Old 02-27-2010, 02:16 AM   #1576
Tag
Tag's Avatar
Trader Rating: 31 (100%+)
hello, i found the screws that secure the wheel hubs a little fragile and it can be stripped easily if not careful , just wondering if possible subsituting these screws from other manufacture ? looking for somthing stronger
* Serpent 966 TE Novarossi 35+21, Airtronics M12 *
Tag is offline   Reply With Quote
Old 02-27-2010, 08:52 PM   #1577
Potoczak's Avatar
Trader Rating: 112 (100%+)
Is there any links or threads on how to properly use a set-up station for touring cars? Any help would be great!! Thanks
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 02-28-2010, 10:59 PM   #1578
nitro rat's Avatar
Trader Rating: 5 (86%+)
hey guys, just a quick question..... does a 28tooth pinion with an 84tooth spur sound alright? it leaves me with 5.70. this is using a 10.5.
i like the quality of the car, went together really nice
SMC BATTERIES
ALPHA ENGINES
TEAM DURANGO
nitro rat is offline   Reply With Quote
Old 03-01-2010, 02:24 AM   #1579
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
I believe the setup guide that comes with the car is very good. Basicly you bolt the plates on. and the main thing is you have to remember that when you change something like camber on the front, it can also affect toe etc.
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 03-01-2010, 02:33 AM   #1580
rx7ttlm's Avatar
It depends on your track and esc, if your timing profile in your esc adds dynamic timing you should run a numerically higher final drive ratio. I think with a sphere tc i was running between 5-6 fdr (minimal timing advance), Now I run 6.2~ in 17.5 with a tekin RS since it adds so much dynamic timing
Old 03-01-2010, 02:35 AM   #1581
rx7ttlm's Avatar
they aren't the strongest fasteners, but you shouldn't need to put much torque on them since they are very small, and they are captured by the wheel and just need to be index finger and thumb tight.
Old 03-01-2010, 02:38 AM   #1582
rx7ttlm's Avatar
Do you think it would be to stiff ???
Yes, if the tire you will run most is rubber. get the rubber car, IMO the foam cars are far to stiff for 98% of the tracks you will run with rubber tires. I run a HIGH bite carpet track and i have yet to run with even the side posts yet.
Cheers,
Patrick
Old 03-01-2010, 05:37 AM   #1583
nitrobeast's Avatar
Trader Rating: 41 (100%+)
Yeah they really suck. If youve stripped them you are tigheting them way too tight. That screw doesnt need to be that tight, the wheel holds it all together.
Rui Goncalves
Team CRC|Awesomatix USA|TQ Wire|
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 03-01-2010, 05:59 AM   #1584
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Cheers,
Patrick
Interesting the different setups that alot of people are using. Here in Australia, on med grip Asphalt, im using all 3 posts in the car, with my best results so far. I found the car flexes too much without the rear ones in. Especially on power. Im running modified though
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 03-01-2010, 06:58 AM   #1585
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
Since when did sphear tc's have timing advance You mean SPX? Sphear's and Sxx's don't have timing advance. Just straight change in timing. Nothing ever advances or ramps like a Spx- Sxx SS or 199-200-203 Tekin.
I know it's early, but im confused
-Mike
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 03-02-2010, 01:28 AM   #1586
Professor's Avatar
Default L1 & L2
can some one explain what effect these actually have on the t3 or 009 as opposed to not using them or conversely using them on either the front or rear only ?? thanx & appreciate any feedback
graham
VBC RACING AUS--HOBBYWING--RC MAKER--
MAD GRAPHICS--BITTY DESIGN
Professor is offline   Reply With Quote
Old 03-02-2010, 02:08 AM   #1587
rx7ttlm's Avatar
I dunno, I have wanted to test somethings. Like martin hudy's setup from DHI cup is totally different than mine or any of the us drivers I have seen. To each their own, last week someone drove my car and was like wtf. Your car has NO rear grip. I just like a car that turns lol. So I think alot of it depends on driving style and preference. But so far I haven't seen many people using the rear side posts. I plan some more testing this weekend with front post etc. But I found the rear end can be a bit inconsistent and have a tendency to have a bit more unpredictable over steer on power exit.. Just ment that I don't think using the US chassis with rubber tires would be best.
Old 03-02-2010, 02:11 AM   #1588
rx7ttlm's Avatar
-Mike
The sphere tc was one of the first esc's that I know of to have some built in timing advance. The advance it has is minimal, especially compared to the tekin etc. But it still has some. As the brushless have evolved they have more and more timing built in or able to be adjusted. I could be wrong, but I am pretty sure that's correct.
Old 03-02-2010, 02:20 AM   #1589
rx7ttlm's Avatar
graham
ok, L1 and L2 run in the normal high roll center position (down / inboard), raises the roll center more than the 009 high roll center postion, with a longer link. In the up position it also allows a longer link than the 009.
Alternately in the rear I have been using the L1 on the left rear with the pin in the down inboard position and L2 in the RR in the same way (opposite of the kit directions) and I have found the car has less overall rear grip, but it free's the car up and helps in transitions. One of the other guys tried it and the third corner decided he hated it and needed more rear traction lol.
If your running a T3, it might be a good idea to get some of the 009 roll center pills as an intermediate. Handy on med-low grip tracks.
Old 03-02-2010, 04:14 AM   #1590
Benzaah's Avatar
Trader Rating: 21 (96%+)
Hi, can you explain your thinking on this some more as I run T3 now on med grip asphalt. What roll center position do you suggest with these 009 adjusters? And do you mean front and rear? Cheers Benzaah
Adelaide RC - XRAY Xb216de & Xb416
Walter Rc Hobby - Serpent 4X
Nosram - R1wurks - Sanwa - Hudy - Muchmore
Benzaah is offline   Reply With Quote
Xray T2'008 Drew_Cat Electric On-Road 1941 01-25-2016 12:36 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
XRay T3 (spy pics) syndr0me Electric On-Road 33 07-13-2010 04:43 PM
where to get xray?? 2qwik Northwest Racers 20 10-10-2009 03:02 AM
New Xray T3!!! Jammin'Trey Electric On-Road 39 10-09-2009 12:40 PM
