Old 03-02-2010, 06:58 AM   #1591
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
Originally Posted by rx7ttlm View Post
The sphere tc was one of the first esc's that I know of to have some built in timing advance. The advance it has is minimal, especially compared to the tekin etc. But it still has some. As the brushless have evolved they have more and more timing built in or able to be adjusted. I could be wrong, but I am pretty sure that's correct.
I really think your thinking SPX man, because if the sphear had such minimal timing advance, I can't see you needing to drop to 5.0-6.0 in 17.5. The last 3 profiles on a SPX had ever more violent timing gain, which ment you needed to lower your FDR more and more the higher the number profile. I ran 5.5 fdr in 17.5 SPX at RCPlus. Car sucked all day and I had no clue what to do with it, but I seemed to have a good amount of motor. (figuring it was only a 17.5, so there was really not much motor there )
SPX and Sphears look the same with the heat sink installed.
-Mike
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 03-03-2010, 06:12 AM   #1592
Potoczak's Avatar
Trader Rating: 112 (100%+)
Hey guys just picked up a used t3 from a fellow rc tech member. My question is what kind of rebound are you guys running on your shocks and is it worth building the shocks with the clicker adjustment or just stick to the standard 2 or 3 hole piston setup? Also another question how do you's break in a freshly rebuilt diff? i have never rebuilt a diff on a touring car so this is all new to me!!! Thanks for any info!!!
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 03-03-2010, 06:41 AM   #1593
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
I would go for around 25% rebound. Around there works the best for alot of people. If you and try and build them with 0% rebound, generally the shocks become very hard to build. I wound go standard, but some people like clickers, up 2 you really. No benifit in either. 3 hole pistons, 1.1mm. And yes run teh diff in after a frest build
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 03-03-2010, 10:51 AM   #1594
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
-Mike
I have a sphere TC in the other room. I ran the novak gtb right before, There is some timing built in.. anyhow..
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 03-03-2010, 10:55 AM   #1595
rx7ttlm's Avatar
Carpet? 550 shock oil front, 350 rear, 3 hole fixed pistons seem to be what works well. so thats 1.0mm holes. Try that and go from there.
Rebound is in the dead to 20% range. No foam insert in the bladder.
Diff - tear it down, clean everything with solvent. Lube the thrust bearing with hudy black moly grease. Lube the diff balls and rings with associated clear diff grease (diff slips less). and be careful not to preload the diff to much as you need to bed the diff rings and balls. some people apply throttle while holding one of the rear wheels. I usually just break it in on track being mindful of diff slippage. and adjusting every 1/2 pack till its seated (about 3 for me)
hope this helps
Old 03-03-2010, 01:38 PM   #1596
Trader Rating: 3 (80%+)
Hey how often are you guy`s rebuilding or re-lubing your diff? Thank`s guy`s
traitor is offline   Reply With Quote
Old 03-03-2010, 05:39 PM   #1597
Potoczak's Avatar
Thanks for the input guys
Pete Potoczak
Old 03-03-2010, 05:51 PM   #1598
JayL's Avatar
the TC has fixed timing advance, meaning the timing is set by the esc based on the profile and it stays there
the spx has timing that actually changes during the run
mike: you are going xray too?
JayL is offline   Reply With Quote
Old 03-03-2010, 06:41 PM   #1599
Yup, going back to Xray. I heard you got one, build that thing yet? Hope I can get mine done for spring break. Itching to run SWR
Old 03-03-2010, 07:42 PM   #1600
RLMW VQ's Avatar
every 20-25 runs or when it feels crunchy. also depends on what you running in your diff. ceramic or carbide diff balls.
Hotbodies-HPI Racing- Hara Products-Team Fantom Driver-True RC-Rc Hobby and Track
RLMW VQ is offline   Reply With Quote
Old 03-03-2010, 07:44 PM   #1601
cwoods34's Avatar
I've always used about 50-75% rebound, but I guess it's just personal preference. It is easier to set a shock to "0" as in little to no rebound.
I have the clicker shocks on one of my vehicles, and they are pretty cool. I don't know that I prefer them over standard, though. It is faster to just "click" it where you like, but theoretically if the shock was ever fully lengthened it could catch on the clicker and not extend completely. However, I don't think that TC's have/use enough suspension travel to completely elongate a shock assembly, unless you're running 8 mm of droop, so I've never had it happen nor do I worry about it.
I like 2-hole front, 1-hole rear for the pistons
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 03-03-2010, 08:35 PM   #1602
Potoczak's Avatar
Have any of you guys swapped out the hardware (meaning the screws) with the RC SCREWZ kit? Is there any advantage to use the stainless steel screws. I personally think it looks pretty awesome. But other then that i am not sure...
Pete Potoczak
Old 03-03-2010, 08:58 PM   #1603
rx7ttlm's Avatar
if you were to swap screws I would think it would be for ti screws since they are lighter. But with the T3 your adding so much weight why spend the extra $ on it? I seem to remember stainless hardware was weaker than stock harware.. could be wrong but that's what I remember from offroad back in the day.
Old 03-03-2010, 09:10 PM   #1604
Potoczak's Avatar
What kind of metal do the RC SCREWZ kit use????
Pete Potoczak
Old 03-03-2010, 09:14 PM   #1605
rx7ttlm's Avatar
I think they are stainless. You can get mugen Ti screws that have a similar look but actually weigh less... But like I said, When your adding 30-60 grams of ballast just to make weight seems silly now.
Xray T2'008 Drew_Cat Electric On-Road 1941 01-25-2016 12:36 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
XRay T3 (spy pics) syndr0me Electric On-Road 33 07-13-2010 04:43 PM
where to get xray?? 2qwik Northwest Racers 20 10-10-2009 03:02 AM
New Xray T3!!! Jammin'Trey Electric On-Road 39 10-09-2009 12:40 PM
