Help with chossing a good servo >
Old 02-11-2004, 06:28 PM
DT-Skyline's Avatar
Default Help with chossing a good servo
Can someone tell me which good servos to get from either HiTec Or Airtronics. I need a speedy racing servo ranging from $50-$200.
Thankx for your advice
DT-Skyline is offline
Old 02-11-2004, 07:37 PM
Tek Nickal's Avatar
Get the Ko high speed, the fastest servo you can afford and its only 100.00 the other 100.00 should be spent elsewhere.
Tek Nickal is offline
Old 02-11-2004, 07:45 PM
DT-Skyline's Avatar
Thankx man. Where can i find this ervo though?Hobby People?
Old 02-11-2004, 08:20 PM
Tek Nickal's Avatar
Try asking your LHS to order it, you can tryfinding it on-line. There are plenty of RC online shops, incuding the sponsers to this site.
Old 02-11-2004, 09:09 PM
seaball's Avatar
for the ko stuff look here:
http://rctech.net/forum/showthread.p...113#post715113
go to the first post, and follow the link.
it is for an analog servo (2113), but the same site sells the digital(2123).
likely the best servos out there right now.
0.06sec/9.5kg*cm - can't be beaten.
seaball is offline
Old 02-12-2004, 04:28 AM
Cole Trickle's Avatar
Gotta KO 2123 myself - extremely fast, precise and realiable. Can only reccomend it.
Cole Trickle is offline
Old 02-12-2004, 11:36 AM
psycho's Avatar
I agree with Cole Trickle. The PDS2123 is the best servo made, imo.
psycho is offline
Old 02-12-2004, 04:15 PM
Korey Harbke's Avatar
I got one at X-mas and it;s the best servo I've tried so far. I close second comes the PDS-2143. Still really fast, digital, and a little easier to use in gas cars since there is no FET wire. Both are awesome servos and you can't go wrong with any of the Ko Servos.
-Sushi Boy
Korey Harbke is offline
Old 02-12-2004, 05:06 PM
seaball's Avatar
Thumbs up
the only other series of servos that come close to those specs are the 94X57's from sanwa/airtronics. and the new 94758 digital from them.
the interesting thing here is that this is acheived with only 6.0 volts.
seaball is offline
Old 02-12-2004, 05:15 PM
DT-Skyline's Avatar
So digital servo's are better? Is thedre a difference between a digital servo and a plastic gear servo? Thankx for the posts guys
Old 02-12-2004, 05:25 PM
seaball's Avatar
well, digital versus analog, refers to the type of control applied to the servo motor. the digital servo "checks" itself much more frequently, and will have stonger holding power given the same specs. both can work well.
a plastic gear servo is just that. the internal gears that transfer the movement from the servo motor to the final output gear can be plastic, metal, or usually a combination. in my opinion a metal gear is quite superior regardless of what type of servo it is. it can be more precise, will grip the servo horn better, and the screw through the center will not likely strip out.
seaball is offline
Old 02-12-2004, 05:30 PM
DT-Skyline's Avatar
So wat ur tryin to say is that anolog's with steral gears are decent but a digital servo is much better, reliable, quicker and more pricy am i right?
Old 02-12-2004, 05:35 PM
Tek Nickal's Avatar
It depends if you have that fet servo wire. I have one. The Ko digital one is only 15.00 bucks more. If you don't have the fet servo wire, just go with the analog one.
Old 02-12-2004, 07:31 PM
seaball's Avatar
yes, that is a fairly accurate way to sum it up. a good analog servo can perform very well. you won't likely notice a difference until you are a very experienced racer.
the analog servos can post the same specs as a digital when it comes to speed and torque. it's more a positioning quality difference, than a raw power difference.
check out this link. it's a great reference.
http://www.futaba-rc.com/servos/digitalservos.pdf
seaball is offline
Old 02-12-2004, 09:22 PM
Tek Nickal's Avatar
^^ Yeah, that about explains all of it.
