Old 10-04-2009, 07:56 PM   #1
Nemo racing's Avatar
Send a message via Yahoo to Nemo racing
Default Team Power Brushless Motor Checker
NEW Team Power Brushless Motor Checker
Features:
- Input voltage: 7.6V -8.6V(Suggested Power Input Source: 7.4V 2S-1P LiPo Battery)
- LCD Screen: Blue Screen, White Text Monitor
- Dimension: 150mm x 80mm x 25mm
- Supported Motor: Sensor or Sensorless Brushless motor.
(i) RC Car Motor: 2.5 Turn or over
(ii)Flight Motor: Current drawn that is less than 18A without the Loading
- Functions Included:
(i) Endbell Sensor Test
(ii) RPM/KV measurement
(iii) Ampere measurement
(iv) Motor Cycle
Team Power Brushless Motor Checker-motorchecker-p4.jpg   Team Power Brushless Motor Checker-motorchecker-p6.jpg
A800
Scorpion Power System
Nemo racing is offline   Reply With Quote
Old 10-04-2009, 11:20 PM   #2
Kevin CBR's Avatar
You can test any brand motor with this ?
Kevin CBR is offline   Reply With Quote
Old 10-04-2009, 11:32 PM   #3
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
Im interested. Is there any more literature i can read about?
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
TEAM ASSOCIATED|REEDY|HITEC|PARMA|PROTEKRC|SWEEP|IWATA| RPM|AMAIN|CREATEX/WICKED/AUTOAIR PAINTS|CFX|CAL RACEWAY
charlie_b is offline   Reply With Quote
Old 10-05-2009, 12:34 AM   #4
Looks nice but the SP motor checker does all this and uses your speedy to control the motor. This allows you to see how the motor performs with YOUR speedy and also has the advantage of being able to test and compare different settings/software on the same speedy.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 10-05-2009, 07:46 AM   #5
Agree. It is a good concept to use real ESC to test the motor. However, i think most players including me will check the motor only when there is a problem. I have also bought SP checker and connect my ESC to check the failure motor, but due to the unknown motor problem, my ESC burn out suddenly and I didn't know what happen and didn't know which part is failure.
Besides, it is too complicate to install several modules together to work for SP
checker. I think everyone hope that the checker should be very simple to operate and don't want get trouble on the installation before checking the motor.
engine.tech is offline   Reply With Quote
Old 10-05-2009, 11:20 AM   #6
Can this be use to tech motor in RC race ? I think it is good to find out if my motor is still healthy or not.
afung1 is offline   Reply With Quote
Old 10-05-2009, 11:45 AM   #7
Racecrafter's Avatar
Trader Rating: 25 (96%+)
Features:
(iv) Motor Cycle
Novel indeed. Problem is to make accurate the input voltage needs to remain constant. A battery pack will not allow for this. You need a well regulated power source. A Lipo battery has a serious Voltage drop which will render back to back testing unreliable.
just my $.02
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 10-05-2009, 11:52 AM   #8
DENNIS STORTI's Avatar
Trader Rating: 42 (94%+)
Send a message via AIM to DENNIS STORTI
just my $.02
i disagree considering you can test a motor in about 30 seconds even testing multiple motor will not be affected by the battery if u use a charged battery when you use this its gonna be very good for analyzing this again is my beleif cause lipo bvatterys do not fall off much during the run so i would assume that during a test your thoughts of inconsitent voltage is incorrect
DENNIS STORTI is offline   Reply With Quote
Old 10-05-2009, 12:17 PM   #9
I commend your arguememnt. However do you know what the RPM or Torque difference would be between 8.4 volts versus 8.3v? Or even just a .5v difference? With "X" motor.
In ANY test procedure there should be no input variables.
In this case Voltage.
Jimmy Wright
Old 10-05-2009, 12:22 PM   #10
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
why not just put some kind of voltage reg in the circuit.
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
Old 10-05-2009, 12:29 PM   #11
Super Moderator
charlie_b's Avatar
Im almost wondering is you can just connect a simple 10a power supply like the OFNA one to power it.
It could be a simple fix, right?
Old 10-05-2009, 01:43 PM   #12
The main reason they choose to use battery instead of power supply:
1. Power supply that racer use everyday mostly have an out put between 10 to 30 Amps. IF the motor checker run off the power supply and the motor checker start to run a motor (an modify 3.5 turn motor) it will have a surge peak. And that peak will cause the power supply to cut off. And if you have other product connect to the power supply like charger and tire warmer. It will cause those machine to reset. Using an lipo battery pack will not cause any of those problem.
2. As a racer, you will have as lease one pack of battery. And if you are a serious racer that demand this kind of equipment, you will have more than one pack of battery.
3. In combination of running the Motor checker with the battery, you will also be able to feel which battery will give out better motor performance.
A800
Old 10-05-2009, 02:02 PM   #13
Swampgremlin's Avatar
If you are checking just to see if you're motor strength is good why would you're battery matter I mean you can test you're battery sepreatly right? I don't know I would think a good motor is a good motor. Reguardless of what battery you are using.
Swampgremlin is offline   Reply With Quote
Old 10-05-2009, 02:37 PM   #14
over gear's Avatar
Trader Rating: 15 (100%+)
cool. that mean i can find the best lipo/motor combo with 1 tester.
over gear is offline   Reply With Quote
Old 10-05-2009, 03:21 PM   #15
Trader Rating: 48 (100%+)
Maybe use the motor lathe function on the charger as the power supply?
Yellowtaro is offline   Reply With Quote
Cebu RC Car Racing Club jpn Manila Racers 14147 05-27-2016 10:01 PM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 08:17 AM
New TEAM WAVE racing brushless system TEAMWAVE Electric On-Road 1930 07-25-2014 07:12 AM
Novak 10.5 Brushless Motor - Integy Tire Truer - Integy Motor Checker dbme R/C Items: For Sale/Trade 6 09-18-2009 05:54 PM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Lots for Sale With More To Come !!!! mav913 R/C Items: For Sale/Trade 13 05-16-2009 02:33 PM
