Old 03-14-2010, 09:20 PM   #1681
bigdadracing's Avatar
the 008/009/t3 shocks should be the same. the origanal t2 /007 shocks are a little diffrent they are longer and they are not threaded to the top
rcamerica/xray/ team powers/bsr tires/ slapmaster tools/ bigdads garage/cheep beer/ mykeart paint works / team pop a top
suport your local hobby shop because ebays track is hard to find !!!!!!!!
Russ Jacobson
bigdadracing is offline   Reply With Quote
Old 03-14-2010, 09:55 PM   #1682
Potoczak's Avatar
Trader Rating: 112 (100%+)
Would i be able to run those since they are a little longer? Would that effect any settings on the car??
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 03-14-2010, 10:26 PM   #1683
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
I don't recommend using the 007 shock bodies on the 008-t3, there isn't much travel on the stock shocks. (007/ NT1 shock bodies are longer) and you might bottom out the shock body on the new car with old shocks.
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 03-14-2010, 10:49 PM   #1684
LOSI123's Avatar
Trader Rating: 63 (100%+)
In the Manual for building the t2 009 & T3 the thrust bearing grease and the main diff balls grease is the same grease & part number.
Every other car ive owned states to use a different grease for the thrust bearing (not so thick or tackey usually)
Is the xray manual Correct?
LOSI123 is offline   Reply With Quote
Old 03-14-2010, 10:54 PM   #1685
Trader Rating: 3 (80%+)
your kit should have come with 2 type`s of grease , a greyish black graphite grease for the thrust bearing and a yellow grease for the diff bearings. Hope this helps.
traitor is offline   Reply With Quote
Old 03-15-2010, 12:34 AM   #1686
rx7ttlm's Avatar
I actually started sanding my diff rings recently, and using associated clear diff grease (red label) and the diff slips less while running loose. the clear on the thrust bearing works, but seems to require more tear downs and thrust bearing rebuilds..
Old 03-15-2010, 12:56 AM   #1687
LOSI123's Avatar
But it actually states the diff grease part number on both the thrust and balls & plate.
If this where the case would it not state the graphite grease part number as it does in the cvd part of the manual for example.
Either the manual is wrong on the T2 009 and T3 or Mr Hudy wants us to use the diff grease on both the thrust and main balls and plates as well.
Old 03-15-2010, 04:34 AM   #1688
Potoczak's Avatar
how do you guys sand your diff rings? Just hold it down with your fingers to the sandpaper? I was looking into the tool the muchmore racing has. Does anybody know where i can get that tool from them??
Pete Potoczak
Old 03-15-2010, 05:18 AM   #1689
Pablo Diablo's Avatar
Send a message via Skype™ to Pablo Diablo
I use an old T1 diff half to hold the ring. If you are careful you could use one of your current diff halves(the one that doesn't hold the pulley bearing)>
Paul H
Losi Type R | Xray T3 | CRC Gen XL | CRC Gen X 10 ME(Messiah Edition) | Black Diamond
www.FlyingFoxRC.com | Advanced Electronics | Team CRC | Factory Messiah
Pablo Diablo is offline   Reply With Quote
Old 03-15-2010, 12:28 PM   #1690
What is the best diff balls to use? Ceramic or carbide? I hear some people say ceramic and some say carbide.
Futaba 7PX---Xray T4 '18 ---R1 Wurks---EAMotorsports---Hobbywing
kobiwan is offline   Reply With Quote
Old 03-15-2010, 12:50 PM   #1691
Regional Moderator
CarbonJoe's Avatar
John -
I use the 3/32 ceramic ones from RC4less without issue (stock are 2.3mm = 0.091, 3/32 = 0.093) $8 for 12 diff balls.
http://rc4less.com/Bearings_&_Diff_B...duct_info.html
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 03-15-2010, 02:45 PM   #1692
RC MARKET's Avatar
$5 only !
http://rcmarket.com.hk/index.php?cPath=84_95_251
RC MARKET is offline   Reply With Quote
Old 03-15-2010, 04:06 PM   #1693
rx7ttlm's Avatar
Just as long as you don't try to sand them to much, you can use the long outdrive (female) and use 800-1000 grit wet / dry sand paper. wet the sand paper and make sure there is a puddle where your sanding it. I like to do opposing figure 8's. Check the face often for the pattern and to make sure the groves that the balls were in are evenly wearing away. That and the associated grease and you can build an amazing xray diff. If i had to guess I was able to run about half the pre-load that I used to before building diffs this way. To reuse the thrust bearing just flip it to the other side. I used to only do this on pancars, but now its my standard diff build.
Old 03-15-2010, 04:15 PM   #1694
rx7ttlm's Avatar
Obviously ceramic has the benefit of being lighter. They seem to allow the diff to slip more (read smoother). I run carbide just because they seem to work well. I have some ceramic balls but after the first time I tried them I switched back cause I felt they didn't have enough bite. Other people have used abrasive pastes to break in their diff with them.
Old 03-15-2010, 04:17 PM   #1695
rx7ttlm's Avatar
Correct, if you take your t3 diff apart from the factory, you will notice that its no longer black moly grease on the thrust bearing
Xray T2'008 Drew_Cat Electric On-Road 1941 01-25-2016 12:36 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
XRay T3 (spy pics) syndr0me Electric On-Road 33 07-13-2010 04:43 PM
where to get xray?? 2qwik Northwest Racers 20 10-10-2009 03:02 AM
New Xray T3!!! Jammin'Trey Electric On-Road 39 10-09-2009 12:40 PM
