Old 10-09-2009, 08:49 AM   #1
Hua
Default Help with charger and batteries...
Hi all
I have been away from r/c for like months, just recent, i bought 2 new packs of Team Orion Rocket Pack 3300 MAH NIMH batteries from my LHS..
So my very 1st thing to do when i reach home, i discharge the pack @ 10amps since my charger only allow 2 charging rate either 2 AMP or 10 AMP and i charge it for use @ 3.3amp...
Just about 5mins or so,my batteries show false peaking, same for another pack.. my charger Beeps indicate the battery is oready fully charge, but reading was @ 8.4V @ range from 5xx~6xx MAH
After that i discharge the pack and charge it again, same thing happens....then i called back the shop owner, they recommend me to cycle the pack[s] few times, see wat happen...and so i did, i cycle the pack 5 times...capacity did increase by abit but, battery dun peak...after tat i dare not to discharge the pack, since there is some capacity inside, i just put it away..
The charger im using was a APEX MU+ -> http://www.apexhk.com/products/mup.html
Any1 can tell me if the charger is not compatible with the battery im using now or is the battery faulty? or maybe both? Should go for a better charger eg: LRP pulsar 3?
Hua is online now   Reply With Quote
Old 10-09-2009, 09:15 AM   #2
sosidge's Avatar
They probably just require a number of cycles to bring them back to life.
Keep re-peaking the cells until they are warm to the touch. If they are cold they are not charged. Then discharge.
A few cycles like this should decrease (hopefully stop) the false peaking.
Old 10-09-2009, 09:25 AM   #3
Hua
So which means, even tho 10 time cycle cant really gurantee if the battery will 'wake up'?
another thing is, i heard new battery which bought from fresh requires a very low amp charge like maybe overnite charge to allow the cell to hit to the max capacity? wat if i didnt do that?
Old 10-09-2009, 09:32 AM   #4
sosidge's Avatar
There is no guarantee the cells will wake up, it sounds as if they have been resting for a long time.
A handful of incomplete or fast charges is not going to do the cell any harm. The harm comes from a long period of misuse.
Old 10-09-2009, 09:59 AM   #5
padailey's Avatar
I just looked up that charger and found some reviews of it stating false peaking. Also the description always mentions 3000mah... not sure why you couldn't use higher capacity batteries but maybe not. Can you borrow someone elses charger to try? That should tell you right there where the problem lies.
However though it might just be what others have mentioned and it will take several cycles to wake them up. What I have found is each cycle you should get a little more capacity into the cell. If that is happening you should be heading in the right direction.
www.hobbyplexraceway.com
Tamiya TRF417X (Lion's Automotive GTR)
Tamiya TRF416X
Tamiya F104W MP6/4 converted to F104X1 (Renault R30)
padailey is offline   Reply With Quote
Old 10-09-2009, 10:07 AM   #6
Hua
Oh ic, now im doing cycle again on the 2 battery, 1 of them looks like it waking up, but after i discharge it, let it rest for like an hour plus, i charge it back, it false peak again...
Wanted to go lipo need some help on charger and batteries vito357si Electric Off-Road 10 02-23-2009 12:27 AM
New guy needs help with charger tiko Rookie Zone 30 02-04-2009 08:22 PM
Help with Charger Michael_T Electric On-Road 13 11-06-2001 10:16 AM
