Tekin RS Pro?
Old 09-26-2009, 06:37 AM
RCknight's Avatar
Default Tekin RS Pro?
Just wondering if you can remove the wire posts? Never much cared for them.
RCknight is offline
Old 09-26-2009, 06:47 AM
liljohn1064's Avatar
Trader Rating: 17 (100%+)
They are the heat sink.
liljohn1064 is offline
Old 09-26-2009, 06:49 AM
The manual states not to cover them with anything, as they act as heat sinks.
So do what you will, but you have to ask yourself....
What would Jesus do?
Sean B. is offline
Old 09-26-2009, 07:00 AM
RCknight's Avatar
Default Thanks for the info.
I got one on order.
RCknight is offline
Old 09-26-2009, 07:24 PM
Team Tekin
Randy_Pike's Avatar
DO NOT remove the posts from the RS PRo. You can cause more damage than it's worth. Both power boards must have sufficient contact between them.
If you want to remove part of them you can cut them shorter but this DOES reduce their ability to remove heat from the unit...
Randy_Pike is offline
Old 09-26-2009, 07:26 PM
pakk's Avatar
Trader Rating: 80 (100%+)
I have them removed. Been running 17.5 and have never seen more than 1 led as far as temp goes.
--pakk
pakk is offline
Old 09-26-2009, 07:32 PM
Joey4875's Avatar
Does anyone want to share the 200 software? I have the software loaded on my speedo but i would like to be able to fine tune it
Joey4875 is offline
Old 09-26-2009, 08:22 PM
snoopyrc's Avatar
Are we running two separate threads for the RS and RS Pro?
snoopyrc is offline
Old 09-26-2009, 09:08 PM
Default 200 software
u have pm joey.
Robert
robert s is offline
Old 09-26-2009, 09:19 PM
vabroom's Avatar
I think there are 4 including this one.
the original
the one cell
the setup
vabroom is offline
