Old 10-02-2009, 10:39 AM   #1
Regional Moderator
CarbonJoe's Avatar
Default Rubber tire care between races?
What do you do to maintain your TC rubber tires between races? Ziploc bags, simple green, WD-40, etc. How about for longer term storage (say like a few months)?
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 10-02-2009, 11:16 AM   #2
I don't have them so long!! My rubber tires run for just 3 days and than they are gone. I put Quick and Bright on it.
Works great. Also will your tires live longer in the races.
I run 2 to 3 heads more on them with Quick and Bright.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 10-02-2009, 01:11 PM   #3
J.Filipow's Avatar
Trader Rating: 15 (100%+)
P1 Brand Tire Tubes™ are a simple way to organize and store your rubber or foam tires between races. They are lightweight, compact, airtight and feature a laminated lid label that can be used to record tire data with a dry erase style pen (not included).
Available in both 10th scale and 12th scale sizes:
http://p1brand.blogspot.com/2009/05/...ire-tubes.html
http://p1brand.blogspot.com/2009/06/...ire-tubes.html
And can be purchased online at the P1 Brand Shop-
http://p1brand.bigcartel.com/
Rubber tire care between races?-tube_master-copy.jpg   Rubber tire care between races?-p1_tire_tube_12th_scale.jpg
P1 Brand - "Victory is Black and White" ◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤
RC America / XRayUSA / Hudy / Motiv / Avid / Vannen Watches
J.Filipow is offline   Reply With Quote
Old 10-02-2009, 01:19 PM   #4
Regional Moderator
CarbonJoe's Avatar
Besides storing them in a hermetically sealed tube, what else should be done to extend the tire life, or at least prevent them from degrading?
Old 10-02-2009, 01:26 PM   #5
Rockpyle's Avatar
Trader Rating: 23 (100%+)
I usually clean them with motor spray really good, put a very light coating of wd-40 on them (spray it on a rag not the tires) and put them in a ziploc freezer type bag.
Rockpyle is offline   Reply With Quote
Old 10-02-2009, 01:28 PM   #6
Regional Moderator
CarbonJoe's Avatar
What effect does the WD-40 have on them? Keep them from drying out? Make them softer? Stickier?
Old 10-02-2009, 01:52 PM   #7
liljohn1064's Avatar
Trader Rating: 17 (100%+)
WD40 works cleans the tires and makes them a bit tacky. Motor spray (brake/contact cleaner) cleans the tires and they stay fairly neutral, not so tacky, but with grip. Naptha Lighter fuel) cleans the tires and makes them gummy (I use this for dried up foam tires).
Long term, zip lock with a little of your traction compound will keep them healthy.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 10-02-2009, 01:58 PM   #8
Regional Moderator
CarbonJoe's Avatar
Does the motor spray or brake/contact cleaners dry out the rubber at all?
Old 10-02-2009, 02:19 PM   #9
It sure can. The tires usually don't last long enough, but that stuff will melt the tires first, then dry them up as the cleaner evaporates if you're not careful. I spray it on a rag, not on the tire and as soon as the tires are dry I put on a light coat of sauce. Its key to put some compound on them if store them after cleaning them with this stuff.
Old 10-02-2009, 03:45 PM   #10
Pro10noob's Avatar
Between heats i clean them with brake cleaner and long term storage i put some tire gue on them and store them in very cheapish pringle bins
You can put 4 sets of tires in them and they work like a charm and they cost nothing
You have to put some race tape on the top to make the lid shut air tight tho.
cheers Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 10-02-2009, 04:24 PM   #11
yokemad's Avatar
Wurth Brake Cleaner to clean Tyres and use some clear clinic film to store Long term or a plastic bag ...
Good Luck
yokemad is offline   Reply With Quote
Old 10-02-2009, 04:41 PM   #12
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
What I do in between races is use the ZipLoc Vacuum seal bags. You can purchase a starter kit with vacuum pump for less than $5. I purchase the quart sized bags. Just prior to inserting the tires into the bag, I clean the tires and place a bit of Tire Tweak on the tires. After this, zip the bag up and remove with the pump, remove the air.
IIGQ4U is offline   Reply With Quote
Old 10-02-2009, 04:51 PM   #13
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I clean my tires with buggy grip between races. Buggy grip a shop towel and wipe the tire down. Cleans well without drying the tire out.
Old 10-02-2009, 04:52 PM   #14
Danny-b23's Avatar
Between heats:
1. After you clean dust off the tires, put Simple Green on them and leave it to evaporate.
2. After they're dry, if you can see any shiny spots just wipe them with a rag. Then apply your favorite traction compound.
3. Leave the tires for as long as you see fit to get the usual traction, maybe not quite as long as usual.
Between days:
Same thing, but make sure the tires are dry, as to keep your pit bag clean.
Off-Season:
1. Check the tire for holes or cuts and the rim for cracks.
2. Douse the tires that are good in Simple Green for a couple minutes.
3. Leave them to dry for a couple hours.
4. Once they're dry, put on a citrus-based traction compound like Niftech and store them in Ziploc double-zipper bags.
RC America|XRAY|ORCA|Motiv|EA Motorsports
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 10-02-2009, 06:24 PM   #15
cheehtae's Avatar
I use goo gone to wipe and clean it off and store them in pringles can. Make sure you get the flavor you like best.
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Trackside Matt M. Wisconsin & Illinois Racing 17052 12-04-2017 11:58 AM
KARZ Calgary xrayroooahhhh Canadian R/C Scene 19114 12-01-2017 01:26 PM
EGTC Summer outdoor Series (ESLROC) Silver Cup Northwest Racers 5558 01-29-2012 04:13 PM
nwic 2008/2009 FATTOM Northwest Racers 1325 05-19-2009 05:16 PM
Multiple tracks in an area - good or bad? or8ital Electric On-Road 23 12-20-2007 09:52 AM
