Tc3 plus rear Losi carriers >
Old 02-10-2004, 09:41 PM
Exclamation Tc3 plus rear Losi carriers
when mounting the ball studs are you using the outer hole or inner hole ( inner being holee towards the car when mounted)
Anyone notice a difference with the roll center with these? Did they help the car rotate through turns better? Just curious.
Smalls is offline
Old 02-10-2004, 09:44 PM
I used the outter hole on the hub. It seemed to give the car more of a push on power...
The inner hole is close to the same position as the outter on the stock TC3's hub...(might be different height)
Bubblestc3 is offline
Old 02-10-2004, 09:48 PM
Speedie's Avatar
I mounted mine in the inner hole. Biggest plus I see is the extra spacer for wheelbase adjustment and the strength. Havent broken a hub since I bolted them on 2 months ago. Also the AE hubs would bend and screw up my toe setting.
Speedie is offline
Old 02-10-2004, 10:26 PM
carkillaii's Avatar
i want to try the losi rear end
but what parys do i need to do it
carkillaii is offline
Old 02-10-2004, 10:27 PM
carkillaii's Avatar
parts
(parys)
