the diff rings? I bought a 3R diff tool for sanding the diff rings and it looks like it also has a capture part to do the thrust washers too.
NB. One thin to note, is that the 2 thrust washers have two different inner hole diameters and go togeather in a specific order. Alot of people just assume they are the same washers.
Old 03-15-2010, 06:49 PM   #1702
rx7ttlm's Avatar
I haven't tried to resurface the thrust washers, Problem being they are spec'ed out to be 3.5mm thick to locate the screw hole properly. I got some shims to try this with some old parts I kept to test this. But for the first servicing I just flip the washer and use the other side.
The inner diameter of the outboard thrust bearing washer is 3.0mm (if memory serves me correctly) and the other is 3.2mm. the larger Inner diameter washer goes away from the screw head(correct orientation is towards the center of the diff)..
Old 03-15-2010, 07:08 PM   #1703
hanulec's Avatar
Trader Rating: 27 (100%+)
Originally Posted by Potoczak View Post
how do you guys sand your diff rings? Just hold it down with your fingers to the sandpaper? I was looking into the tool the muchmore racing has. Does anybody know where i can get that tool from them??
yup but you don't need to buy a special tool! just use the one half of the diff and 1000 grit paper. get the sand paper wet with motor spray and make figure eights with the rings until you see the surface change color/shine. make sure to spray down the rings, diff balls and diff halfs well.
for fluids - the black associated or losi grease works great on the thrust and associated stealth is the best for the diff balls.
usually when the diff feels bad the problem is the trust bearing. after attempting to rebuild the diff w/ fluids your best bet is to replace the thrust. Paul L says he replaces thrusts about 7 times as frequent as he replaces the diff balls and rings.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 03-15-2010, 07:25 PM   #1704
pcar951's Avatar
Trader Rating: 19 (100%+)
A little trick I learned after sanding my fingertips off a couple of times....Use a pink eraser to hold the ring rather than your fingertips, it works great. I use 1500 grit on one side and 80 grit on the other. The rough side grips the out drive hub a little better and allows me to run the diff loser without the rings slipping.
pcar951 is offline   Reply With Quote
Old 03-15-2010, 09:14 PM   #1705
Potoczak's Avatar
Trader Rating: 112 (100%+)
After rebuilding the diff how tight do you guys make it. Do you make it snug or really tight. Sorry for the newbe questions first time rebuilding....
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 03-15-2010, 09:21 PM   #1706
hanulec's Avatar
tighten your diff slowly. if it isn't in the car yet you can work it in for a few minutes, slowly tightening it. i only make my diff tight enough so that it doesn't slip under max accel. the looser the diff the more your car will rotate.
Old 03-16-2010, 01:56 AM   #1707
Benzaah's Avatar
Trader Rating: 21 (96%+)
Im after some advice on going to a new track. I run a pretty large technical asphalt track and my car is set up pretty nice. I'm going to a big meet at a similar surfaced track but its a lot smaller and less technical. Times running 15.5 vs 23.3 second laps. So,
Do you run the car as is and adjust the set up to suit?
Or take the car back to box set up and work a new set up from their? I have around 8 practice runs to get the car ready for qualifying but will need some later ones for the Tekin. Any advice appreciated. Regards, Benzaah.
Adelaide RC - XRAY Xb216de & Xb416
Walter Rc Hobby - Serpent 4X
Nosram - R1wurks - Sanwa - Hudy - Muchmore
Benzaah is offline   Reply With Quote
Old 03-16-2010, 05:36 AM   #1708
How often should the cone washers in the diffs be replaced?
Futaba 7PX---Xray T4 '18 ---R1 Wurks---EAMotorsports---Hobbywing
kobiwan is offline   Reply With Quote
Old 03-16-2010, 11:34 AM   #1709
Regional Moderator
CarbonJoe's Avatar
With as fast as you go through cars, they should be good for life.
In reality, it probably depends on how tight you make your diffs. But, you can always tighten them down a little more if the washers start to lose their "spring". Not sure how you'd measure this, though.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 03-16-2010, 08:10 PM   #1710
rx7ttlm's Avatar
Xray T2'008 Drew_Cat Electric On-Road 1941 01-25-2016 12:36 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
XRay T3 (spy pics) syndr0me Electric On-Road 33 07-13-2010 04:43 PM
where to get xray?? 2qwik Northwest Racers 20 10-10-2009 03:02 AM
New Xray T3!!! Jammin'Trey Electric On-Road 39 10-09-2009 12:40 PM
