Old 10-02-2009, 08:43 AM   #1
PrimeAKF11's Avatar
Default What happens when different winds are geared for same speed?
Pardon my newbness, but I couldn't find the answer anywhere.
It is my understanding that the higher the motor wind numbers are, the lower the kV but bigger the torque, right?
..So what's the difference between, say, a 10.5 motor and a 13.5 motor that is geared for same top speed?
If my calculations are correct, a novak 10.5 in a touring car with FDR of around 5 would have top speed of 40mph. I can gear a 13.5 in low 4's and achieve the top speed right around there. In a case like this, what kind of advantage would the 10.5 car have against the 13.5 car?
Best rubber tires>> www.SweepRacingUSA.com
For your Team Magic G4 parts needs>> www.bluesunhobbies.com
HD Videos of Blue Diamond Onroad Raceway!!! 200ft+ straight of fury!! >> http://www.rctech.net/forum/racing-forum/406318-2nd-annual-pete-johnson-have-nice-day-memorial-race-5.html
PrimeAKF11 is offline   Reply With Quote
Old 10-02-2009, 08:46 AM   #2
geeunit1014's Avatar
The 10.5 will accelerate faster. In other words, they may have the same top speed, but the 10.5 will get there faster.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 10-02-2009, 08:55 AM   #3
PrimeAKF11's Avatar
Why? Since the 13.5 has higher torque, wouldn't it negate the taller gearing?
Old 10-02-2009, 08:56 AM   #4
snoopyrc's Avatar
Punch!
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 10-02-2009, 09:33 AM   #5
tfrahm's Avatar
Send a message via AIM to tfrahm
The key is to understand that RPM and/or Torque are not the numbers that matter most -- POWER is what you are after...
In your gearing example, you have geared the motors based on RPM to get to the same top speed -- you have not factored in the simple truth that the 10.5 has more POWER, which as someone else noted is seen as "PUNCH" on the track. Torque is multiplied by the gearing also, so the 13.5 may have more torque, but it is working against taller gearing (lower numeric ratio) -- the 10.5's torque is multiplied by the higher numeric ratio, which again brings us to the fact that nothing makes up for more POWER.
"If you cannot win, make the one ahead of you break the record."
Biff Racing Team #420 (Ah... The "good old days"...)
The local indoor Offroad Track: The RC Race Barn
TLR22-3.0, TLR22T-2.0, TLR22SCT-1.0
tfrahm is offline   Reply With Quote
Old 10-02-2009, 09:33 AM   #6
gubbs3's Avatar
You're missing the fact that lower winds have a higher power potential, measured in watts. A motor with more overall power, geared to the same top speed, will accelerate faster. This is the same whether you are measuring power in terms or torque or horsepower (RPM) because the required gear ratios will balance out and you will still just be comparing motors in terms of which is more powerful.
It is also not necessarily a fact that higher wind motors have MORE torque than low wind motors. It is simply that the current low wind motors are capable of pulling REQUIRES a low gear ratio to reduce current draw in order to keep the motor from overheating.
gubbs3 is offline   Reply With Quote
Old 10-02-2009, 09:36 AM   #7
PrimeAKF11's Avatar
aaaah I see. That clears up perfectly. Thanks guys!
