Old 02-15-2010, 05:55 PM   #1516
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Originally Posted by Magnet Top View Post
rx7ttlm,
I'm very interested in details about your drive shaft binding issue and your results of further testing today. I've had significant issues with my car "snap" hooking and would love to know how confident you are that the 50mm dogs are the fix. I've been trying everything I can think of and not much works that isn't drastic and has significant compromises ( basically dumbing down the front suspension ).
Thanks,
Jake
if your coming down for the 3 day race this weekend (nwic at timezone II) we can get this worked out. But I changed the bones, tested. and 0 snap oversteer. I intentionally didn't tweek the car. just rebuilt shocks with random spring preloads. and it worked fine. I will get on posting a setup now lol. To check your own car, with your car aligned like you would throw it on the track compress your rear shocks one at a time. Remove the pinion and spin the spur gear, the rear tires should spin at the same rate. if the compressed side stops you also have the problem. After I changed the bones this was a non issue for me.
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 02-15-2010, 06:34 PM   #1517
rx7ttlm's Avatar
Ok, my jaco blue setup is posted on the xray site now.
Old 02-15-2010, 07:12 PM   #1518
Magnet Top's Avatar
RX7ttlm, Thanks! I'll bench test it tonight and post. Were you seeing the snap over steer on entry or exit, or everywhere ? I mainly had it on entry but my car over rotates with a base setup ( w/ out rear bar ). I've been running anti-dive and larger front bar to help tame it down on entry which has helped but I have to always be aware it could snap on me. Lastly I put the rear bar back on to help the rear and front have more symmetry thinking that was the reason it was behaving weird ( it helped the entry snap and due to your finding it makes sense as to why! , but now on a low traction track I'm not getting the grip I'd like. Running negative on the pin blocks makes the grip come up but the car is too "lazy".
I'm hoping to make the TZII NWIC race as I've been looking forward to it but there is a chance I won't be able to . please send me a PM with your name so I know who you are. btw, I used to race Rotary's ( rx-7, rx-2, r100, formula Mazda ) I'm assuming your screen name is related to Rx-7's !
Jake
Magnet Top is offline   Reply With Quote
Old 02-15-2010, 07:53 PM   #1519
rx7ttlm's Avatar
Jake
ygpm, and it was at entry. I drive it in hard lol.
Old 02-15-2010, 08:22 PM   #1520
Originally Posted by nitro ho View Post
I know where i can find them, on my car,lol,lol,lol,lol,lol.
And thats the truth
And mine too LOL . And im in Canada
but they came from RC america LOL. from a Canadian distributer
Dustin Quanstrom
bambikilr is offline   Reply With Quote
Old 02-15-2010, 09:14 PM   #1521
Magnet Top's Avatar
rx7ttlm,
At least with my current setup ( 3.5 of rear toe ) and my diff in the up position and long rear wheelbase I am not seeing the phenomenon but I can easily see it could occur with the narrow toe and the dogs not as swept back ( short wheelbase ) which you are showing in your setup sheet. Also, at the last race just a few days ago the snap oversteer wasn't nearly the issue it had been when I was using 1 degree of outboard toe and a shorter rear wheelbase but I thought it was due to my other changes ( that are a compromise ) . So it is very possible I avoided the issue by accident.
Question, how far did you compress your shock before it bottoms out the dog bone ?
Old 02-15-2010, 10:47 PM   #1522
rx7ttlm's Avatar
rx7ttlm,
On mine it wasn't far at all. A couple mm. As grip comes up this weekend I might be into running 6 degree blocks. We will see...
Old 02-16-2010, 07:15 AM   #1523
rx7ttlm's Avatar
Update, got a text from Paul L, he changed his rear axles for the same reason. added that he felt it also free'd up the car..
Old 02-16-2010, 11:17 AM   #1524
I guess being canadian does have some perks
RROL and LOU`s where only real racers race.
Weapons of choice,NT1 2010 , X-Ray T3 x 2, X-Ray X10 X-Ray all the way baby.
Futaba 4pk,gq tires,jaco tyres,odonnel fuel,T-Power batteries, tekin and nova powered.
Don`t blame the car, when you know you can`t drive.
Sponsor, me , myself and I.
nitro ho is offline   Reply With Quote
Old 02-16-2010, 11:19 AM   #1525
lowcel's Avatar
Trader Rating: 80 (100%+)
I guess so, can't find any in the US and RC America hasn't had the courtesy to call me back since I left the message last week.
Team Whopperjawed Racing
This hobby is going to $5 me to death.
lowcel is offline   Reply With Quote
Old 02-16-2010, 11:26 AM   #1526
Sorry to hear that you couldn`t get a hand on those babies.
They`re awesome well worth it.
Old 02-16-2010, 03:15 PM   #1527
Default XRAY T3 Problems
Hi Everyone,
I am from Colombia. We have 3 T3 running in our track. I have run mine in 3 race meetings with good results.
However we have problems with the 3 cars these are:
- A lot of wheel vibration in the front, causing screws to fall.
- One of the chasis has break in the front suspesion point.
Does anyone has a solution without having to buy the expensive ECS or changing the Spool to the expensive Multi-diff?
Many thanks
Jorge
jandrestbb is offline   Reply With Quote
Old 02-16-2010, 04:23 PM   #1528
Answer #1 did you use lock tite for an extra bit of protection from the screws backing out?
Answer #2 The T3 did have this problem a few months ago, This problem has been resolved with huddy making an extra beefy suspension mount included in all the most recent kits being released.
Answer #3 Can`t help you with the chattering, your gonna have to buy the Ecs shafts...BTW they`re worth if, even if they`re a little pricey.
Old 02-16-2010, 05:24 PM   #1529
rx7ttlm's Avatar
Originally Posted by jandrestbb View Post
Hi Everyone,
Many thanks
Jorge
First, if your lucky enough to run on a large flowing track. You have the option of turning down the dual rate so you have less steering throw. But after one run with the stock shafts I had to get the ecs shafts.... also the multi diff isn't the greatest thing for this car since depending on your drive train layout you will have a 2wd car with the optional front belt right setup..
Old 02-17-2010, 01:19 AM   #1530
P.I.M.P's Avatar
Trader Rating: 14 (100%+)
Hi guys thought I would give xray the thumbs up for the t3 as first run today track was not clean and the car had good front grip and rear it's much nicer to drive then the 009 it's a great car for mod easy to drive I'm loving it.and dose anyone know if xray has changed the blatter material as they are much hard and don't seem to be swelling as fast there kinda a grey colour now.
Vbc wildfire D06
clinton livingstone
P.I.M.P is offline   Reply With Quote
Xray T2'008 Drew_Cat Electric On-Road 1941 01-25-2016 12:36 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
XRay T3 (spy pics) syndr0me Electric On-Road 33 07-13-2010 04:43 PM
where to get xray?? 2qwik Northwest Racers 20 10-10-2009 03:02 AM
New Xray T3!!! Jammin'Trey Electric On-Road 39 10-09-2009 12:40 PM
