ko mars radio, how do u servo reverse? >
Old 02-07-2004, 11:01 PM
Default ko mars radio, how do u servo reverse?
i just bought a used mars radio without instructions, how do you get it to servo reverse...when i turn the steering wheel left it turns right vice versa. thanks
SubaruSTi is offline
Old 02-07-2004, 11:08 PM
Trader Rating: 49 (100%+)
If its an ex-1 mars, do the following: press balance and key.a at the same time while turning the radio on, this will put you in system mode, next use the balance down key until you see reverse st and then push key.c and put it normal. Hope this helps
weaponx is offline
Old 02-07-2004, 11:15 PM
ah ok thanx, problem solved
