Old 01-04-2010, 11:18 AM   #46
Ok. I've got my Team Powers unit in and have been going through all my 17.5 and 13.5 T motors. I've noticed a very consistent set of numbers if I use a 7.4V 5000mah lipo that is fully charged before each test cycle. Once the battery, hooked to unit with no motor, shows 8.2 volts or lower, then I recharge the battery for 5 mins and start testing again. This seems like a hassle but it isnt. I can check about 5 motors before the voltage drops on the battery. Of course, you can continue to check motors against one another even when the voltage drops; just make sure that the voltage range is consistent. There is a slight variance in numbers from a fresh charged pack to the same pack once dropped to 8.3 V, after testing about 5 motors for 1min each. Example, my Putnam Propulsion 17.5 tested with a fresh battery read; V=8.4, Amp or I=1.8, RPM=21400, KV=2579. The same motor and battery tested at 8.3V read I=1.8, RPM=21116, KV=2575. As you can see, not much difference but there is a difference. I have not started testing with load yet but have a small boat prop that I am going to use for load because I agree, there needs to be a load of some sort that is consistent from motor to motor. The above test was done at full power setting but I am now checking the difference at mid power, because the motor stays in that range a lot during racing. What I like about this product is I can use the Epic I-Gauss and swap cans and rotors of the same turn to put together a kick ass motor.....I will let you know the results of testing all my motors and then putting together the best of the parts into one stock motor.
Burst is offline   Reply With Quote
Old 01-06-2010, 09:06 AM   #47
abe-racing's Avatar
for all the guys in the uk there is a full review of the motor checker in next months radio race car... need any help let me know
ABE-Racing,Team Orion, Blakey Designs, Xray RcDisco,T-Shox
abe-racing is offline   Reply With Quote
Old 01-07-2010, 08:10 AM   #48
Thank you for sharing with your testing result. This device is quite helpful to for the racer to fine tune the motor.
engine.tech is offline   Reply With Quote
Old 01-10-2010, 08:08 PM   #49
anyone have further comment?
Old 01-14-2010, 02:44 AM   #50
i find this checker have one more useful function. it can use a fix voltage to run the motor. then we can use a fix 4.2V to run our motor to simulate 1cell performance.
Old 01-14-2010, 05:57 AM   #51
Trader Rating: 21 (100%+)
Please explain how to do it for 4.22.
Rick "Blue" Sieboldt - Mooresville, NC
* Associated T5M * Tekin * TQ Wire *
www.tqracing.com/rc_products.htm For all your wire needs
lidebt2 is offline   Reply With Quote
Old 01-14-2010, 12:41 PM   #52
abe-racing's Avatar
for you guys looking for team power in the uk .. i would like to welcome
Reality Racing
11 Whitefield Road
New Milton
Hampshire
BH25 6DE
01425 627676
to our dealer network, we are looking for more dealers including ireland
Old 01-16-2010, 06:06 AM   #53
abe-racing's Avatar
now also avalible from
sld models
45 eastgate street
stafford
email [email protected]
Old 01-16-2010, 07:48 PM   #54
The below guideline quoted how to use a fix voltage to run the BL motor.
1. After Power up the unit, press and hold the Mode key for around 2 second, then it will enter to the Motor Break-in mode.
2. As in the Motor Break-in mode, the displayed voltage value V will be flashing for setting. This value can be set to different values 2.5V~7.2V through Inc and Dec key.
3. After the voltage value V is set, press the Stop key to change the setting on T value. Pressing the Dec key continuously until T value will become F then press Start key again, the fix voltage break-in process will be started.
Old 01-18-2010, 05:12 AM   #55
abe-racing's Avatar
i know team powers are after a usa dealer so if you are an interested party either contact them of myself and i will pass your info on
Old 01-22-2010, 08:26 AM   #56
try the team powers item. good product.
Old 01-28-2010, 03:26 AM   #57
any comment?
Old 12-19-2011, 06:43 PM   #58
Crew Dad's Avatar
Has anyone used it to tech motors at the track? or would it work?
Crew Dad is offline   Reply With Quote
Old 12-19-2011, 10:35 PM   #59
No. The Team Powers motor checker is just what it says it is. A checker. You can check your sensor board to make sure it is working and you can get RPM, watts and amps. What you need is this meter.
http://www.tequipment.net/BK875B.html
This is the meter that ROAR uses at it's national events to check motors in technical inspections. You also have to check the rotor diameter and magnet thickness by measuring the diameter of the rotor where the magnet is bonded to the rotor shaft. You then compare your readings with the ROAR motor and rotor approval list to see if a motor is legal.
Rocket RC Speed Shop - USA Importer of Team Powers products
[email protected]
http://rocketrcspeedshop.webstorepowered.com/
Crashby is offline   Reply With Quote
Old 12-23-2011, 05:00 PM   #60
Buckaroo's Avatar
So if you're comparing two motors of the same wind, what sort of numbers are you looking for to determine which is the better motor?
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Cebu RC Car Racing Club jpn Manila Racers 14147 05-27-2016 10:01 PM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 08:17 AM
New TEAM WAVE racing brushless system TEAMWAVE Electric On-Road 1930 07-25-2014 07:12 AM
Novak 10.5 Brushless Motor - Integy Tire Truer - Integy Motor Checker dbme R/C Items: For Sale/Trade 6 09-18-2009 05:54 PM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Lots for Sale With More To Come !!!! mav913 R/C Items: For Sale/Trade 13 05-16-2009 02:33 PM
